04-23-2007, 10:21 PM | #51 |
Tripple Five Fanatic
Re: 1950 LQ9 conversion
Just by looking at it, I think it's a little too high, you might have problems with the tunnel. You should try to get the engine as level as possible. Good job on boxing the frame! What type of shocks are you using with the front bags?
Tri5 |
04-24-2007, 08:43 AM | #52 |
I am not worried about the tunnel, my floor has a little rust for to aft is where I dont want to mess with the fire wall. Engine is level, the buble sits on the line giving it a slight lean to the back. The SHocks came with the Airbag kit...which I am questioning b/c it might keep me off the drag strip, still deciding to keep the bags or get some springs.
I am going to clearence the shaft and the crossmember using some tubing welded into the crossmember, and in the pic it is off b/c I have the jack under there, when I took it out the engine leveled up nice, and my home made motor mounts worked, I gave myself 50/50 odds at them working the first time. oh yea the frame is not boxed yet, just the pic I guess |
04-26-2007, 12:57 PM | #53 |
just to give an example of the engine height in relation to the cab (51 GMC), here is a couple of pics that show the installed height of engine. first pic shows the bottom of the A/C compressor mounted on a 5.3 truck motor & the notch I cut in the cross member of the 84 Monte front clip. The second pic shows the trans protruding into the floor. I could not get around moding the floor & keep the motor where I wanted it. I did raise the front clip up to get the stance I want tho. so this might not be the best example to make comparisions to. Still have not driven it yet because I'm still working on the body, but it sure sounds good!
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
04-26-2007, 11:52 PM | #54 |
go buy an angle reader...5 bucks are home depot. You want it at 3 degrees back...
04-27-2007, 11:51 AM | #55 |
polishing a turd
just make sure the angle finder is right. the one i bought from home depot is 2 degrees off. set it on a level and make sure it zero's out.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
08-19-2007, 08:31 PM | #56 |
update july/august.
real dont know what to do next?? any suggestions? I am going to pull the cab back off and start the floors and frame mounts so it can bolt up to the frame. I have a bunch of other stuff, fuel tank brakes, plumbing. Anybody know good places that sell kits to get the entire project done at one time? Last edited by Detroit3100; 08-19-2007 at 08:35 PM. |
08-19-2007, 08:51 PM | #57 |
I don't know of any kits, but what you need to do is take that young man and teach him how to weld and turn wrenches and that you can have him do it while you drink beer....LMAO.
Bernie |
08-20-2007, 11:50 AM | #58 |
I don't know how true it is, but someone told me that when you remove the center crossmsmber and cab you might have trouble lining up the hood when you start the re assembly. So let me know how your mock up goes on re assembly !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-30-2007, 01:04 AM | #59 |
Detroit 3100 any idea on after market harness and re flashing the computer, and do you need the pressurized fuel tank and how about the antilock brake sensors... I just have a few questions =). I'm considering the same swap!!
11-16-2007, 02:10 PM | #60 | ||
ABS-dont know, but I dont think the engine PCM controls the brake system. New pics. THe hole I cut for new floor pans. Engine Aired down Last edited by Detroit3100; 11-16-2007 at 02:13 PM. |
11-21-2007, 03:27 PM | #61 |
12-20-2007, 08:21 AM | #62 |
12-29-2007, 07:02 AM | #63 |
PROJECT 7DEUCE
Looks like you guys are makeing some progress keep up the good work.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-25-2009, 05:53 PM | #64 |
my garage fell on the truck. crushed the cab roof pretty good. I am looking for a new home for this sad
01-25-2009, 08:03 PM | #65 |
Huge bummer. That's not the kind of update we were all hoping for. Snow load on the garage roof make it collapse?? Is the cab roof repairable?
58 Apache short fleetside ona 64 chassis: Last edited by poncho_villa; 01-25-2009 at 08:06 PM. |
01-29-2009, 10:45 AM | #66 |
Detroit3100 - I have an extra 3-window cab...rusted junk from the door handles south, but the roof section is good. You are welcome to it. I'm in the Grand Rapids, Michigan area. PM me if you are interested.
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
09-26-2010, 11:13 AM | #67 |
update. sorry no pics...yet.
I moved, got a garage, garage is like truck...both need new roofs I put a new roof on the garage. I am back to thinking about finishing a project I started cough...half my life ago...cough So I am looking for a new cab and old projects in my area and I want to drive this before I die, work on it with my sons, and give it to them. Looking at the damage...its not that bad, I think the doors will still work, so untill Ii find different the rat rod/steam punk theme just got a big helping of patina...a pitna sunroof you might say. I need to organize my tasks...pull the cab/bed back off after the move and nail down the frame/drivetrain. I grab pics to get you guys interested. other updates: I have he software to program the GM Gen III Pcm. I am no HPtuners pro, but its an added tool. My buddy has been hiding a miller plasma cutter and 110 mig welder, so I finally go them to my garage. have this turbo manifold I built for the LQ9. I welcome any suggestions for a method to this madness. |
02-17-2012, 05:35 PM | #68 |
I am putting this thing back together!!!! I have a little motivation, not shooting for any trophies, just want it back on the road. I know if I get it back, that my kids will get to enjoy it. Pics to come soon. I have the bed on and figuring out the bed floor. Gonna put doors back on and see if I can sub assemble the front sheet metal. three main areas:
1. powertrin 2. suspension. 3. body. going to work on the body and getting it rolling and then I can set the motor trans in place.. |
02-23-2012, 10:22 PM | #69 |
budget fender welting for the box. rubber roofing material. This was a test, I am going to cut long strips and punch the holes out and cut reliefs.
Gathering parts, front end is all accounted for. After I get the cab repaired I will bolt these up. Wanna have this as a unit so I can pull it off as one assembly while I am finishing plumbing/wiring. and I have photobucket on my phone so I am going to take plenty of pics |
02-28-2012, 01:47 PM | #70 |
Sheet metal repair parts were just ordered from Top Banana. Will report back. Did a frankenstin job to a rear fender but it will work for the shop truck.
Need to find some 1/4 thick rubber for the cab/bed mounts any suggestions?? Also Mounted the drivers door for the cab repair fit and also pulled the rest of the LQ9 harness off the motor and gathered the underhood fuse panel for wiring. Gonna try to use the underhood panel for all of the truck and add the needed wiring. |
02-28-2012, 02:10 PM | #71 |
If you are near a farm and ranch type store, they sell high density rubber horse trailer flooring material. Cuts with a box knife.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-28-2012, 03:14 PM | #72 |
You can cut some pretty neat washers with a hole saw out of those urethane bumpers that you find on the free way as well.
Retired and too busy to work. |
02-28-2012, 04:04 PM | #73 | |
I'm use'n semi truck mud flaps for my 59 build on my mounts. I picked up one at a truck stop for $10 bucks. It's 20"x26" 1/4" thick with a 2" border thats 3/4".
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
02-29-2012, 02:25 PM | #74 |
Keep posting pictures and information.
I have a LQ9 and 1950 and they will go together some day in the future. I'm doing the C4 Corvette suspension so it will be interesting to see what I need to do for an oil pan to clear that crossmember...
1950 Chevy 3100-Transforming into a hot rod. Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=435302 |
03-01-2012, 05:02 PM | #75 |
sheet metal arrived today. thats good service, thanks top banana. Will post pic's when I get the tools out. Dang I might make a big step this weekend if I can weld these pieces into place.
