Old 08-26-2008, 10:22 AM   #51
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Something I've been working on...
Yeah man, any updates ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-23-2008, 02:09 PM   #52
71/454
Turbo Guy
71/454's Avatar
Sorry I haven't updated in a while. I have been working around the house and at my sister's place a bunch. I have been able to find time to do some test and tune sessions.
I went back to an unlocked distributor, meaning not welded weights. I just backed the initial way up so that I only get 22 degrees total, this helps with driveablility. I also put a vac advance on it for the cruise to try and help with gas mileage,yeah right!
I seem to have the jetting pretty close, maybe one size too much on the front an back because it works the best when it is cooler at night than during the day. Front jets are 66 and the rears are 69.
Funny things I have found. I had read that the 1/4 inch ready rod that I was using to hold the carb hat on was not strong enough, another website with lots of turbo info, and everyone seemed to believe this sort of thing, recomended is drilling and tapping for a 5/16 bolt. I did have what seemed to be a small fuel leak between the hat and carb which seemed wierd until I figured out it was just excess spray from the shooters being blown around by the turbulence under the hat. I thought the leak was just a bad gasket so I replaced it and while I was there I used a grade 5 bolt instead of rod. I ended up with more power at the top end, sometimes breaking the tires loose close to the redline in first and second gear. And then I ended up having to up the jets 2 sizes on the primary. Altogether a fun experiment, problem is now I'm hooked and need more power.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 09-23-2008, 05:19 PM   #53
heavy71chevy
heavy71chevy's Avatar
Man...that is pretty badass...Looks like it be fun as hell to drive to lol
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 09-23-2008, 05:59 PM   #54
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
subscribing, waiting to see the video
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 09-23-2008, 08:04 PM   #55
69chevytruckin
Nothing to say that is beyond crazy!!!!!!!!!!!!!!!!
[Dont Trasem' Restorm
69chevytruckin is offline   Reply With Quote
Old 09-23-2008, 09:08 PM   #56
71/454
Turbo Guy
71/454's Avatar
I should add that it is not a vette killer by any means. It's a stock 170 horse 305 so to get it to come alive, trust me we're overcoming alot. It is still pretty quick, and when the boost comes on you sure know it. I always get some ricer who wants to race, but usually the one who put all his money into neon tubes and bondo rather than engine. I was toying around with a G35 coupe that seemed to be working hard to keep up but I think he was playing, that car should wup me.
I have some bad video from inside, but it's at night and shows really nothing (I prefer breaking the law in excessat night when I can see the lights) . I guess I'll have to get some before the snow flies
12 bolt diff
Old 09-23-2008, 09:14 PM   #57
straitnate14
straitnate14's Avatar
So how long would you say you have been driving it like this? I'm realy curious to see how long it will last and if I should jump pullies on my blower to pick up a little more boost, Oh and by the way I just put the wideband air/fuel meter in made by NGK in my truck and it's super easy to do and only cost $300 but it only does one bank unless you want to move it from side to side.
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 09-26-2008, 08:12 PM   #58
'68 C-20
'68 C-20's Avatar
Nice Job, It never ceases to amaze me the talent of folks on this board!
Question if you will, what is the paint code on the truck?
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-12-2008, 03:48 PM   #59
71/454
Turbo Guy
71/454's Avatar
straitnate14 I have had it running for a few months now and it is still going strong. All it does it get taken out and beat on and put away before the cops show up, kinda like when I used to have a crotch rocket. I am surprised a stock bottom end has taken this abuse. I keep up on my tune, never letting it get too lean and almost never let it detonate, almost...
I have an AEM wideband on the pillar along with a autometer boost gauge, kinda like a ricer but it's easy to see at speed
68-c20 I don't know the paint code the truck was this colour when I bought it.
I'm going to try to get some video tomorrow as I think this will be my last chance before it goes into the garage for a nap for winter, well that and more motor
12 bolt diff
Old 10-13-2008, 11:11 PM   #60
71/454
Turbo Guy
71/454's Avatar
Ok, I'm dumb. I took the camera out and didn't notice the battery was almost dead, so I got one crappy video from inside the cab. I took my neighbour for his first ride in it, there's a little bad language at the end, he was a bit surprised. The wife says that if it stays nice she's willing to stand in the ditch and tape it while I run it thru the gears so we can see what it sounds like outside, she must love me?
I hope this works, and hopefully more on the way
http://s120.photobucket.com/albums/o...t=MOV00459.flv
12 bolt diff
Old 10-14-2008, 05:34 AM   #61
rod86
great southern land
rod86's Avatar
dude that sounds awsome... cant wait to see more video...
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 10-14-2008, 09:31 AM   #62
72BLUZ
72BLUZ's Avatar
looks interesting
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 10-14-2008, 05:16 PM   #63
Riveted1
Tasty Cakes!
Riveted1's Avatar
MORE! MORE!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 10-14-2008, 10:35 PM   #64
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
i think im in love
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 10-15-2008, 11:08 AM   #65
noteron
noteron's Avatar
Right on!
noteron is offline   Reply With Quote
Old 10-15-2008, 03:19 PM   #66
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Love that boost noise. Very cool
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 11-09-2008, 04:09 PM   #67
98turbls1
Got any more detailed pics?? I want more vid!!! haha.. looking good man..
98turbls1 is offline   Reply With Quote
Old 05-15-2009, 09:35 AM   #68
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
any new updates!? still watching this lol, im looking into a single turbo setup on my bored 305 (310)
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 03-01-2010, 12:35 AM   #69
71/454
Turbo Guy
71/454's Avatar
Sorry I haven't updated in a long while. I don't even remember where I left off. Surprisingly the 305 lived the whole time and when I took it out in the fall of 08, it still ran fine. Like anything else I wanted more power, so I tossed in the 327! I did regasket most of it but I decided not to pull the heads so I didn't find out what the pistons were, I'm guessing just flat tops. If they are, then with the 64 cc heads that makes it around 10.5-1. I installed an intercooler and got a proper carb hat from extreme velocity. Now I run 12 lbs of boost with 22" total timing. I makes enough power that you can safely put a $50 bill on the dash an offer your passenger that he can keep it if he can reach it, noone's gotten money yet.
Things I've learned, boost is hard on stuff.
- When I opened the diff to put in the lock right I found the cross pin bolt snapped and the cross pin had a twist in it.
-I broke the lock rite, this thing does hook surprisingly well!
- I blew the saginaw up, literally gears broken into pieces and shafts garbage, that seemed to happen after I put the posi in and it hooked finally.
- I pulled the saginaw and to my surprise the newly turned flywheel was blue, the clutch was slipping pretty bad under full power, It didn't have a 1000 miles on it.
- I put in a super t10 I had that was used with a brand new centreforce clutch. The good news is that the clutch works great now, I can break the tires loose at 75mph in 3rd, the bad nes is that the super t10 lasted about 25 min of hard abuse before the bearings went out.
12 bolt diff
Old 03-01-2010, 12:42 AM   #70
71/454
Turbo Guy
71/454's Avatar
Where I'm at with it this winter.
I got a pile of 9 inch stuff for free, including a posi so I'm going to run that, plus it has a very favorable gear for me, 3.50.
I came very close to getting a 700r4 but found alot of people were very resistant to use this behind something twin turbo. I am now doing a 4l80e swap with an electric manual valvebody from rossler trans and a pile of transgo parts to make it work behind this setup. I'll post some pics but it'll be a few days.
12 bolt diff
Old 03-10-2010, 01:58 AM   #71
71/454
Turbo Guy
71/454's Avatar
I've got the truck all the way against the wall and right up to the door. I'll have to open the door to get some better shots of the intercooler and piping.
12 bolt diff
Old 03-10-2010, 02:45 AM   #72
tomtuna1978
what is that can above the watter pump that has the 2 hoses to the 2 turbos and the 1 hose attached to the valve cover breather ? btw .... this is aussome !!!! keep us all updated !!! i wanna do this but with a big block
tomtuna1978 is offline   Reply With Quote
Old 03-10-2010, 01:50 PM   #73
71/454
Turbo Guy
71/454's Avatar
its part of a push pull system that is the crank case evac for when it is under boost. The can is the oil separator. The intake on the turbo provides the vacuum to evac the crankcase while the engine is under boost. The other engine I ran had some oil come thru and you don't want it to get sucked into the turbo intake. I may take it off as this engine has no blow by
12 bolt diff
Old 03-10-2010, 02:53 PM   #74
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
WOW!
Very cool setup.
Keep the updates coming!!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-10-2010, 04:08 PM   #75
splehigh
splehigh's Avatar
Sweet! subscribed
splehigh is offline   Reply With Quote
