Re: 1971 3/4 swap to 1/2 ton
Also you will not have a nice alignment unless you get the drop spindles or shim it out. I personally dont care about that though since it still drives straight and I dont drive it enough to wear out the tires.
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster |
Nice truck, and good call on keeping the D-60. Nobody mentioned to you that if you swapped in a 12 bolt, your drive shaft would have been too short by 1.75". The slip joint would/could pop apart.
Again, nice truck.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
What do you mean shim it out? Is it something I need to do when I put the coil springs in? I planned on doing it this weekend.
Barrito Loco Diablo
Charles..... Man oh man.... Your stance is leaving me speechless.
I have a 72' GMC 3/4 ton and have been stuck on whether or not to convert over to 5 lug.... I want to lower it and i can't afford bags. It's crazy cuz' your truck looks just like mine only beautifully budget slammed and primer gray. I painted wide whites on mine about a month ago and get about the same reaction you probably are except yours looks so damn sweet sitting that low.... Does your front tires rub at all when turning? |
