12-11-2010, 09:35 PM | #51 |
BLAZER THIRTY!!
Re: Jeep Coil Spring Drop
NO! I installed mine and it dropped it 5 inch's but if i stand in the bed it hit's the bump stops and i weigh 340 , but rides nice and looks awesome,i don't haul with it , Matt
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
12-12-2010, 12:16 AM | #52 |
so I guess picking up a load of alfalfa an hour from home is out of the question
12-12-2010, 01:34 AM | #53 |
Grandpa in the rustmobile...
haha unless ya wana ride bumpstops!
stock front jeep springs rear
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-18-2011, 01:24 AM | #54 |
Just wanted to add a note to this thread about the rear Jeep TJ/LJ springs.
There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate. The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows: 103AA (or 3AA) 130lb. 104AA (or 4AA) 140lb. 105AA (or 5AA) 150lb. 106AA (or 6AA) 160lb. The colors on the tags can vary and the rates are "ball park" at best. |
02-18-2011, 09:01 AM | #55 |
Hmm
Good info.
02-18-2011, 12:06 PM | #56 |
02-18-2011, 12:14 PM | #57 |
Who Me?
The ride is real rough with cut springs. I did that once too.
This Jeep spring mod looks like something to do in the near future. What is used to hold them in place? I have cut coils welded in the rear now from the PO. The ride is not too bad in the rear, but would like it smoother.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-19-2011, 11:27 AM | #58 | |
and a few others
a newer pic of the same truck....
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
02-19-2011, 11:47 AM | #59 |
Are chevelle springs any 'stronger/thicker' than jeep springs? (I like the drop of the jeep springs but not the hauling capacity).
http://67-72chevytrucks.com/vboard/s...d.php?t=437582 Shock relocators on the cheap too...
02-19-2011, 12:56 PM | #60 |
That looks awesome... I see the stock springs for the Chevelle can be had on RockAuto for about $55-65. How does it ride? Bottom out like crazy? Did you relocate your shocks? How is the front lowered, if you don't mind me asking. |
02-19-2011, 01:41 PM | #61 | |
and a few others
On the front, I cut 1.5 coils and cut off the bump stops on the LCA's. I sold that truck about a year ago, but I wouldn't recommend the coil cuts that much just because it puts the LCA's too close to the ground. If you're considering cutting coils, read this first.... http://webrodder.com/article.php?AID=582&SID=16
02-19-2011, 03:51 PM | #62 |
so in english.... what do i need to drop the front 2 inches without cutting.
02-19-2011, 07:51 PM | #63 |
Drop spindles, 'lowered' coil springs, air bags
cut 1 coil off and you'll be fine
02-19-2011, 09:02 PM | #64 |
SSN 706
jeep spring in the rear and a c notch. Put 7 sheets of 3/4" plywood in there today. Rode sweet no bump. Front coils cut about 2 removed the bumps and the brackets.
02-19-2011, 09:49 PM | #65 |
Can you add air bags inside the springs to help carry the load. Just like air shocks of yesteryear? Set up the same way.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
07-02-2015, 10:29 PM | #66 |
New guy here:
Are you guys using stock shocks ? with jeep rear springs and cutting off 1 coil on the front coil spring Thanks Paw |
