Old 02-08-2009, 11:52 AM   #51
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: 69 cst-10
Bummer, man. You know you're gonna kick yourself in the a if you get rid of it.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 02-08-2009, 12:58 PM   #52
67BBC
67BBC's Avatar
Re: 69 cst-10
I have been close to doing the same thing with my 67. I held out and got lucky, It took me to long to find one in the condition mine was in, barn find. Here is a couple of pics of mine, all original metal in cab, I haven't worked on it in almost a year, job keeps me on the road too much. I hope everything works out for you, looks like you have done a lot of good work to your project.
72 SNB Drag truck
67 Project (Sold)
85 4x4
11 Z71
67BBC is offline   Reply With Quote
Old 09-29-2009, 10:21 PM   #53
ripdog28
ripdog28's Avatar
Talking Re: 69 cst-10
So holding out on selling it worked. My military time will pay for this build seeing as im going back to school for the MGI bill. I have a set of BFG drag radial 315/60R15 coming in tomorrow. Will get mounted and move the truck to my garage finally. get the Painless wireing harness #10206 installed. get the Hooker comp headers order, along with the Wiend G water pump, MSD or Milloy 6al, some hoses, and a IED driveshaft all ordered. Will be seeing some progress after about a 8 month rest. I am not worried about the body right now, will look like **** (some good paint scrapes) for a while but will be eating some RICE burners looking like that. I love the pump you get when seeing it come together.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 09-30-2009, 02:09 AM   #54
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: 69 cst-10
Congrats, Man! Glad to see you're going to get back at 'er.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 09-30-2009, 07:15 PM   #55
ripdog28
ripdog28's Avatar
Re: 69 cst-10
got the rear tires on. they are taller then i thought but will work, maby after she is running and has some miles on it i will get some nice 18-20 inch rims on it. but for now, these will be doing the hooking(er: ). I really need to get it cleaned up, sitting for so long got it dirty. Ill wash it while moving it to my garage. I have another set of rims, 10x15 2in backspace. maby put some regular BFG like the front so it dont look like it has much under it,
69 c-10 BBC
Old 10-06-2009, 12:01 AM   #56
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I got the truck moved from my friends house to mine. borrowed a trailer from a co worker. After putting the bed on, i like the way it sits and the way the tires are in the wells. I amy drop it a little more but not to much, will see once everything is on it.
69 c-10 BBC
Old 10-07-2009, 02:57 AM   #57
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Once the tires were on, i noticed the pass side rear frame rail was about 1 1/2 inches closer to the tire then the Driver side. adjusted the springs cause they are still a little lose and i still have an inch to work out. When i welded the trailing arm perches on it was all centered. Im not sure where i will find the inch from er half inch. 1/2 inch over will be 1 inch total. Shouldnt be to hard, probly just need to tighten everything up, i still dont have the watts tightened.
I did get the rear brakes on, just need to find a brake line fitting that will fit the caliper fitting. Ill be ordering an aluminun driveshaft here shortly. I should have the fuel tank installed by weeks end, work will get in the way a bit though.
I got a bit of help while messing around today.
69 c-10 BBC
Old 10-09-2009, 06:30 PM   #58
ripdog28
ripdog28's Avatar
Re: 69 cst-10
So i got the rear end centered, just worked with the watts link and it moved the body over enough. Ill be ordering some more parts to button up the engine this weekend so may have her running by end of next week, I hope.
69 c-10 BBC
Old 10-12-2009, 10:42 PM   #59
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Got a bit done today before a lot of parts come in (headers, Malory 6al, other stuff i can not remember) I got the front sway bar in. I had to drill some holes in the tubular cont arms. the flat plating not the tubes, and it mounted to the orig frame holes. I also found out that with my POL box trailing arms i can not use a stock type rear sway bar so i will probly buy a weld in one to mount to the rear axle. I got the alum fuel cell installed but no pics yet as i have removed it to wait for the wife to get home so she can, "Help me get it in." I do all the measuring 3x and drilling 3-4x and wait for her to do the final step so she dont need to do the hard work but will stil help me with it. With the Watts link set up, i had to make a few holes I did not remove the rear brace between the frame rails and after getting the cell in, i noticed the Watts link was hitting it when suspension traveled down, so i had to cut out the rear brace (will get a new one welded in) and mount the Alum cell a bit further back making more holes in the frame, so 6 holes in total that are new and not used. I will post pics of the fuel cell once she gets home. I have a bit of surface rust to wire brush off also from sitting outside so long.
69 c-10 BBC
Old 10-13-2009, 02:30 AM   #60
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Well, it did not work out so well, Wife gets under truck and bolts are not going in as easy as a new pair of shoes fit so she gets frustrated. A bolt falls from her hands while twisiting it in and hits her in the head and she leaves, go figure. I spend a few hours of prep to wait so she can help then that happens haha oh well.
69 c-10 BBC
Old 10-15-2009, 07:38 PM   #61
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Got some new parts in. Just need to get a new trans cross member now cause the Hooker headers are long. Once that is in, ill get the ignition system installed and hope to be running in a week or two.
69 c-10 BBC
Old 10-19-2009, 11:06 PM   #62
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Got the headers on. Having 2in primaries took some masaging to get in. I kind of wish i had gone with 2in but i got em in now. Needed to be dimpled at the lowest bend where they hit the lower Tubular A-arm and where they hit my motor mounts.
The passanger side went in easy but the Driverside took some work. After the new transmount was is all went pretty well.
I am working on sizing the pics. will get some soon.
69 c-10 BBC
Old 10-20-2009, 07:57 PM   #63
ripdog28
ripdog28's Avatar
Re: 69 cst-10
So here are pics from yesterday. Today i got the starter on, trans cross member drilled and bolted in, and started on the wiring for the Ignition (mallory 6al).
69 c-10 BBC
Old 10-26-2009, 10:51 PM   #64
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Got the 6in drop rear springs in. I think it looks better now. Do not have any good pics from a distance because it is in the garage but believe me, it looks better leveled out. Now it is 3.5in front and 6in rear.
69 c-10 BBC
Old 10-31-2009, 06:34 PM   #65
ripdog28
ripdog28's Avatar
Re: 69 cst-10
got my alt and pwr steering pump brackets in. I painted them an aluminum gray. they are Alan Grove's mid mount brackets. i wanted to keep everything tight instead of spread out.
69 c-10 BBC
Old 11-06-2009, 12:39 AM   #66
ripdog28
ripdog28's Avatar
Re: 69 cst-10
got the inside of the cab cleaned and started installing the painless performance wire harness.
69 c-10 BBC
Old 11-06-2009, 02:12 AM   #67
CheyenneShop
CheyenneShop's Avatar
Re: 69 cst-10
Awesome build so far!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 11-11-2009, 04:12 PM   #68
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Pushed the beast outside to wipe the dust and crap off of her. took a few pics also. I like the stance just need to rotate the front tires. I may drop her down a bit more front and rear 3.5/6 so far but may mod the rear frame rails a bit.
69 c-10 BBC
Old 11-11-2009, 04:14 PM   #69
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Few more of what i have done with the wire harness.
69 c-10 BBC
Old 11-11-2009, 06:21 PM   #70
CheyenneShop
Re: 69 cst-10
still looks great
what happened to the right rear side marker area of the bed/
72 3/4 long 4X4
69 SWB "Prospector"
Old 11-11-2009, 08:25 PM   #71
ripdog28
ripdog28's Avatar
Re: 69 cst-10
The PO had a small metal plate bondoed in to smooth the fender. I did not want it bondoed and decided to take it out. It had a thick layer of filler in it and i scratched it a bit, It has some small wrinkles in the bed and front fender with some filler in them. when i do the body ill take it all out and get the metal fixed.
Right now the plan is to make it driveable. The body will be taken care of later. It will look bad but run like a bad ass.
69 c-10 BBC
Old 11-12-2009, 12:37 AM   #72
mcbassin
Still Learning
mcbassin's Avatar
Re: 69 cst-10
This is a sweet project! I love the FAT block! that thing is gonna bang! That rear end is built! keep it up and don't sell!
mcbassin is offline   Reply With Quote
Old 11-17-2009, 03:01 PM   #73
team39763
Re: 69 cst-10
Any news on this project?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 11-17-2009, 03:38 PM   #74
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Should be running in a week or so. Still need to get the driveshaft. I am ordering the fuel pump/line/gauges and a few other items needed to get the engine fired up. Hope to have the wiring finished soon.
69 c-10 BBC
Old 11-17-2009, 03:44 PM   #75
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 69 cst-10
This thing is coming right along, nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
