11-17-2008, 05:17 AM | #51 |
Restoring a 68 SWB
Re: Lucy - My 1968 SWB
Yeah, I am gonna keep the intake. I am not gonna change much on the engine now. Just clean it up and put a new water pump, fuel pump, and maybe change the timing chain if needed.
I am gonna put a hidden hitch on it. I'll probably drive it like this for a few years at least. I wanted to go ahead and do the frame right this time around so I wouldn't have to bother with all of that when I do get ready to paint the body.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
11-17-2008, 05:19 AM | #52 |
Restoring a 68 SWB
I've already pressure washed it once or twice when it was on the truck with the motor still in, but I guess I am gonna do it again with some oven cleaner and then some naval jelly.
11-17-2008, 10:02 AM | #53 |
Restoration Virgin!
ahhhh....progress....looks good Trai!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
11-30-2008, 06:34 PM | #54 |
looking good, keep pictures coming
12-11-2008, 12:10 AM | #55 |
Just found the build thread and can't wait to see more. What drop are you going with? I have a 68(clone 50th) that I am getting ready to convert (5-lug) and drop 4/6 so I'd like to see what you do. It looks great!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
12-12-2008, 11:24 PM | #56 |
VA72C10
Looks like a really nice start to the project
Looking for a 67-72 swb or blazer project in or around VA. |
12-13-2008, 02:44 PM | #57 |
Restoring a 68 SWB
Thanks guys. Funds have been tight recently, so no major updates. Still cleaning on the frame and motor. Need to finish getting the control arms blasted too.
As for the drop, I am going with 18" wheels and 50 or 55 series tire, so whatever drop it takes to just get those wheels to tuck the fender is what I will do. I am gonna run bags all the way around, so I 'll just adjust til I get it where I need it. That's a cool 68!
12-27-2008, 01:26 PM | #58 |
1967 C10 SWB
I will be following your build. I like what I see so far. I am doing something similar
http://67-72chevytrucks.com/vboard/s...d.php?t=320847 No air bags but probably a 4/6 drop and some 20's Vex |
01-03-2009, 11:35 PM | #59 |
Restoring a 68 SWB
I got a flux core wire welder for Xmas and I got to try it out today. This is the first time I have ever welded anything. I practiced a few times on a thick piece of metal and laid down a nice little bead after a few tries, so I decided to cut up a bad fender and try my hand at some sheet metal.
I cut off the front cup off the fender and then welded it back on. I burnt through the metal a few times and had to fill it back in. All in all I was pretty pleased with the results. The cell phone pics aren't that great so it's hard to see the details.
01-04-2009, 12:21 AM | #60 |
That looks good Trai
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
01-04-2009, 01:12 AM | #61 |
Restoring a 68 SWB
Thanks. Got any tips about how to keep from burning through the sheet metal? Do you use gas with your welder?
01-04-2009, 02:23 AM | #62 |
To keep from burning thru thin metal try a smaller wire gauge. .20(if your not that small yet) or so and lower the volts/temp a little at a time. I would use that scrap panel and stick a bead. If it burns thru lower the volts a little till it looks good. On sheet metal do not run a bead/line. Just spot weld it spreading it out as you go so you do not build up heat and warp the metal. Stick a spot every 5-6inches till it is filled in. I use c25 gas on sheet metal. That just keeps the weld cleaner. Flux coated is fine just make sure to wire brush it a lot.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 01-04-2009 at 02:24 AM. |
01-04-2009, 04:24 AM | #63 |
Looking good.
01-04-2009, 04:42 AM | #64 | |
Restoring a 68 SWB
01-04-2009, 07:55 AM | #65 | |
Just read thru your build thread, Nice build you have going there
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
01-05-2009, 12:19 AM | #66 |
Restoring a 68 SWB
Tonight I started on a little rust repair. This little box behind the vent was rusted out pretty bad so I cut out all the rust. I cut it out all the way back to the cab. I brushed on some rust inhibitor/converter and let it dry while I was cutting up the metal to weld back in.
I made a template and cut some sheet metal out of an old fender. I put it in a vice and put a 90 degree bend on it to match what a I cut out. Took me a little bit of grinding to get it to match up, but I finally got it right. I even bent up a little curve at the end so it would match up. I clamped it and tack welded a few places and then lined the other side up and tacked it in place. Alot of tacks later it was really strong. I had some holes that I couldn't fill, but I think I am just gonna just gonna fill them with seam sealer and call it done. I should have taken some before, during and after pictures. Oh well. I got to come back tomorrow and fill the seams with seam sealer then I can cut out the piece for the the front and weld it back on. Here's what it looked like before I started. You can't see it but it was rotted this bad underneath too. This is all the crap that came out of that little box.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 01-05-2009 at 12:33 AM. |
01-07-2009, 08:01 AM | #67 |
Restoring a 68 SWB
Got a little done tonight. Still have a few holes to fill, but it turned out pretty good.
01-07-2009, 08:58 AM | #68 |
Looks like you’re getting a handle on your welding it just takes time and practice working with what ever tools that you have, keep up the good work
01-10-2009, 12:29 PM | #69 |
THE DAMN YANKEE
looks great trai, i'll be following this build my friend. phipp13
01-11-2009, 08:03 AM | #70 |
Restoring a 68 SWB
I went over tonight after the Titans game and worked on my Truck a little. I finally pulled the doors off the cab so I could take a look at the rockers. Man this is gonna be some work . Slow and steady.
Sorry about the crappy pics. Didn't have my cell or my camera. Had to borrow someone's cell to take the pic.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 01-11-2009 at 08:05 AM. |
01-11-2009, 10:02 AM | #71 |
getting there, your vent boxes are better than mine... I had to replace the metal behind that area too!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-11-2009, 10:19 AM | #72 |
Insert Title Here
coming along great so far...... Nice dedication with the name too...
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
01-19-2009, 02:19 AM | #73 |
I'm here 2 learn!
I think I'm gonna take a short welding class....I'd like to buy a welder, but I'd hate to post of puff of smoke on the site where I blew something up...!
This is a great place! |
01-19-2009, 06:40 AM | #74 |
Restoring a 68 SWB
The only thing I had ever welded before that vent box was cutting a cup off an old fender and welding it back on . I think it will be easier, and safer, than you think. That being said, I should probably take a welding class myself .
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor Last edited by tdave00; 01-19-2009 at 06:41 AM. |
01-19-2009, 09:28 PM | #75 |
Piece of cake, take your time and practice welding with different heat's and wire speed's.Before you know it you'll be laying down some nice bead's.Proper amount of penatration is key to a good weld.Good luck were ALL watching the build.
