03-01-2007, 11:31 PM | #51 |
Chief Honcho In Charge
Re: 67-72 LED tail lights in stock $59
I just ordered mine.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
03-02-2007, 12:58 AM | #52 |
Active Member
03-12-2007, 04:13 PM | #53 |
Mine came last week...Monday I think. I wanted to get them right in.
Of course on a 35 year old truck...there is an issue of rust to deal with. Mainly in the socket area. So I... http://www.67-72chevytrucks.com/vboa...d.php?t=230420 And all is good. These are truly plug and play. Thanks Musclerodz
03-12-2007, 08:08 PM | #54 |
just ordered mine... thanks
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
07-21-2008, 10:43 PM | #55 | |
Ochre Club?
And yeah I am just now getting to installing them....parenthood is a real drain on the free time
'71 Cheyenne LWB 2WD for sale |
07-22-2008, 08:00 AM | #56 |
You most likely have a ground issue. I had a similar problem.
See this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=230420
07-22-2008, 12:42 PM | #57 | |
Ochre Club?
Maybe I'll just try the replacement flasher first to see if that fixes things. It should be cheaper than new rear housings.
07-22-2008, 12:46 PM | #58 |
You need an electronic flasher to replace your mechanical flasher. You will also need one for the hazards. We have had a few trucks require these with just the tail lights, but most did not. You can get them at your local auto parts store. If they don't have them, we stock them.
The LED's don't draw enough amperage for the mechanical flasher to sense the light so it just thinks a light is out. The electronic flasher uses voltage so when you activate the circuit, it automatically flashes.
Mike Redpath Last edited by Musclerodz; 07-22-2008 at 12:46 PM. |
07-22-2008, 03:32 PM | #59 | |
Ochre Club?
07-22-2008, 06:05 PM | #60 |
Mechanical flashers are thermally operated which means the wire has to build heat to work which is something you don't want to do. NAPA should have them, I don;t have their part number though.
Mike Redpath |
07-24-2008, 12:23 AM | #61 |
Ochre Club?
Replaced my flashers today with electric units from Napa, and they did the trick! Thanks everyone.
12-12-2011, 01:11 PM | #62 |
bbadfred
Do the musclerodz/spaghetti engineerng sequental led taillights fit stock lenses also??
12-23-2011, 03:25 AM | #63 |
yes they do. thanks
Mike Redpath |
12-23-2011, 08:43 AM | #64 |
I just went to your store page and it said out of stock. Are you going to be getting more?
