Old 04-26-2007, 10:53 PM   #51
edman87
junk collector
Re: 4X4 Crewcab Stepside Project..............
Hey, it has those see thru rockers too!
I am just not used to everything being that rusty. I definately can't wait to see the finished truck.
On that 81, 4 speed od? What trans would that be?
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 04-27-2007, 12:18 PM   #52
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
that awsome i tell you tho i could really use that power steering bracket. my buddy had a emissions truck removed the emissions and he need a preemissions power steering bracket. For now he just made one work ok my looks very jerry rigged.
Cool truck tho.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-28-2007, 10:37 PM   #53
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Originally Posted by mike nutt View Post
rick , what kind of shape is that suburban cab section in, reason i ask is the suburban from the back of the rear doors forward is the same as a crew cab truck.just cut the burb off just behind the rear doors and graft on the rearwall of a pick-up cab (two door or four door) that might be easier than repairing the trucks cab . just a suggestion . well good luck on you project .
Thanks for that Info, Actually the burb is in Pretty Good shape other than Passenger side Rear Rocker, Will Look into Using that instead of Patching the Crew. If any one has done this any info would be appreciated..............
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 04-29-2007, 12:41 AM   #54
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Originally Posted by toomanytoyz View Post
Bought a 81 Stepper Today, It has got to be the Plainest Truck I've ever seen for a 73-87 model,
Plain Jain?!? But it's got those AWESOME von Dutch style pin stipes on the tailgate
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-29-2007, 01:25 AM   #55
pcmcobra
pcmcobra's Avatar
you stole that burb...
good deal
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 04-29-2007, 01:56 AM   #56
toomanytoyz
Luv the Crewcabs
Got Them on the Hood also.................
About as Plain as you can Get...............
Old 04-29-2007, 02:16 AM   #57
liljon285
That Guy
liljon285's Avatar
Let me holla at the coulmn plastic thing, I am taking of my column shifter and putting it on the floor. Can i just get something like that plastic piece and replace mine?
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 04-29-2007, 02:17 AM   #58
liljon285
That Guy
liljon285's Avatar
WHoa! $ on the floor, although it is a 6 inline still looks like fun!
Old 04-29-2007, 02:27 AM   #59
toomanytoyz
Luv the Crewcabs
Actually scoot's along Pretty Good with that 6, On that Column Thing, You can have this one when i get it Parted................
Maybe be a Little while Though, Any clue what that Tranny might be worth?
Rick
Old 04-29-2007, 02:45 AM   #60
liljon285
That Guy
liljon285's Avatar
yea my truck has is gonna be done by maybe next year, its nothing I NEED so dont worry about it. For the tranny you should check what it is, Ive seen some saginaws get some good money.
Old 04-29-2007, 10:25 AM   #61
Srubydo1986
The Crazy Machanic
its not a granny tranny is it.
newest additions
Old 04-29-2007, 04:29 PM   #62
OJOE
Crew Cut
OJOE's Avatar
hey just seen this thread, good luck. what are you going to use for a gas tank? the one in your swb will bolt on if you do the frame work like i did mine. i am going with a tank in bed. i read all the comments on the rust i was lucky and used a rust free cab here in alabama but have to be careful with all of the fried chicken grease on it ha ha good luck with your build
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 05-06-2007, 09:16 PM   #63
toomanytoyz
Luv the Crewcabs
Thanks for the Comment's, Plan to do the Frame work as u outlined on your Build. I would like to run a Tpi set-up in this Build also, Will probably use the Tank from the Part's Burb & put in a Higher Pressure Fuel Pump to run the Tpi system...........
Again Thank's for the Comment's & the Info on how u did your Frame Swap
Rick
Old 05-06-2007, 10:06 PM   #64
tyjoja
I'm wondering about the tranny also, is it stock? I've never heard of a 4 speed with overdrive. Is it granny in first. also liljon 285, I changed my shift column to a floor shift, and got a new smooth column piece from speedway parts. thanks bob
tyjoja is offline   Reply With Quote
Old 05-07-2007, 08:56 AM   #65
Texas Lefty
trans should a sm465 or "muncie"
Texas Lefty is offline   Reply With Quote
Old 05-07-2007, 03:07 PM   #66
kevinr1970
If it were the "granny" or compound-low tranny.
I had asked about a tranny like this a while back and got lots of good info, but can't seem to find it now.
I believe I was told it is an A35, or A435 or something like that.
IIRC, it was used in a lot of Chrysler product and in some late 70's to early 80's chev/GMC trucks. It was only used in the 1/2 tons and I think it was only used with 6 cylinders.
I think I got the most info in the drivetrain forum so you might check there
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-08-2007, 09:21 PM   #67
garysouthlake
'lox'
garysouthlake's Avatar
The vision you have of the completed project is terrific. A real one-of-a-kinder. I can't imagine the amount of work and patience it's going to take to complete the project and I salute your gumption..............
garysouthlake is offline   Reply With Quote
Old 05-30-2007, 10:43 PM   #68
kevinr1970
Hey OJOE (or anyone else that can answer this), I am interested in a crew-cab swb but would prefer to have a 4x4.
Doing the frame mod as you described sounds easy enough but I was wondering about doing something similar to the front end. I have access to an '85 2wd 3/4ton crew (bad tranny) and was wondering about sectioning in the front part of a 4x4 frame to make it a 4x4. Or more to the point, I have an '85 GMC 4x4 swb as a donor and was curious if I could more or less split the swb frame in the middle and section in the crew frame to fill the difference?
Would this be too much sectioning of the frame?
Any input would be great.
Thanks.
2000 Tahoe Limited
Old 05-31-2007, 12:49 AM   #69
BBC Beater
You are going to get a good lesson in metal working there! Better get a technis shot!
BBC Beater is offline   Reply With Quote
Old 05-31-2007, 03:30 AM   #70
GREASEMONKEY72
GREASEMONKEY72's Avatar
alot of progress in this thread, i love that 81 stepper, i dont know why exactly but i do...
cant wait to see more
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-01-2007, 04:13 PM   #71
toomanytoyz
Luv the Crewcabs
Thanks.
I think you would be better off to Convert the 2x Frame over to 4x4, Im no expert at this, but i think that would be the safest way to Go..........
Good Luck & Start a Build Thread when you have Decided which way to go.
Rick
Old 06-04-2007, 05:48 PM   #72
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
sounds like a great project...i have worked with rusty stuff before...im lucky now i live out west, so not so much if its been sitting for along time...if you lived closer i woul make and offer for the frome off the 81 stepside, i just want everything but the motor...would be great for what i want to do with my 68...cant wait to see more on this build..
billy
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 06-05-2007, 11:10 PM   #73
toomanytoyz
Luv the Crewcabs
Just Won this Blazer on Evil, Going to use the Running Gear on the Crew Build up, Will Part out what Im not gonna use............
http://cgi.ebay.com/ebaymotors/ws/eB...m=230136765012
Also have decided to use the 86 3/4 Ton Crew Cab that i have for the Cab, Now have all the Needed Part's, Will Try selling the Running gear off the Crew Cab...........
Thanks for all The Comment's, Rick
Old 06-10-2007, 10:31 PM   #74
toomanytoyz
Luv the Crewcabs
Got the Blazer Picked up, I think i now have all necessary Part's for the Conversion. The Blazer has 4" Lift, Like New Tire's, Warn Lockouts, 205 Transfer Case & Motor supposedly Rebuilt.................
Thanks, Rick
Old 06-10-2007, 10:38 PM   #75
1969k10stepside
Rick,your user name does tell the truth.You do have too many toys! Let me know if you want to get rid of that steering stabilizer on it,mine is gone.BTW,did you ever get to that junkyard to look at the K20?
1969k10stepside is offline   Reply With Quote
