06-02-2008, 05:13 AM | #51 |
Re: No Regrets - The Rebuild post
thanks youre awesome!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
06-04-2008, 01:35 PM | #52 |
It'd be alot cooler if you did
snapped a few more pics today... almost ready for a guide coat. Next step is to close up the gaps on the hood.
06-05-2008, 07:43 PM | #53 |
Until Seventy Times Seven
It's looking really good. I can almost smell the fresh paint to come. You need to send your paint and body man out this way. Always looking for a pro'.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
06-05-2008, 08:17 PM | #54 |
Fix It Till It's Broke
Wow truck's looking good Chuck. I'm not even usually a fan of dropped trucks but damn! that's all I have to say. Good job!
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
06-08-2008, 06:58 PM | #55 |
Spent half the day today messing with the belt set up. I was actually able to retain all my old pulleys, rendering the two sets I got at the pick and pull useless. It is becoming a little more clear that the air cleaner probably isn't going to work with this set up.
Sooo, with a little grinding and fitting, the new brackets worked ok, and all the pulleys lined up like they should. Still need to get the next size belt for the compressor, but three trips to the parts store was enough for me today. I'm thinking of adding a tensioner between the crank and the Sanden, but after going through all the boxes at the parts store I couldn't find one I liked, so I'll see how it works without one. Now as far as the engine accessories go, All there is to do is some final fit and finish work, rehab the York and the power steering pump, and the motor is ready to go in! |
06-08-2008, 09:29 PM | #56 |
looks good. too bad about the air cleaner, tho. i liked it's uniqueness.
It's peanut butter jelly time. '74 GMC 3/4 TON 2WD LB |
06-09-2008, 02:42 AM | #57 |
Why are your belts white!
06-13-2008, 01:24 AM | #58 |
hood gaps are all set. Widened the hood by about 1/2 inch.
06-17-2008, 09:25 PM | #59 |
why did you have to widen the hood? did the fenders change profile when you made the inners?
06-17-2008, 11:42 PM | #60 | |
At any rate, the gaps between the hood and the fenders was too big. It's not now. |
06-20-2008, 08:49 PM | #61 |
got it. lookin really tight so far. when are you rollin in to paint?
06-27-2008, 03:15 AM | #62 |
stopped by the shop the other day to snag some progress pics. 6 coats of primer have been laid down, and the truck will be coming home to my shop after the firewall has fresh black paint on it!!! After that it's time for me to clean up and detail the frame, slide the motor in, and back to the body shop for final blocking, painting and wet sanding. I can't wait. I should have it home by Sunday!!!
06-27-2008, 12:41 PM | #63 |
Looks awesome , I should post some pics of my build . I thought you Z'ed your frame ?
1970 Gmc6500 1951 chevy gasser 1986 crew cab dually 1956 Gmc extended soon to be ? |
06-27-2008, 12:43 PM | #64 |
no need... I raised the crossmember years ago. |
06-29-2008, 03:52 PM | #65 |
It's home for the time being. Now it's time for me to tear into it and clean and repaint the frame, mount the air tanks, fuel cell, run the exhaust, rebuild the transmission crossmember, and drop in the motor and transmission. I'm going to take my time on it.
The firewall is painted and cleared, and the interior has the base coat on it for the time being. For frame paint I ordered chassis black from Eastwood. Also notice the gap between the cab and the bed... it has been closed in by about 3/4 of an inch so you can't see through it. Last edited by smashingchuck; 06-29-2008 at 04:45 PM. |
06-29-2008, 07:24 PM | #66 |
a few more... one with the boy checking out the lines. He'll go to a car show and tell me out loud when a car isn't straight; right in front of the owner. Kinda funny.
06-29-2008, 09:50 PM | #67 |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
06-29-2008, 10:41 PM | #69 |
17x8 with 4.5 backspacing. 225 50 in front 255 50 Nitto 555 in the rear. Wheel Vintiques. I won't be using them this time around. I barely have any pictures on the computer of them at all, and now they are stacked in my basement with fresh gloss red base coat/clear coat on them.
07-01-2008, 08:36 PM | #70 |
lookin really good. i'm surprised to see your tail lights installed before paint. i figured you'd install them on final assembly or are they in so you can drive it to the shop?
07-01-2008, 09:14 PM | #71 |
SWEET
07-01-2008, 11:48 PM | #72 |
they are super easy to bolt in to place. they are the only thing on the truck right now with a wire one them... in other words, they aren't functional yet.
07-02-2008, 11:02 AM | #73 |
got the wheels on for a test fit...
07-02-2008, 12:14 PM | #74 |
67-72 parts collector,…
Love the wheels! Looks like a different truck. Who/where did you order your wheels from?
07-02-2008, 12:14 PM | #75 |
yeller
These new wheels MADE the truck...NICE!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
