Old 01-21-2010, 12:36 AM   #51
70 Suburban
Rods
Re: My "Pop's 66" Build......
why not use the 6 lug stock swap and run six in front with disk...I did looks and works great.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-21-2010, 12:39 AM   #52
CSoliz
Torn between 66 and 78
CSoliz's Avatar
thats the plan. Been working on gathering all the pieces necessary for it. I just need the drop spindles.
CSoliz is offline   Reply With Quote
Old 01-21-2010, 12:44 AM   #53
70 Suburban
Rods
ahh i didnt use drop spindles. used stock uppers and 3/4 ton lowers with 2000 van spindle
Old 02-04-2012, 12:15 PM   #54
CSoliz
CSoliz's Avatar
Here is some long needed progress. I am sure most know how life seems to slow these things down. But I finally got my welder and hopefully I will start strong on it now.
got it braced up and ready:
The cut:
welding them together:
Not to sure why I took so much metal off on this side and created that gap, but I got channel on the inside so I can weld it up nice and strong:
The duct tape was to cover up the vin while I welded. Its all I had. I still have to do the passenger side today. I learned that I cant weld very good in tight places (to low too). Th inside of the frame on the drivers side looks like crud. I am going to lift the frame up on some sawhorses today to tackle the passenger side, that way I am a little more in a comfortable position, hopefully it helps out some.
