Re: my 80 build
looks good. how much drop will you have in the front with the new springs
6.0 powered square
Re: my 80 build
thanks 1984, it should be a 6" drop, It has djm 3" spindles and 2" coils but it only turned out to be a 4" drop
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
6.0 powered square
Re: my 80 build
Yesterday I got the gauges wired up on cluster, would of got the indicator, and dash lights wired up and that would of been done, but my parts from summit came so had to look at them and installed the water pump pulley and the window crank handles would installed the crank pulley but it looks like I have to get shorter belts, and a guy came over to buy a few parts and he admired my truck for about hour,
6.0 powered square
Re: my 80 build
Ive done a few things on my in the past couple of days made some kick panels out of some galvanized steel, wired up a 12 volt outlet and installed three inch drop springs, and the top of the wheel well measures 24 3/4 inches before I started it was about 27 inches, I'll take pics tomorrow
6.0 powered square
Re: my 80 build
before
![]() after ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 01-26-2009 at 02:41 PM. |
Re: my 80 build
Looks great flamingbig10!!! Those couple extra inches taken away made a big difference in the stance. Joe
6.0 powered square
Re: my 80 build
thanks, the coils helped the appearance a bunch, it looked kinda goofy before
6.0 powered square
Re: my 80 build
thanks slugish
6.0 powered square
Re: my 80 build
Ive done a few things to my truck in past couple of weeks wired up my factory wiper motor to a universal wiper switch only work on low and low might be a loose ground or I need to spray some lubricant on the mechanics, I wired up my heater blows air out good now to decide about how I'm going to route the heater hoses, and took a few pics of what the inside looks of now, and a few more
my dirt cheap seat I got at the junk yard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Re: my 80 build
Wow! Only 18! I am 23 and haven't done near as much as you have. Looks good! I especially like your dash. Its similar to what I want to do
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350 1.83 60' 13.14 @ 100 on motor 1.49 60' 11.52 @ 116 w/150 shot 1952 Chevy truck project 1980 Z28 Camaro 1967 Camaro drag car 10.60@126 |
6.0 powered square
Re: my 80 build
thanks 85, I used the factory pieces as templet, a lot people don't believe that how young I am that I built my truck
![]() Join Date: Jul 2007
Re: my 80 build
Truck looks great! keep up the good work!
#13 |
6.0 powered square
Re: my 80 build
Thanks Alex, today I used Mothers California Gold® Clay Bar System, what A difference it made the finish hasn't looked this good in over two years, now I need to use the 3 step Ultimate Wax System
#14 |
Re: my 80 build
Nice! I like the interior trim, good job.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#15 |
6.0 powered square
Re: my 80 build
thanks silvereagle
#16 |
6.0 powered square
Re: my 80 build
I figured out why my wipers would only work on slow had a bad ground, I was Tired of hiting my knee on my radio so I moved it where the factory a/c controls, then I drove my truck it was a liitle ocword with the shifter lever, so I decided to leave it alone, until I know what I really want. I was given a 89-91 bezel that I used since past owner messed up the metal dash were the radio was since I didn't notice it when my truck was getting body work, I mad a piece of diamond plate that covered up the radio opening just didn't take any pics
this was before it was tightened down ![]() also took a bunch of pics of my heater under the dash http://store.summitracing.com/partde...5&autoview=sku ![]() ![]() ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-03-2009 at 12:24 AM. |
#17 |
![]() Join Date: Jul 2010
Re: my 80 build
[QUOTE=flamingbig10;3176776]
![]() ![]() QUOTE] Does that heater put out good heat ? |
#18 |
6.0 powered square
Re: my 80 build
[quote=Pop's C-10;4424920]It did blow ok, but I only had it ducted to blow on the window for defrost
I got the trans bolted to the motor tonight
#19 |
Re: my 80 build
It can't be any worse than the original heater!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#20 |
6.0 powered square
Re: my 80 build
And some outside pics
#21 |
6.0 powered square
Re: my 80 build
#22 |
6.0 powered square
Re: my 80 build
#23 |
6.0 powered square
Re: my 80 build
I decided how I'm going to use my tax refund, first a front end aliment,
and maybe some of this stuff http://store.summitracing.com/partde...art=CAL-198195 http://store.summitracing.com/partde...art=SUM-811004 http://store.summitracing.com/partde...part=SUM-G1198 http://store.summitracing.com/partde...part=SUM-G1201
#24 |
Happy to be here
![]() Join Date: Mar 2000
Re: my 80 build
Awesome work. Would it be possible to update some of the old pics that aren't showing up?
#25 |
Low & Fast!
Re: my 80 build
Nice pics!
![]() Good luck with the upgrades and keep us posted!
