Old 05-02-2007, 03:57 PM   #51
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Re: I bought a Dana 60!
Originally Posted by arkracing View Post
Dumb question - do you have to move the spring perches on the D60 to put it in? I'm assuming No since the pass side mounts right to the center section - but was just wondering.
Bolts right in, you dont have to modify the perches.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 05-02-2007, 04:37 PM   #52
Burt4x4
Burt4x4's Avatar
Originally Posted by johnnywagon View Post
To simplify things I ordered a u-bolt kit from Skyjacker. It came with studs!
Cool! Let us know how that works out
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-03-2007, 02:08 PM   #53
martinkh
What shocks are you using with the d60 front? I don't mean brand, but the 1/2ton ones, 3/4 ton, 1 ton? how does the mounted length work out ei mount to mount distance compared to the d44?
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 05-03-2007, 02:10 PM   #54
johnnywagon
Its always something! Here's some info for anyone doing a front D60 swap. If you buy a D60 u-bolt kit, be warned that its for a real one-ton truck with thick one-ton leaf springs. The u-bolts and studs were way to long for my "thinner" leafs. No big deal on the u-bolts, I just cut 'em down. But the studs (that thread into the diff) aren't threaded far enough down to simply cut. So its either thread 'em and cut 'em or do something else. Right now I'm temporarily using bolts, but I plan on using studs long term.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-03-2007, 02:47 PM   #55
johnnywagon
Good Question. My truck has been all three: 1/2 ton, 3/4 ton & now 1 ton. All with the exact same shocks. I got out the Rancho book and all three list the same part #. The only differences are for how much lift you have. I did relocate my shock mounts up to the top half of the axle, rather than hanging below but I doubt I'll need a different lenth shock.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-08-2007, 11:31 AM   #56
johnnywagon
I had a productive 2 days off. She's done. Locker is in. New shorter front drive shaft is in. Modified brake lines seem to work and the top is off!
More D60 swap facts:
- Because of the bigger axle tube and the tall spring pads, the front is about an inch taller now.
- Because of the much bigger diff. I had to shorten the front drive shaft, however it still used the same u-joint as the D44.
- The brake hose bolt (on my D60 calipers, there are diff. types) is a smaller diameter than the D44. The 6" lift Skyjacker brake hoses seem like they will still work with the smaller bolt AND a 90 degree adaptor.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-08-2007, 11:36 AM   #57
johnnywagon
Oh yea, NO I havent tested the front locker out yet, and YES she has the infamous D60 deathwobble.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-08-2007, 03:18 PM   #58
Burt4x4
Burt4x4's Avatar
Ok you offically beat me toit (but I am installing a rear 14FF too so..)
Good Job!
My driveline fit without making it shorter...I only have about 1"or less of "in" travel left..I don't know if this will be a problem or not..I have all kinds of "out" travel now
Thanks for the pics of that 90deg fitting...I will probly need the same thing as I have SS Earl lines.
As for deathwobble I am combatting that with crossover and eliminating the KingPin springs (source of the deflection/wobble). I will keep you posted with how I get that done...would work very well on yours too...
Thanks for the update
Burt
Old 05-09-2007, 03:05 PM   #59
johnnywagon
Burt, I am definitely interested to see your progress w/the kingpin/crossover steering project.
Thanks.
BTW: I just discovered a new problem/project. The driverside front leaf spring H.D. lift shackle on my rig is bent/twisted and the welds on the H-beam are cracking. It looks like the frame is bent there as well. Gonna need a custom crossmember....at least.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-09-2007, 03:36 PM   #60
Roper
Different year GMC one tons 4 wheel drives used different front brake lines.
I know when I swapped in my dana 60 I didnt know the year so I ordered in about three different year models of brakelines before I got the right ones.
But if you kbnow the year of the truck the dana 60 came out of its no problem.
Also even with 4" of lift I didnt need extended brake lines. I just moved the brake lines down closer to the axle.
Also that front driveshaft is the same on 1/2 tons and 1 tons. 205 takes a shorter shaft than a 208 but they are both the same diameter.
The outer u joints on the dana 60 are the weak point. Those will usually go before your front driveshaft.
Also for the studs on the housing of the dana 60. I ordered new studs from Superlift and they didnt fit. Then I ordered them from somebody else and they didnt fit either so I just reused the studs that came on my dana 60.
About u bolts. Corporate 14 bolt FF came in 3 different houseing diameters of the years. Im going from memory but I think they came in 3 1/4", 3 3/8" and 3 1/2" So take dial calibers and measure your axle housing before ordering u bolts. Basically depending on what you have for suspension your going to have to find a place that custom makes ubolts. Any spring shop should be able to make them up.
Roper is offline   Reply With Quote
Old 05-09-2007, 06:09 PM   #61
earl87gta
earl87gta's Avatar
Thanks.
I would check this out http://www.diy4x.com/suspension.htm they have 67 to 72 HD front spring nount kits now. a little pricey at $270 but I dont think you can bust one.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 05-09-2007, 07:00 PM   #62
johnnywagon
Oh great, more cool stuff I want to buy.
Seriously, thanks Earl.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-10-2007, 10:09 AM   #63
Yukon Jack
Post Whore
Yukon Jack's Avatar
Awesome progress! Dana 60 looks right at home under your K5.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2007, 01:46 PM   #64
johnnywagon
Thanks everyone for the compliments. Hopefully I'll hit the trail this Sunday.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-10-2007, 07:55 PM   #65
earl87gta
earl87gta's Avatar
No problem when I seen them they went on my got a have list. now I just need a taller lift to go with them.
Earl
Old 05-15-2007, 11:18 AM   #66
johnnywagon
The new front lockright locker works great!!!!!
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-15-2007, 08:28 PM   #67
RED72blazer
urban fourwheelin
RED72blazer's Avatar
what is the infamous deathwobble?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 05-16-2007, 01:31 AM   #68
earl87gta
earl87gta's Avatar
danna 60 fronts like to let the front wobble a bit to fix it you can add an extra bushing for the king pin. you may have to add 2 some times just replacing the king pins help but most the time you have to add the extra bushing.
Earl
Old 05-16-2007, 11:06 AM   #69
johnnywagon
The locker works great!! Definitely going to need to fix the death-wobble.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 05-20-2007, 08:39 PM   #70
scotto0609
Junior Member
Upper bushings and spring. Cheap easy fix.
scotto0609 is offline   Reply With Quote
