11-05-2008, 04:30 PM | #51 |
Re: Calling All 383ci Trucks
Nice thing about the 383 setup is the big fat torque curve Over 400 ft-lb through most of the rpm range. That'll move your truck in any gear. Of course, too big a cam will kill that in a hurry.
11-05-2008, 04:34 PM | #52 |
Accessories will bolt like any SBC, they have the same bolt holes as all SBC heads do, and they take a normal or reversed water pump so , litterally the 67-72 accessories bolt on and work as is. Yes, he'll need a Vortec intake $130 new, so no real increase in $$$, but all the benefit outweighs the extra $$ IMO since a roller cam, and never worrying about a flat lobe in and of itself helps me sleep at night.
11-05-2008, 04:40 PM | #53 | |
11-05-2008, 05:44 PM | #54 |
I took mine 1500kms from Niagara to Daytona Beach with 4 speed M21 and 3:73 gears...now I have 3:07 gears and man it is a highway machine now....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-05-2008, 07:05 PM | #55 |
Grand PooBaa Member
I understand now. I was told 3:08's make there own power so with that engine and my setup of gears and trans, I would have a nice torq and freeway-able without worrying about tearing up the engine.
11-05-2008, 07:07 PM | #56 |
Grand PooBaa Member
Thats my problem with my 283, the cam is so big (not sure what size) that I have only top end power. No grunt at all. The guy who built this had it in his Chevelle with a manual trans.
11-05-2008, 07:52 PM | #57 |
Parts and more parts
385 Cu In stroker motor with Comp Cams roller cam and rocker arm setup, Edelbrock Performer RPM intake, "Carb Shop" billet dizzy, Edelbrock AVS 650 carb, and Moroso 7 quart oil pan.
This is the second engine that I have built like this and the driveability is better than a normal 350 and has more low end torque than needed. I am running a 700 R4 with 3.73 gears and 28" rear tires. Highway RPMs are at 2500 RPMs at 70 MPH with the gas mileage at 15 MPG. I have had this truck all over the country on numerous Hot Rod Power tours. |
11-05-2008, 08:06 PM | #58 | |
Grand PooBaa Member
Thanks. |
11-05-2008, 08:11 PM | #59 |
I have a 383 in my 69 as well. 700R4 with 4:11s and on the hwy it was getting 18mpg. Offey intake with a Q-jet and points. Its a good truck engine with alot of torque an you should be happy with it in yours even with the 3:08 gears. But then there is nothing wrong with a good 350 engine.
11-05-2008, 08:40 PM | #60 | |
With a set of 3.08 gears, don't overdo the cam choice. The gear ratiio will kill your take off and screw up the gas mileage. My son's truck had 3.08 gears and when we put an OD tranny in it, the RPMs fell to just under 1800 at 70 MPH. The mileage also dropped off. We put a set of 3:73 gears in it and gained back 2 MPG and it is a strong running 350 truck. |
11-05-2008, 08:54 PM | #61 |
Grand PooBaa Member
Options Options!!
I just know its time to get out of the 283! |
11-05-2008, 09:36 PM | #62 |
1969 Short, Fleet, and Beat
11-05-2008, 09:43 PM | #63 |
11-05-2008, 10:10 PM | #64 |
Truck and auto performance nut
then just save some money and change the cam in your 283?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-05-2008, 10:24 PM | #65 |
Next time you're out my way, let me know. We can go for a test ride.
11-05-2008, 11:03 PM | #66 |
Here she is
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
11-06-2008, 08:47 AM | #67 |
Actually 3.08s would be prefered by most,I`d think.3.73s were standard,maybe that`s why most have that ratio.Figure GM used 3.08s with the torquey big blocks.Better torque allows taller gears.
11-06-2008, 01:38 PM | #68 |
Grand PooBaa Member
11-06-2008, 01:40 PM | #69 |
Grand PooBaa Member
11-06-2008, 01:41 PM | #70 |
Grand PooBaa Member
11-20-2008, 01:19 PM | #71 |
Certified Car Nut
Vdog,
Build the 383, you know I would not steer you wrong. You will be very happy with it. I'm thinking about building one for the 55 Chevy truck, the 5.3 might be going in another project. |
11-20-2008, 03:44 PM | #72 |
I'd bet you could build a 383 for close to the price of a rebuild on the 283 and you are giving up 100 ci!! Do like I did amass the 383 piece by piece, just be sure to buy the rotating assembly matched or you could end up spending all the $$$ you saved getting it balanced!
I built a pretty wild iron vortec headed 383 and the machine shop bill with parts ready to assemble was $2600. Sounds expensive but I rework ever piece and part, ported heads, bowl blended them, screw in studs, guide plates, Mutha' Thumpr" roller cam, screw in studs, etc, etc,etc!! |
11-20-2008, 04:31 PM | #73 |
Grand PooBaa Member
All you guys make a strong point for the 383. Again if it will work with the gear and trans I have, then I will go for it. Other than that, a stout 350 will go in and I will be done with it.
11-20-2008, 07:35 PM | #74 | |
Grand PooBaa Member
The engine is going to have to come soon since im getting blowback from the current 283. Again if it works with my setup, then lets build it. |
11-20-2008, 08:16 PM | #75 |
VDOG, I blew the original 350 ci engine in my '69 (full throttle with a load up the steepest hill in Los angeles,Baxter St,) and had a "rebuilt" 350 put in and opted for the "RV cam".(specs unknown). I am VERY happy with this 350 and it has loads of low-end torque. I've never driven a 383 to compare it with, but the only reason I WISH I had gotten a 383 is if I ever want to tow a travel trailer of any size,it would probably struggle up the long mountain grades.
But for all other uses,including bed-loads of sand,dirt etc.,I like my 350 just fine.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
