Old 09-21-2008, 11:32 AM   #51
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 1971 Cheyenne "One For the Road"
Man, it is hard to believe that is the same truck, nice to see one bring one back from being so far gone.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 09-25-2008, 11:17 PM   #52
19723DR
19723DR's Avatar
[quote=msgross;2898843]oh ok, didn't know the name of them, thanks. I used those to convert my boat trailer into a flatbed. Allowed me to bolt the deck right down to it... only $13 for a 10 ft section at Home Depot...
cab corners look great.[/QUOTE
Your welcome, and thanks. I think they come in handy for a lot of projects.
I wish I could be of more help to you on your floor, I've never dug that deep into it.
Thanks, to be perfectly honest with you this truck has more good going for it than what the exterior shows. It is mechanically sound, I can deal with a little rust.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 09-26-2008, 12:05 AM   #53
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Dude, you got big ones! LOL I guess living in SoCal my whole life, I am not used to seeing this type of rust (or worst). I would have looked at that and sent it to the scrap yard.
Great job on bring it back to life! Never would have thought it was the same truck. BTW, what size rear tires are on there?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-28-2008, 07:56 PM   #54
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looking good im sure it will turn out killer.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-28-2008, 10:40 PM   #55
19723DR
19723DR's Avatar
Ha, ha, ha. You wouldn't have sent it off to the scrap yard with out pulling off all the good stuff first! Here in Utah, the roads are salted in the winter because of our heavy snowfall, so this kind of rust is common on most old vehicles, at least in Northern Utah.
My last project, '72 Suburban, the majority of the rust repair had already been done so I didn't really get the chance to tear it apart to see how it all went together. With this project, I get to have the ability to do the rust repair and say, "yeah, I did the work." I have looked at this project as a challenge to overcome.
As for the tires, they are 295/50/15 BFG's front and rear. If I want to run these tires I'm gonna have to get some smaller fronts.
Thanks, if you look at the first post in this build thread I have a rendering of what I want it to look like when I'm done.
97 Z71 3 Door
Old 09-28-2008, 10:43 PM   #56
19723DR
19723DR's Avatar
This weekend, I had a hard time uploading my pics, I did get a little work done.
I cleaned up my rear brake drums and made some shock re-locators, I did a little work on the front of the bed.
97 Z71 3 Door
Old 09-28-2008, 10:52 PM   #57
19723DR
19723DR's Avatar
Here are the pics.
I had a leftover piece of deep unistrut. I drilled some holes for the shock, cut it down so it would clear the top of the shock, painted it black. It took about and hour and saved me sixty bucks. I'm gonna make a couple more for my suburban.
97 Z71 3 Door
Old 10-05-2008, 11:34 PM   #58
19723DR
19723DR's Avatar
Small update. I spent Saturday trying to stay out of the rain so I built some upper bag brackets. Not to complicated; I took some leftover circles, Cut 1 inch off a 4 inch pipe, flat peice of steel and a 3/4 inch, bolt weld it all together and this is what you get.
Sunday morning was much better for wheather wize, I simply bolted the bags up to the rear, had to try out my new toy. I also noticed my shocks on the bottom were mounted backwards. Fixed that.
I never seem to sick of messin' around with air suspention.
I also recieved my woofers in the mail this weekend. It onlly took three months. But that's the price you pay when you get them cost. (Thanks Johnny.) That will make a good project for my suburban in the winter.
97 Z71 3 Door
Old 11-03-2008, 12:03 AM   #59
19723DR
19723DR's Avatar
I finally got some time to post the the progress I've made. The last three weeks I've been super busy; at work and play. I spent all last weekend in Moab, Utah on the Jeep trails. I managed to get some work done on the truck. Me and three friends put the bed back on. (Sorry about the backs, guys.) Thanks Mike, Matt and Jeff!
I also fixed the small cracks in my grille. I also worked on the grille shell getting the big dents out, this shell is in really bad shape. I also made some time to cut my front coil springs, I cut coil and a half off. They say that's three inches, ha-ha-ha.
I needed to move it around until I get my bags mounted, I'm going to need to get new front tires, these rub on bumps.
It's starting to look like a truck again, the neighbors are happy.
Hey, Matt, How's the ride now?
97 Z71 3 Door
Old 11-03-2008, 12:13 AM   #60
19723DR
19723DR's Avatar
I spent some time this weekend working on a cowl screen. My truck is parked under a maple tree, and I knew I was going to get a bunch of leaves down there, my truck is equipt with a leaf clean out hole, provided by the kick pannel. Leaves also end up in the inside of my truck, thanks to the well thought out speaker holes.
I took an old ceiling grill vent that I got from work, and cut it to the right shape, painted it black, I then siliconed it to the bottom side of the cab. I know I'm gonna need to take it off when I repaint, but I'm just trying to keep all the crap from getting in there.
97 Z71 3 Door
Old 11-03-2008, 08:50 AM   #61
msgross
msgross's Avatar
That's work pretty nicely... Better than $50 or whatever LMC sells them for. Keeps this from happening!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-09-2008, 02:55 AM   #62
19723DR
19723DR's Avatar
I figured I would save myself fifty bucks. 'Cause that's fifty bucks I don't have! It really wasn't too difficult, but this project has turned into a "do-it-myself-because-of-lack-of-funds."
Your truck has come along way since then. I suppose you are going to find a way too keep the junk out.
97 Z71 3 Door
Old 11-09-2008, 03:01 AM   #63
19723DR
19723DR's Avatar
Saturday progress:
I put new poly-urethane body bushings in the cab. I also welded in the drivers side gas door. Nothing big, just more of the same boring stuff.
97 Z71 3 Door
Old 11-09-2008, 04:37 AM   #64
61superman
61superman's Avatar
wow another great job
i enjoyed following you last project page (burb) and this one is keeping up nicely. again great job and look foward to reading more
keep up the great work
later
61superman
current project: 1964 chevy II Wagon
1956 3100
1972 c10 burb bagged
1962 GMC burb
1963 c10 burb
1966 c10 burb
1995 chevy lowerado 5/7 static drop daily driver
1963 c10 step side
1965 super sport impala
1967 c30
61superman is offline   Reply With Quote
Old 11-17-2008, 12:31 AM   #65
19723DR
19723DR's Avatar
later
61superman
Thanks, I appreciate the support. I hope my suburban build has been helpful. If you have any questions, just give me a PM. I checked out your VW, that is pretty sweet. I really love the older buses, totally classic.
97 Z71 3 Door
Old 11-17-2008, 12:37 AM   #66
19723DR
19723DR's Avatar
This weekend's progress: More of the boring stuff.
I patched the antenna hole, and smoothed out the gas door on the passenger side. Unfortunately, I got a little warpage during the welding and grinding. I didn't want to use that much body filler; but hey, what do you do?
97 Z71 3 Door
Old 11-17-2008, 12:41 AM   #67
19723DR
19723DR's Avatar
More of the bed:
97 Z71 3 Door
Old 11-17-2008, 12:54 AM   #68
19723DR
19723DR's Avatar
I spent some time on the extra gauge cluster I had. I had an old tach sitting around. I saw how to do this in the FAQ sections. If you want a more detailed how to, just go to the FAQ index and do a search.
I painted the bazel with Dulpli-color chrome spray paint and the inner plate with Dupli-color with blue metal specks, they were just sitting in my garage left over from past projects.
This is how it looks all together:
97 Z71 3 Door
Old 12-09-2008, 01:43 PM   #69
Clyde78
Nice! Plus, I found out that milk crates make better seats than five gallon buckets. You also need to mention how much better it runs now that you found out that the secondaries were FUBAR. Still need a donor carb?
Clyde78 is offline   Reply With Quote
Old 12-09-2008, 03:42 PM   #70
67ChevyRedneck
67ChevyRedneck's Avatar
Impressive!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-10-2008, 12:41 AM   #71
19723DR
19723DR's Avatar
That's the first time I've had three adults in my truck.
Yeah It runs sooooo much better, I did a small burn out in front of my house no sweat! It is making it really hard not to keep it.
Originally Posted by 67ChevyRedneck View Post
Impressive!
Well, we try. Thanks!
Seeing some of the builds that are going on right now, I feel like an ameture.
97 Z71 3 Door
Old 12-10-2008, 01:10 AM   #72
19723DR
19723DR's Avatar
Well, I really like the long bed, but I would really like short bed even more. I have a '69 short bed frame that I bought with the truck. I was going to start the swap last week, but I helped move my brother. Maybe this week end.
I can see it already . . . well, almost!
I've got the shortbed frame all painted and ready to go. If you don't hear from me for a while, I'm busy?
97 Z71 3 Door
Old 12-22-2008, 12:23 AM   #73
19723DR
19723DR's Avatar
Here are some pictures of what the truck looked like two weeks ago. The body work was coming along nicely, however, I have drastically changed my mind about the direction of this project, but don't worry, it won't become a ford or anything...
97 Z71 3 Door
Old 12-22-2008, 12:39 AM   #74
19723DR
19723DR's Avatar
Since last weekend I've been working on pulling the bed and cab off. I was able to do the bed by myself, but the cab was more difficult. Lucky for me, I have two really great buddies who always happen to show up in time to help prevent my back from straining. (Thanks again guys.)
This coming weekend, my plans are to pull the engine and tranny, followed by dropping the front and rear suspension out. Hopefully by next weekend, I'll be putting the suspension on the shortbed frame, so if you don't hear from me for awhile, Merry Christmas and Happy New Year!!!
My wife's happy about the new addition to her parking spot!
97 Z71 3 Door
Old 12-22-2008, 12:51 AM   #75
nuke1
nuke1's Avatar
just checking out the build, great looking project, and at least your wife gets to park in the garage, it is 35 below and my wife has to park outside, priorities you know, me bad
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
