Old 05-21-2007, 02:04 PM   #51
bigblock73
yeller
bigblock73's Avatar
Re: 6" front drop question
Ooooh man, am I furious!
I called STD, basically I am screwed because I installed the coils! No refund or exchange..he did offer me a discount on shocks...
This guy insist that the Western Chassis springs are rated/designed based on engine size. As an argument point from his side, he swears that my 1" Bell Tech (BT) springs are 1" springs for a small block, but they are 3" springs for a big block. I told him BT doesn't specify a difference based on engine size, he said "Yes they do"...but his "book" doesn't break it down that far.
My truck sat exactly the same, regardless of engine size...there is no way my truck sat 2" lower than it did just because I put in the big block.
He then tried to turn it around saying it was my fault I didn't tell him I had 1" BT springs from the get go...he said he could have figured out the correct spring for me based on that info. This coming from the same guy who insist my truck now sits 2" lower than it did once I put in the big block. I have pics to prove it doesn't!
So, moral of the story...DO NOT ORDER FROM SPORT TRUCK DIRECT! I have been burned by them twice, that's enough!
bigblock73 is offline   Reply With Quote
Old 05-21-2007, 02:25 PM   #52
jr2
jr2's Avatar
That blows Jeff!!!
I have found out many times now that ordering online or over the phone gives the companies an easy way out in almost everyway. Mainly because you are not stainding in front of them and threatening them with physical bodily harm! I feel for ya man!!
-John II
"A Little's Good! A Lot's Better! & Too Much is Just Right!!"
-1978 Chevy C10 Stepside 350/4sp/12 bolt
-1967 Nova 2dr HT & a couple others...
jr2 is offline   Reply With Quote
Old 05-21-2007, 03:07 PM   #53
ocbaud
Garage Queen Material
thanks for the heads up. no more ordering or sending orders their way.
ocbaud is offline   Reply With Quote
Old 05-21-2007, 04:33 PM   #54
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
That sucks Jeff........so what's the plan now????
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 05-21-2007, 05:08 PM   #55
jr2
jr2's Avatar
Hey maybe we could all chip in on the cost of a cutoff wheel for ya It only takes 1 or 2 to chop a set of springs.
-John II
Old 05-21-2007, 05:12 PM   #56
bigblock73
yeller
bigblock73's Avatar
LMAO!!
I already cut my BT coils last night, took off half a spring...did it with ONE cut off wheel too!!
I will put them in and see where I sit (no pun intended).
Old 05-21-2007, 05:31 PM   #57
jr2
jr2's Avatar
I TOTALLY feel for ya Jeff.. Been there before.. Chalk it up to experience.. The world just ain't the happy/friendly place it used to be.
-John II
Old 05-21-2007, 06:48 PM   #58
AirMale
AirMale's Avatar
I am reading this post late but just want to say if your springs don't seat correctly it won't show how much it trully has dropped. If the truck drives then take a spin around the block and make sure to bounce the front of the truck too. Good luck and where are the freakin pics?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 05-21-2007, 07:16 PM   #59
bigblock73
yeller
bigblock73's Avatar
Airmale, truck does not drive...but I have bounced the front up and down, and pushed it back and forth from the garage/driveway a couple times (while pushing up and down..challenging in itself).
I will get pics of the truck when I get the BT coils back in.
Old 05-21-2007, 07:57 PM   #60
swervin ervin
You get what you pay for
swervin ervin's Avatar
Jeff, if I had known you were about to order from Sport Truck Direct, I would have told you not to. They are a bunch of jerks and don't know their ass from a hole in the ground. Not but one place to order drop parts from as far as I'm concerned and that is Performance Suspension Components. They know what is what and won't lie you just to get out of something.
Hate to hear you got ripped. I had my dealings with them long ago and for sure won't go back.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-21-2007, 08:45 PM   #61
bigblock73
yeller
bigblock73's Avatar
Mike, my first order from them was my flip kit and c-notch. The flip kit came with the incorrect U-bolts (they were larger than my axle), and I was shorted two nuts for the bolt in c-notch. I called them and they said this stuff ships direct from the mfr, and since their 48 hour return policy passed, I was SOL.
I kind of believed them, that is was not entirely their fault...but I still felt they could have tried harder to keep a customer in me. Now I will make it my mission to inform everyone who has drop kit questions NOT to go thru STD!
Old 05-21-2007, 09:29 PM   #62
boatpuller
boatpuller's Avatar
Hey jeff,
If you can slide a fullsize jack under it it ain't low enough... This shot is before I added fluids and everything else for weight. This is 3" drop spindles and 3" drop springs.
BUT~ I do not have standard offset wheels either ( I think) 5" backspacing with 1.5" spacers (good ones not junkers) and 235x60x15 tires. It looks really good because it get's the wheel/tire package back out of the fenderwell.
Doesn't hit the inner fenders or the fender lip. The control arms are lower than the rim lip (which is lillegal but I didn't plan it that way) Hope it never gets a flat
you nailed the look jr...........i like it big time.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-21-2007, 09:31 PM   #63
boatpuller
boatpuller's Avatar
hang in there jeff.you'll get the stance.it gets frustrating when you gotta do everything 3 or 4 times.but hey,you'll be a spring install guru when your done.
Old 05-21-2007, 09:32 PM   #64
bigblock73
yeller
bigblock73's Avatar
That makes two of us! Niiiice!
Old 05-22-2007, 09:16 PM   #65
bigblock73
yeller
bigblock73's Avatar
OK, got the "3" inch coils springs back out and installed my old BT 1" coils minus 1/2 coil. Here are the best before shots I could get...it was raining out and getting dark, so the pics suck, but you get the idea. This is supposed to be a 6" drop.
Old 05-22-2007, 09:20 PM   #66
bigblock73
yeller
bigblock73's Avatar
Here are the after shots, again, I know they suck but mother nature was not cooperating. The drivers side sits about 1/2" higher than the passenger side...but the caster is off on this side (missing UCA shims), and I have not had a chance to push the truck back and forth any to see if it settles any more. I will push it outside tomorrow and get better pictures. I think it sits about perfect, but I may lose another 1/4" coil...might wait until the front end is completely installed and all fluids are in the engine before I do any more. BTW, took me 35 minutes from start to finish to install these coils back in the truck...bet I could do it in 30 if I have to do it again!!!
Old 05-23-2007, 12:41 AM   #67
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Jeff:
I emailed STD three times through their website with questions about the drop stuff I wanted to buy from them. They never responded. That right there told me I they don't believe in customer service, and that I didn't want to deal with them.
Good luck...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-23-2007, 02:28 AM   #68
dubdeuce80
dubdeuce80's Avatar
Hey jeff,
do you happen to have any pics from the side? i thought i had a 6" drop up front, but mine looked a little lower...
dubdeuce80 is offline   Reply With Quote
Old 05-23-2007, 12:35 PM   #69
jr2
jr2's Avatar
LOWER?? I didn't know you could go any lower than this without being a "Total Turtle Killer"? Let's see what I got here for a piucture for ya...Not the most flattering picture but it shows the height in the front. The second shows how low the control arms are.
And I know its low when I scrape off the high spots on my (pretty darned flat) gravel driveway The rim lips are actually higher than the control arms. I'll try to get a better head on shot tonight with it sittin in the shop on the slab.
-John II
Old 05-23-2007, 12:59 PM   #70
dubdeuce80
dubdeuce80's Avatar
hm...well i don't really have any good pics that don't have a ton of shadow under it. it might be the same, just my rear was lower so my eyes are playing tricks on me. heres a pic of my lowest static, like i said, a lot of shadow
Old 05-23-2007, 01:08 PM   #71
bigblock73
yeller
bigblock73's Avatar
Rear flip kit drops can be confusing...they are advertised at 5 inches...but if you have HD rear springs...it will be more. So a 5" drop on a LD truck, can be a 6" drop for a HD truck
Old 05-23-2007, 01:11 PM   #72
jr2
jr2's Avatar
[QUOTE=dubdeuce80;2187607]hm...well i don't really have any good pics that don't have a ton of shadow under it. it might be the same, just my rear was lower so my eyes are playing tricks on me. heres a pic of my lowest static, like i said, a lot of shadow
If you look at the center of your wheel you will see that it is pretty much in the same area as mine. I think you just have larger diameter tires so it creates an optical illusion. That and the rear being dropped lower than the front too.
-John II
Old 05-23-2007, 01:24 PM   #73
jr2
jr2's Avatar
You kow Jeff I am not actually sure what springs I do have in the back but I am pretty sure they are standard. The truck was a stocker C-10 no frills 3sp/column/6cyl truck. I have 3 leafs with what looks to be a factory overload under the stack. My rear is a flip kit with 2" blocks.
-John II
Old 05-23-2007, 01:30 PM   #74
bigblock73
yeller
bigblock73's Avatar
You suspension is the standard light duty setup (3+1), mine is like 6+1. Mine is flipped, no blocks, but 2" drop shackles. By the numbers your rear drop is 7, mine should be 8...but they sit about the same in the back. Just throwing my thoughts out there, as I am clearly no expert...STD is.
In your latest pic, it looks like your shock is not on all the way.
Old 05-23-2007, 03:36 PM   #75
benoit454
Chris
benoit454's Avatar
dubduece80,
what kinda drop you run front and rear? I love it!!!!!
I too wondered like alot of you guys if you could get like 2.5 plus drop spindles and springs, and combine them for like 5+inches of drop.
Then out back, flip kit with blocks like above, shackles, hangers, or lowering leafs, and combine thoose.
That stepside front end from the front sure looks low. I don't think I could go that low, I'd always hit the control arms. I love the look it has, but from the side it does seem higher then the front pic. Like I said, love it, but doubt I could run one that low.
Chris
GIT R DONE!!!!!!
Check out all our rides,
