#51 |
67-72 Addict!
Re: My first build thread LED REVERSE LIGHTS!!
I use part number #EL-12 to run my LED tail lights (all 700 of them)
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#52 |
Wow that is awesome
#53 |
Self-proclaimed LED man
Got any pictures of your turn signals and brake lights?? please do tell!!
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
#54 |
724X4, What do you think the durability is on those things? Will they last very long or is it gonna be something that will burn out once in a while?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#55 |
leds have a rating of 100,000 hours. your average 60 watt light bulb only has 1,000 hours of life. http://electrical.hardwarestore.com/...bs-102546.aspx They should last a LONG time. Assuming that you do the resistors right and provide only the proper voltage to each led
Reds = 1.8-2.2 volts White = something like 3 volts (cant remember)
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 03-13-2007 at 04:32 PM. |
#56 |
Got Light Emitting Diode?
i have 3mm green, 3mm white, 5 mm white, and 5mm amber all calling for 3.2v-3.6v and 3mm red and 5 mm red calling for 1.9v-2.3v.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#57 |
Wheres a good place to buy LED bulbs? So far Im not having any luck...
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
#58 |
#59 |
i prefer to buy mine from someone here in the states, there's a guy in maryland (wilni14) that has a good selection and a guy in kansas (randccom). randccom seems to only sell reds though.
http://search.ebay.com/_W0QQsassZwilni14QQhtZ-1 http://search.ebay.com/_W0QQsassZrandccomQQhtZ-1
#60 | |
67-72 Addict!
#61 |
Sunglasses!!!!
Alex 1971 Lil' Red 350 SBC 700R4 |
#62 |
Chief Honcho In Charge
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#63 |
Where are the other 44?
#64 |
67-72 Addict!
Dash and sidemarkers using the refractor style LED's (5 bulbs per each unit)
#65 |
how in the world to you fit so many in the tail lights? they must be 3mm's instead of 5mm? ECE's kit looks packed and they only have like 200 per side. Did you take pics as you built them?
Justin
#66 | |
67-72 Addict!
#67 |
Thanks for the sites.
Ive got one more question, the soldering iron we had in our shop was 100 watts and its shot. I need to get another one, what wattage would you recommend? Id need one that could do work like for these reverse lights and also for regular wiring in the cab. Should I get 2 different ones? They had one that was 15/30 watts variable, but I dunno if 30 watts is enough for bigger wires.
#68 |
67-72 Addict!
Justin- After checking the pic it's actually 12 rows x 27 columns for a total of 324 individual bulbs per tail light. That's 648 LED's and ALOT of soldering
#69 |
This is the soldering gun i have. Its a weller rated at 240/325 (Dual Temp) I havent had any problems with it and it does everything i need. The only time it doesnt work is when it comes time to solder to the bulbs. I usually get the propane torch out for that one and heat up the copper surrounding and solder to the inside of it.
#70 |
[QUOTE=70c10;2076980]Justin- After checking the pic it's actually 12 rows x 27 columns for a total of 324 individual bulbs per tail light. That's 648 LED's and ALOT of soldering
![]() ![]() GEEZE!!!! i thought 85 took a long time!! I just finished laying out my passenger side setup. Sticking with 85 per side but i didnt offset them like i did on the driver side. Hopefully it wont be noticable. I really need to get one of the electronic flashers. my hazard lights blink about 3 times/second. ![]() Justin
#71 |
67-72 Addict!
#72 |
any idea where he got the bulb inserts?? Its a real pain to try to modify and make them work. We bought ours at weslakes when they closed out their rental department. Also got a bluebird engine hoist and some small engine (briggs) tools
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 03-15-2007 at 04:13 PM. |
#73 |
Can someone elaborate on what is needed if you do LED flashers and taillights? The EL-12 flasher?..
#74 |
You might PM 68w/sbc406. He did a build thread on the turn signals. Its in the FAQ section. I did the retard version of his. I just lit up half for running lights and the other half come on with the brake/turn signal.
#75 | ||
i havent had to change my flasher yet since i still have incandescent tail lights. but you just need to get a electronic flasher when you go full LED since they dont draw as many amps to trip the stock flasher. i know napa has them.
