06-09-2008, 06:42 PM | #51 |
Junior Member
Re: My Big problem..need your help (long)
Its all cool.....I have a set of heads on the way as we speak (3917215) if I remember correct.
Ill have the heads off and ill let everone know asap. Again....thank you everyone for your help.
going to sell this one...looking for a SWB project next. |
07-07-2008, 11:14 AM | #52 |
Junior Member
okay everyone....I pulled the heads off my vehicle last night. The pistons are slightly domed. Now I bought some closed chamber heads (215's) to fix the compression problems and wanted to know...Will closed chamber heads fit on the motor with domed pistons??
07-07-2008, 11:54 AM | #53 |
Never Ending Projects
Not to sound like an ass but I would seriously find someone who knows BBC's to come and help you out. Just "bolting" on parts is easy, bolting on the right parts, that work together takes experience.
You want an answer but there are many variblies that will come into play. Pistion pin centerline, valve size, cam lift, rocker ratios, etc., etc., etc. All of these have to work together and you have to KNOW what you have, not GUESS at what you have. Before you hurt the engine, find some help. My .02 worth. Good luck. BTW, be careful with the compression ratio, BBC don't like it too high without pinging.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 07-07-2008 at 11:54 AM. Reason: added info |
