12-10-2008, 03:13 AM | #1 |
VA72C10
Re: Lower A-arm ???
So compared to drop spindles, it still allows the bags to ride at their recommended height (6-7) or is it for those w/out drop spindles?
Looking for a 67-72 swb or blazer project in or around VA. |
12-10-2008, 03:42 AM | #2 | |
Texas Big Wig
Re: Lower A-arm ???
What it does is allow you to ride lower with the bag at the same height So if you had normal LCAs with the spacer cups & rode with the bags at 6-7" tall then your truck would sit up pretty high But with these it will let the truck set roughly 2-3" lower & the bags be at the same 6-7" height |
12-10-2008, 12:46 PM | #3 | |
VA72C10
Re: Lower A-arm ???
What would be the ride height difference of a truck w/ bags, stock spindles, and these cut out (lowered) A-arms Vs A truck w/ bags, 2 1/2" lowering spindles, and cut out (lowered) A-arms vs A truck w/ bags, 2 1/2" lowering spindles, and stock A-arms? vs A truck w/ bags, stock spindles, and stock A-arms? The way I am reading everything, If we assume zero for the bottom example (bags w/ stock spindles and arms), the ride height could be 2 1/2" lower with the drop spindles and stock a-arms. But here's where I get confused....since i read that you will hit the crossmember before you get 3" of drop with the cut a-arms, wouldn't you RIDE at the same height with either only drop spindles OR the drop A-arms since you could only get about 2 1/2 drop before hitting the crossmember and couldn't ride w/ the arm resting on the crossmember? With BOTH the drop spindles AND the drop arms, do you get a total of 5" drop at RIDE height or just at dump height? I'm a noob at this, but trying to figure it out. I would like to do all my suspension once of course so before buying lower cups (cut to 1") and upper plates, installing them, and not being happy, I'd like to see if i need to/Want to do this to have the ride height I'm looking for. THe other question would be: If i do this, would I have to do some sort of notch (OR Z) to get the ride height in the rear to be level, or since I will be aired up a certain amount to clear the stock inner fenders and stock steel bedfloor, it is really a moot point? I don't plan on laying rocker or frame...just want to tuck the tires slightly when at a show and drive with it as low as possible with full turn capabilities (not worried about dragging anything including my full length headers) Thanks for all the info so far and for any additional info you can provide.
12-10-2008, 03:31 AM | #4 | |
Re: Lower A-arm ???
12-10-2008, 03:45 AM | #5 | |
Texas Big Wig
Re: Lower A-arm ???
But with this mod it will lay the LCAs on the ground (you will need shorter shocks) & at that point spindles will just allow you to ride lower by the amount of drop in the spindles... Such as 2-1/2" lower if you had 2.5" drop spindles (same theory as with springs, the spindles do the same thing here) And at dump you wont have as much camber |
12-10-2008, 04:08 AM | #6 |
Re: Lower A-arm ???
Well if your LCA are on the ground, that sounds like more of a drop than I've seen with cut cups! Do you have any other front suspension mods besides bags/spindles?
12-10-2008, 05:36 AM | #8 |
Re: Lower A-arm ???
12-10-2008, 12:21 PM | #9 |
Texas Big Wig
Re: Lower A-arm ???
Well you can always go lower, I just chose not to because I didnt want all the extra work
Its as low as you can go without: Crossmember mods or different crossmember, front Z, body drop, stuff like that As low as it is you have plenty of clearance issues, cant run stock inner fenders, heater box clearance, hood hinge clearance, & inside of fender clearance You can always do more work & get it to lay frame if you wanted In the rear, Im not a big fan of notches (nothing wrong with them, just dont like em) so thats why I went with a Z instead of a step notch I only did a 6-3/16" Z (thats the height of the frame) & my truck lays out pretty level, so I have no need for a bigger Z on this truck |
12-10-2008, 01:32 PM | #10 |
Texas Big Wig
Re: Lower A-arm ???
Ok Ima try to filter through all that
I will get a picture of my truck at ride height today, so you can see what one looks like with the LCA mods & 2.5" drop spindles This truck has 2" drop spindles I dont think I have a pic of the last version The reason for the mod is to let your bags run at close to the optimal height recommended my the manufacturer & your truck sit lower than if you had stock LCAs with spacer cups You are correct in that the drop spindles offer drop at ride height IN ADDITION TO the drop you get from the LCA mod But the drop spindle wont really let it lay much/any lower In the rear, yes you would need to do one or the other to ride as low as the front Here is the truck that my front set up used to be under, it is close to ride height in the front & laying the frame on the axle in the back So you would need at least a 5" notch or Z in the back so you could have travel & not be bottoming out all the time In order to ride as low as the black truck (which doesnt even have drop spindles) You cant run your stock inner fenders, so you either need to mod them / build new ones or quit kidding yourself about running that low With out the drop spindles there is roughly 1.5" of gap between the top of the tire (tires are 28" tall) & the fender opening And on my other truck with the drop spindles, it is tucking roughly 1" of tire So if you were to try to run that low with stock inner fenders, you would be scrubbing your tires on them a lot (I have tried it) In the rear, you cant even do a very big C-notch without cutting a hole in your floor for the top of the axle to poke through, so doing a Z or a step notch would mean modifying your bed floor in some shape form or fashion If you dont wanna start cutting things, get riding low out of your head & stick to trucks that ride at this height Sorry if I came across as a jerk there Last edited by Spray-Bomb; 12-10-2008 at 01:34 PM. |
12-10-2008, 01:45 PM | #11 |
VA72C10
Re: Lower A-arm ???
I appreciate all the info and suggestions. My ideal ride height is the red truck. I really don't care about ridin low, just want to lower it at shows and not even much lower than that in all honesty. What then would I need to accomplish riding at the red truck height. Would simply bags, 2 1/2" spindles, cut cups (not a-arms) in the front and bags only in the rear get me there or would I have to c-notch the rear? I do not want to mod my bed at all but I guess I could use lowering blocks and the c-notch to keep the pumpkin out of the bed....but do I need the notch to go that low? Again, the red truck is pretty much a perfect ride height for me personally.
12-10-2008, 04:39 PM | #12 |
Texas Big Wig
Re: Lower A-arm ???
Go read the thread below & if you dont find the answer, then ask the owner of the truck what all he did & you should be good
http://67-72chevytrucks.com/vboard/s...d.php?t=317533 |
12-10-2008, 05:40 PM | #13 |
VA72C10
Re: Lower A-arm ???
Thanks, thought that was C10Addict's truck. Thanks again for all the info!
