#51 |
Re: Damn...Motor Just Blew! Need Advice!
.045 is correct for HEI gap.
10 degrees is a good starting point, but you'll want tune initial/advance (see my .sig ![]() The two sets of holes in the carb are for different manifold types - you just need 4 studs/bolts, typically the inner set. |
#52 |
Zombie Killer
Thanks ya'll...you guys have been a life saver! More pics shortly...
1964 C10 Long Step |
#53 |
Zombie Killer
#54 |
64-66 CHEVY JUNKIE
Looking good sixty four, thats a nice rig u got there. Anyway i would like to know if you still have the blowed out motor? I could come pick it up im just up the road in baytown i-10. Thanks and pm me i may have some parts that you need.[IMG]
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
#55 |
Zombie Killer
I just decoded the numbers on the blown motor (14010207) and according to this site it came out of a 80 to 85 Vette and it's a 350cid. Not sure if it's a 2 or 4 bolt main? All I can say is Wow! I really thought it was a 305. Sure didn't feel like a vette!
![]() http://www.chevy-camaro.com/chevy-ca...es.asp?group=6 Anyway, parts I was expecting today didn't show so not much going on here with the new motor.
#56 |
Zombie Killer
Hmmm...this site says 4 bolt main and came out of a truck?
http://www.hotrodsforsale.com/hrfs/t...lock_chevy.htm
#57 |
Try Mortec.com for the numbers.
#58 |
Zombie Killer
Here we go, some more parts came in today. Motor mount brackets, hi-flow water pump, water neck, Center Force clutch, pressure plate and release bearing. Good news, I found the hood bolt I misplaced, bad news I can't find one of the exhaust bolts. Was able to bolt up the water pump and accessories. Tomorrow hope to do the flywheel, clutch set up, motor mounts, fuel pump. Then maybe I can stab the motor.
![]() ![]() ![]() Camera freaked out in this pic... ![]()
#59 |
Zombie Killer
After looking at the mounts a little more tonight it's become obvious they sent me the wrong parts. These will not work together. I'm itching to get back on the road so I'll probably use my old mounts and upgrade later.
#60 |
Zombie Killer
1964 C10 Long Step Last edited by sixtyfour; 12-30-2007 at 08:36 PM. |
#61 |
Thats some nice parts! Motor is looking sweet!!
#62 |
![]() Join Date: Sep 2006
These are the ones you need. They are for stock perches.
http://store.summitracing.com/partde...5&autoview=sku
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 12-31-2007 at 06:23 AM. |
#63 |
Zombie Killer
Taking a break for a minute to post, then off to make the plug wires. Motor won't be going in tonight but probably Sunday.
Question, I've read where I need to prime the oil pump using a drill. What attachment do you use on the drill, I'm guessing this is a special tool or something? New belts are on but loose until I put the fan on. Waiting till after motor is installed for this. ![]() ![]() ![]()
1964 C10 Long Step Last edited by sixtyfour; 12-31-2007 at 06:51 PM. |
#64 |
you can get an oil primer at any parts store
#65 |
Zombie Killer
Thanks, I will pick one up tomorrow along with some plug wires. Turns out the plug wires I have from an old motorcycle project were the wrong size. The rubber caps were to big to go over these plugs...
Edelbrock fuel pump installed. ![]() I went to screw on my new oil filter and found theres nothing to screw too!! I assume there is something I need to un-bolt from my old motor? There have been alot of things I've over looked being my first V8 install. Done plenty of VW motors, motorcycles, and a straight six in my jeep. I'd be lost without your help! Thanks! Oil Filter Mount? ![]()
1964 C10 Long Step Last edited by sixtyfour; 12-31-2007 at 06:35 PM. |
#66 |
Right turn Clyde
You need an oil filter adapter. If you have an old sbc distributor. You can make a much better oil pump primer.
#67 | |
Zombie Killer
Should there be a oring where the dipstick meets the block? ![]() ![]() I drove this dipstick plug only halfway in in-case it ever needs to be removed later. Is this alright or should it be driven all the way in? Seems pretty tight in there now. ![]()
#68 |
Just pull the oil filter adapter off your old engine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#69 |
Hey Y'all!!
#70 |
Zombie Killer
Will do on the oil filter adapter.
#71 |
Right turn Clyde
Wouldnt it be better to have a new stiffer bypass spring than an old one?
http://67-72chevytrucks.com/vboard/s...d.php?t=238758 I have mine out on loan or I could post pictures. |
#72 |
[QUOTE=MylilBowTie;2507601]Wouldnt it be better to have a new stiffer bypass spring than an old one?
I would have to say that it depends on the new oil pump pressure and volume and what filter is being used. All stock? dirty oil bypassing the filter is much better than no oil because of plugged up filter and too stiff of a bypass spring. |
#73 |
Right turn Clyde
I would much rather have filtered oil. Id rather not have the metal slivers and dust circulating in the system. Breaking in a new engine you should keep an eye on your gauges. Mainly oil pressure and water temp. Guess my thinking is with a weak bypass spring, it would be next to not running an oil filter. Wix (#51794) has a two quart oil filter that should be plenty big enough to not worry about oil starvation.
I run an adapter plate that doesn't have a pressure bypass valve. Haven't had any problems out of it. I also use good oil filters along with that oil filter adapter. |
#74 |
Zombie Killer
Well, no motor install today. Went to install the release bearing and it turns out it was wrong. Walked up to the auto parts and they had a "Made in China" release bearing...I passed. Had them order me a quality one which should be here Monday. They didn't have the oil pump primer either. I'll try and make one out of my old distributor here in a minute. Only thing I've accomplished today was pulling the oil filter adapter from the old motor and making plug wires.
#75 |
64-66 CHEVY JUNKIE
LOOKING GOOD 64 keep use posted and plenty of pics
