Old 09-10-2008, 12:50 AM   #51
manimal
manimal's Avatar
Re: another crewcab swb build
Originally Posted by suicide 63 View Post
That is correct ,but like joe said you need 3/4-1-ton lower control arms to fit the 88-up ball joint in as far as alignment i have not got it to the alignment shop yet.It looks like it hase some positive camber right now but there are plenty of shims behind the control arm shaft.What i like about this setup is if i ever decide to go to five lug it wil just be a rotor swap up front and axle swap in the rear .I might be wrong about this though on the rear, as i am assuming 5-lug and 6-lug axles will interchange if you get the axles with the same spline count.
I thought the control arms are all the same,just different ball joints???? What is the difference in them? Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 09-10-2008, 08:22 AM   #52
joe231
joe231's Avatar
the 3/4-1 ton lower arms have bigger "holes" so the newer "larger" ball joints will press into them
CHEVY ONLY
Old 09-10-2008, 08:42 AM   #53
Jonboy
Slots go on anything!
On your interior trim, I am pretty sure the Suburban trim will work on everything except the rear pillars (C pillars). Those (should) be the same as a regular cab truck, IIRC. I am pretty sure the front section of the headliner and all of the front trim, along with the B pillar trim will work for a crew cab. That being said, I have never had a crew cab, but have parted out quite a few suburbans.
Old 09-10-2008, 09:05 AM   #54
manimal
manimal's Avatar
Thank you VERY much. I am going to the wrecking yard today and getting me a set. I can use my existing upper arms, right? And just get 88-up lower/upper ball joints and outer tie rods. Do I need a different adjusting sleeve? Thanks Again
-Lance
BTW suicide63 your truck is looking GREAT! I am wanting to shorten my crewcab one day,but right now I need it for my BBQ business.
-Lance
Old 09-10-2008, 10:36 AM   #55
joe231
joe231's Avatar
uppers will work, i'm not sure on the tie rods, i'm sure suicide 63 will chime in
good luck
CHEVY ONLY
Old 09-10-2008, 05:55 PM   #56
suicide 63
-Lance
Joe has responded to this alreadybut let me say this,This conversion is a topic in 63-66 chevy trucks side and the control arms are differnt.With that being said I have not tried to put an 88-up balljoint in a 73-87 1/2 ton arm ,I just used the info found on this forum for the swap so if what you are saying is true that the a-arms are the same it should work.This was my first time doing the swap.Let us know what you come up with i would be interested to know.As far as the adjuster sleeves , the old ones work here is what i used.
All
88-up 1 1/4" spindles,calipers,7200lb rotor whith are 6 lug,brake lines ,upper and lower ball joints and outer tie rods, Thats it.
suicide 63 is offline   Reply With Quote
Old 09-10-2008, 05:58 PM   #57
suicide 63
good luck
Joe let me clarify this,my old upper ball joints would not go into the 88up spindle ,but all you have to do is grind the rivets out of the old one and bolt the new ball joint in.
Old 09-10-2008, 06:00 PM   #58
suicide 63
Thanks thats my mission this weekend i guess.
Old 09-14-2008, 08:06 PM   #59
suicide 63
heres a pic of what i did this weekend,over the week i will block sand and hopefully paint it this weekend.
Old 09-21-2008, 04:41 PM   #60
suicide 63
Well i got the cab painted today ,I guess i,m going to buy patch panels and fix the shortbed i have so thats next. No luck on finding a good bed or bedsides.heres some pics
Old 09-21-2008, 05:10 PM   #61
mike nutt
69fatmotor
mike nutt's Avatar
the truck is looking good .
mike nutt is offline   Reply With Quote
Old 09-21-2008, 05:37 PM   #62
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
x2............
Thanks for Joining the Club, I sent out invite's to all i know who have Built a Crew Shorty or are Planning a Build. I Need to get Busy to Catch up with you
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 09-21-2008, 07:34 PM   #63
joe231
joe231's Avatar
looks very nice!!
CHEVY ONLY
Old 09-21-2008, 08:09 PM   #64
suicide 63
Originally Posted by toomanytoyz View Post
x2............
Rick
Yea , I want to be driving this in short order ,maybe in a couple years I will tear it down and start over to make a show quality truck out of but for now it just needs to look decent.
looks very nice!!
Thanks for the good words guys , as this is my first full paint job.There are some flaws in it. The camara does it justice,It will need a good color sand and buffing.
Old 09-21-2008, 08:13 PM   #65
OJOE
Crew Cut
OJOE's Avatar
man you are moving on with this. looks good, keep the pics coming. joe
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 09-22-2008, 12:18 AM   #66
firedrag79
firedrag79's Avatar
Looks good. Wish mine would come together that fast. Good luck on the bed repair.
1988 Crew Cab SWB project
firedrag79 is offline   Reply With Quote
Old 09-24-2008, 03:21 PM   #67
suicide 63
Well guys ,I took three days off work so i went up to Classic Parts today to get the patch panels for my bed.I was talking to the guy about bedsides being no longer available and he has 3 sets of swb bedsides coming in on oct 7 ,two sets were spoken for and guess who got the third set. I was starting to sweat it , i think i will still repair the old set and swap meet them.So for now i will strip the bed down to the floor pan and wait.
Old 09-25-2008, 06:23 AM   #68
Your truck is looking really great. Love the color on it.
Old 09-25-2008, 09:18 AM   #69
manimal
manimal's Avatar
wow,looks great!
-Lance
-Lance
Old 09-25-2008, 10:08 AM   #70
Cherub
Cherub's Avatar
love that color
Cherub is offline   Reply With Quote
Old 09-25-2008, 10:14 AM   #71
joe231
joe231's Avatar
I might have missed it...but ...what is that color?
CHEVY ONLY
Old 09-25-2008, 02:13 PM   #72
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great color, and nice work on the body!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-25-2008, 02:28 PM   #73
abebummy26
abebummy26's Avatar
I'm sure that old bed will bring you some cash back if it is rust free those are not easy to find around KC and StL. Good Score!
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 09-25-2008, 02:42 PM   #74
jchav62
1962 C-10
jchav62's Avatar
Very nice! You ain't messin' around!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-25-2008, 03:06 PM   #75
suicide 63
wow,looks great!
-Lance
Originally Posted by Cherub View Post
love that color
Thanks guys for the good words
Joe , it is gunmetal metallic gray
Yea I know, I put it on cl way to cheap had 10 calls within an hour and a guy here the next morning.
