04-05-2007, 09:41 AM | #51 |
Re: some parts that are still f/s
ummm.... might need to look at having the blue one shipped. I-26 is over 3 hours west of me! wheew! I'm putting in a 454 w/400 tranny - auto - does the column have enough shift positions (not the older, 2 speed type - if there is such a thing???..)? And could I get a pic too... Thanks much!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
04-05-2007, 11:10 AM | #52 |
67 lower Alternator bracket $10 how much shipped 97405?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
04-05-2007, 12:53 PM | #53 |
luvlegs getting a pic.
chad shipping $5.00 |
04-05-2007, 01:12 PM | #54 |
here is the blue colum i have it came out of a 72 with a 400 trans. the bottom shaft needs to be replaced it was hit with a lawn mower. |
04-05-2007, 01:16 PM | #55 |
here is the damage part your old one may work if it is the same size. |
04-05-2007, 01:18 PM | #56 |
cpne i am going now to check your parts . will let you no tonite.
04-05-2007, 01:38 PM | #57 |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-05-2007, 09:17 PM | #58 |
cpne i looked at it today its there but how do you take it off? i took the bolt and little bracket off but could not get the part you want off. it was cold here so i did not mess with it to long.
04-05-2007, 09:32 PM | #59 |
Resident Curmudgeon
If you got the bracket off that holds the housing in place, it should be a matter of pulling it out. It presses in and has an o-ring seal IIRC. Since it's been there about 40 years, you may have to persuade it. Perhaps you can grab it with pliers and twist it side-to-side to free it? Or if there is a spot for leverage, maybe pry it upward? I need this part so if you can get it without damaging it and the threads that the speedo cable go on, name a fair price to cover your hassling with it.
04-05-2007, 11:19 PM | #60 |
Im checking on the board to see if I can swap the pieces - gimme until tomorrow to get some replies - thanks!
04-06-2007, 08:28 AM | #61 |
OK - I'll take the column - Paypal work for you? I'll PM you with my info.
04-06-2007, 11:36 AM | #62 |
cpne is this what you need? i will pm you with payment info. luvlegs i also pmed you. |
04-06-2007, 11:39 AM | #63 |
Resident Curmudgeon
Bingo! That be it. PM me. Thanks
04-07-2007, 12:30 PM | #64 |
cpne parts shipped yesterday. thanks
