Old 03-22-2009, 03:02 PM   #51
powerbench
powerbench's Avatar
Re: cadillac rear disc brakes on 70 truck
Does anyone know what size axle flange is on a 72..I have a sneaking suspicion something is different with my axles..
powerbench is offline   Reply With Quote
Old 03-23-2009, 03:11 PM   #52
70STOVEBOLT
70STOVEBOLT's Avatar
Thanks justcuz, I will check that out.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-07-2009, 02:13 PM   #53
chevyrestoguy
chevyrestoguy's Avatar
I am very interested in doing a rear disc conversion, and I used the search function and found a few different configurations . One uses Cadillac parts, the other uses Impala parts, and the last uses Impala rotors and Camaro calipers.
There are alot of wrecking yards close to me with tons of mid 80s GM stuff, and the Cadillac parts shouldn't be too difficult to find. Is there any drawback to this system versus the two others I mentioned? I gather that it has the parking brake internal to the caliper, and that's important to me. I get the idea that some have scoffed at the Cadillac system because it's older technology and not the sexier looking later model Impala/Camaro set-up. I am interested in hearing from guys running the Caddy set-up and how well it works and the availability of over-the-counter parts. Do you have to also grab the master cylinder out of the donor, or can you buy a new disc/disc master cylinder (like a '68 to '81 Corvette unit) and it'll work fine?
I love hitting the wrecking yards, and I love building stuff that works well for hardly any money. Our yards around here have 50% off Day, and even $5 Day (every part is $5) every once in awhile, and a complete Caddy system would be a smoking deal on one of those days.
chevyrestoguy is offline   Reply With Quote
Old 04-08-2009, 12:07 AM   #54
sweet70beast
sweet70beast's Avatar
Everyone has different opinions on which one is better. I went with the Caddy setup because the price was right(free). I put it on my Nova and I have to admit that I haven't put the Caddy calipers on yet. Mine are rusty and need to be rebuilt or exchanged so I have front calipers from an S-10 on there so I don't have a parking brake, yet.
I took the master cylinder, push rod out of the booster (the Caddy's was shorter than my Nova's) and the prop valve and have not had any problems after 3 years of use.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 04-25-2009, 12:28 AM   #55
jablack
Classic Chevy Recycler
jablack's Avatar
Does it matter what year S-10 calipers you use and what rotor works best with those calipers?
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 04-25-2009, 10:55 AM   #56
sweet70beast
Seems to me mine are from a late 80's S-10 but bare in mind that I don't have a parking brake now. If you do go with the Caddy set up you can use ceramic pads ( no dust or noise)from the S-10 by taking of the holding brackets off of the pads, they don't list ceramic pads for the back of the Caddys but the S-10's (fronts) will work.
I had to use 79 Firebird rotors to get the 5 on 4 3/4 bolt pattern. The 79 Caddy rotors have a 5 on 5 which I think is the same as the 71 and up trucks so that rotor should go right on. I had to machine the outside of my axle flange to fit inside the hat of the rotors, I wouldn't be suprised if you had to do it with the truck axles. It only cost me $20 per side to do at a machine shop.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 04-25-2009, 07:43 PM   #57
nartkers
nartkers's Avatar
OK I am trying to run Caddy Calipers ('85 Seville). They have provisions for parking brake, but I do not need that. The problem is that the bolt where the parking brake would hook up always leaks on the caliper. What can I do to stop the leaking?
nartkers is offline   Reply With Quote
Old 04-28-2009, 09:45 PM   #58
jablack
jablack's Avatar
I was wondering if you can use the Caddy rotors with the S-10 calipers.
1970 Chevrolet C50
1979 Chevrolet C30
Old 04-28-2009, 09:59 PM   #59
sweet70beast
I would think you could because the caddy rotors and the trans am rotors are the exact same except for the bolt pattern. (size and measurements)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 04-28-2009, 10:02 PM   #60
jablack
jablack's Avatar
Sounds good to me. I appreciate the help.
1970 Chevrolet C50
1979 Chevrolet C30
Old 06-06-2009, 03:11 PM   #61
jablack
jablack's Avatar
Well I got the backing plates from a 77 cadillac brougham and they won't fit over the axle tube and the rotors won't fit over the axle flange. I'm going to have the axles machined down and punch out the hole in the backing plate another 9/16 of an inch and it should work.
1970 Chevrolet C50
1979 Chevrolet C30
Old 06-06-2009, 06:45 PM   #62
fastom
That's right, it's Copper!!
fastom's Avatar
I have the Cadillac setup on my truck and I think they work very well. I wanted the e-brake and that works well also.
Sorry I don't have a better pic!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 06-06-2009, 06:59 PM   #63
bddcustoms
bddcustoms's Avatar
hey,
beautiful set up. I'm just starting the same conversion. what e-brake cable did you use, where did you find it, and how easy to it mate to your stock e-brake pedal (assuming it did)?
thanks.
DTT
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline   Reply With Quote
Old 06-06-2009, 07:23 PM   #64
fastom
fastom's Avatar
I had the cables made locally, they work with the stock e-brake handle for the 68.
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Old 07-02-2009, 11:30 PM   #65
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
fastom what year cady rotors with ebrake this is the set up I am looking t swa over to and braket where did this come from?
myfirstcarwasa73trk is offline   Reply With Quote
Old 04-01-2023, 04:15 PM   #66
cestrella80
Originally Posted by 61superman View Post
alright 68 longbed again i apologize but here is what you were asking for:
this is my setup
85 cadillac seville calipers stamped 020,021
77 cadillac seville rear rotos (mine are just drilled)
banjo bolt 10x150
the cadillac rubber brake hose is metric for it to bolt up to your hard line you will need an adapter from metric to standard (got mine from napa).
hope this helps and if you have any questions i promise to get back with a speedy response.
hope the wait was worth it
Hi Superman, I know, it's been many years, I installed 85 el dorado brackets and I ordered 79 rear rotos but they didn't fit because flange is bigger that the rotors, did you modify the axle flange or rotors??
Please help,
cestrella80 is offline   Reply With Quote
Old 04-04-2023, 06:12 AM   #67
cwlroch
Please help,
This is a very old thread!
Someone else had mentioned they had to machine the axle flange down to get the rotors to fit.
cwlroch is offline   Reply With Quote
