#51 |
![]() Join Date: Jul 2009
Re: post latest 1/4 and 1/8 mile times and 60ft.
New to the site my name is daniel bodry every one calls me dbo.
I fill like u all are family and i dont even know you! Great trucks maybe mine will be back together in a couple of months. Old engine 468 steel headed th400 trans reverse manual w/brake 12 bolt rear end 3:73 gear spool 33 spline bigshot plate w/nos progressor 60 foot 147 1/8 6.9 102 mph nos button stuck and melted 2 pistons building a new engine. Last edited by bigboybodry; 09-16-2009 at 12:43 PM. |
#52 |
DA = Density Altitude..
BDO, glad to see you aboard.. Hope to hear some new times when the new motor is here..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#53 |
Mean Green
LOL I'm a big dummy. Yes I have noticed that DA can strip tenths away in seconds. I'm putting a new built spec converter in Friday night. They say 5-7% slip only. We will see.
#54 |
Mean Green
Name-68 C-10 KID
Date-9/18/09 60'-1.70-1.68 330'-na 1/8 ET-7.692 1/8 MPH-89.49 1000'-na 1/4 ET-12.182 1/4 MPH-107.04 Year-1968 Weight-4089LBS Engine Platform-406 sbc Transmission-TH 400 W/ Brake Stall converter-A-1 4000 Rear Gear-4:10 Rear Tire-28x13.5 ET Street's CommentsNew converter. 2 step @ 3600 RPM @stripe was 6200 now its 5600. Track was poor. 60's were all over. |
#55 | |
Mean Green
60'-1.601 1/8 ET-7.388 1/8 MPH-91.93 1/4 ET-11.776 1/4 MPH-109.43 Year-1968 Weight-4078lbs Engine Platform-406 sbc Transmission-[COLOR="Red"]Th 400 w/ tci trans[COLOR="Red"] Stall converter-A-1 4000 Rear Gear-4:10 Rear Tire-28x13.5 E.T Streets CommentsTurned down 2 step to 3400 and lowered shift point to 6700[/QUOTE] |
#56 |
That's haulin there buddy.. Glad to see the changes worked for you..
#57 |
good numbers!!! I see a cage coming up next
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#58 |
Mean Green
Thanks guys. I'm glad its coming around. Now I have a good base. I can start power tuning on timing and jets now. Maybe I can get a tenth or so more out of it. Sure would be nice to get a 11.49 out of it before the tracks close.
It would give me some thing to do over winter. Body work and a Roll bar set up. Maybe a bar set up that's legal to get my license W/ help from a Speed tech N20 system. |
#59 |
I am new on here but sure like all the trucks.Just got mine going this summer it has a 6.0 lq9 ,4l80e with stock converter,3.55 rear no posi.my best run on street tires was. 60ft 2.29 ,1/8 9.59 ,at75.9 , 1/4 14.65 at 96.8 that was at4800ft elev.
#60 |
Well i finally made it back to the track with the new gears improved a little somthings still holding it back on the big end still not pulling the numbers we think it should.improved the most down low trucks pulling hard out of the hole. all in all we pleased so far.
old times 8/8/2009 1.60..60ft 7.45..1/8 88.70..mph new best time 11/7/2009 1.56...60ft 7.41...1/8 89.41..1/8 _______________________________ 1968 c-10 stepside "THE GRAPE APE" all motor 1.56...60ft 7.41...1/8 89.41..1/8 Last edited by limitedstreetoutlaw; 11-18-2009 at 03:31 PM. |
#61 |
What was your old gear/tire combo and 60's? How bout the new gear/tire combo?
#62 |
old gear/tire was a 3.73 gears tires are /325/50 drag radials old 60ft was a 1.60
i have 4.56 gears now same drag radials new 60ft 1.56 _______________________________ 1968 c-10 stepside "THE GRAPE APE" all motor 1.56...60ft 7.41...1/8 89.41..1/8 Last edited by limitedstreetoutlaw; 11-18-2009 at 03:31 PM. |
#63 |
At the body shop.
New best with a slightly off 60ft. The d.a was real good that day @ 4160ish btw im the one on the left
" That didnt make it any newer " " Dont antique the equipment " |
#64 |
'71 C-10.
Combo run in '08 with closed exh and 29x18.5 mickey sportsman pros; Re-ringed std bore, std crank 1975 Cadillac 500. Howards 292/302 - 232/240 at .050" cam, .536" on a 112 in 6* advanced. Ported heads and intake but all stock internals except for cam and valve springs, stock 2"/1.625" valves . Edel performer, 1" open spacer, QJ, 1.875" headers. 8.6-1 compression. 2000/3000 stall switch-pitch convertor, 4.10 gears. 12.97 at 100.02 in 1/4 8.12 at 82.19 in 1/8 1.72 sixty foot on 87 octane. Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-16-2009 at 01:53 AM. |
#65 |
'71 C-10
Combo run in '09 with closed exhaust, and 29x17 M&H dot tires; .060" over Cadillac [514"]. 11.7-1 CR, MTS/Probe 19cc dish pistons, PEP I beam rods, ported early iron heads, MTS 2.19/1.84" valves, Potter/Probe shaft roller rockers. Elgin 300/294 - 260/254 at .050", .640"/.624" solid flat tappet on a 114*, advanced 3*. 1.875" headers, Edel performer, 1" spacer, 4781 850. Switch-pitch TH400 with Tri-Shield 1800/3200 stall, 4.30s. Best e.t - 11.66 Best mph - 113.96.6 Best 1/8 - 7.34 at 91.4 Best sixty - 1.59. Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-22-2009 at 06:28 PM. Reason: new track best |
#66 |
Nice truck david!!! Do you have any pictures?
#67 |
Thanks trk69. I loaded pics in the picture thread, see post #225 and 226.
http://67-72chevytrucks.com/vboard/s...62#post3622862 Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-16-2009 at 12:34 PM. |
#68 |
![]() finally made it to the track it was cold as all get out though. think there may still be some left in it. guess i'll have to wait till next year to find out.
69 stepside 489ci 60ft---- 1.46 660ft--- 6.570@105.95 1320ft-- 10.37@127.01 |
#69 |
Right on.. Nice times..
#70 |
how quick do you think a 1972 blazer with a 598 around 800hp with 3.90 gears,29.5 mt et drag radials,a th400 w/o footbrake and a tight 3200 ati converter. rear suspension is ladder bar coil over and vehicle should way about 3000lbs. Im thinking it should run in the low tens. its all metal except for the hood and top. Thanks for any opinions given.
#71 |
I would be surprised if you got it that light but I would say 9's if you get it to 3000lbs.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#72 |
I agree with dj, i would think 3000lbs in a blazer would be very hard to accomplish, it's hard enough to get a truck that light.... i would say in the 9's at 3000 also..
#73 |
Sunburst C10!!!
man i wish i could run mine
Gage 1967 C10 Shortbed Stepside |
#74 |
my blazer is 104 wheel base, and the info i found online about these rigs even with 4x4 and leafs plus 205 tcase and full interior with v8 was said 2 be 3600 lbs. If this is correct i have shed quite a bit of weight and should be very light for full metal body. thanks 4 your guys input.
#75 |
dont feel bad i thought i done all the good on mine till i rolled the scales at baytown. i cried all the way back to the trailer. it weighed 3525 with me in it. so i say fatman fab a little fiberglass where you can.if that doesnt work then NOS fogger and pill it till you kill it.
| Bookmarks |
