Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 12-10-2008, 11:17 PM   #51
Twisted Minis
Twisted Minis's Avatar
Re: Gary's S10
Here's what I am replacing all of that with.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-10-2008, 11:36 PM   #52
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Re: Gary's S10
WOW on the welding skills.
Is the tank part of that rear member?? Looks like some air bungs welded in the whole thing...
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 12-10-2008, 11:44 PM   #53
corn
Re: Gary's S10
I agree! Im really enjoying this thread. Keep up the good work Seth...
corn is offline   Reply With Quote
Old 12-11-2008, 01:24 AM   #54
Twisted Minis
Re: Gary's S10
Thanks.
The whole rear frame as you see it is going to be the air tank. I cut holes in the rails to let air into the mid crossmember, where the valves will mount. I was pressure testing it in that picture, trying to find leaks. I found none with the soapy water technique, and it held 120 PSI for over an hour. But I am leaving it overnight to see how well it holds.
I put some blind tapped bungs in the bottom of the rail to mount a low profile bump stop.
Is it okay to continue this kind of project thread here?
Old 12-11-2008, 08:52 PM   #55
bdydrp97s10
bdydrp97s10's Avatar
Re: Gary's S10
ok by me..
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 12-11-2008, 09:29 PM   #56
redsled04
redsled04's Avatar
Re: Gary's S10
Man you do nice work.Its cool to see you have your own shop I remeber you from a few years back. When you were doing the build up on your yota back when I was on ssm all the time.
I seems like you have alot of time in that thing. wouldnt it have been cheaper to us a kp six link.I have one waiting to go on my lady's Sanoma. I love the work with the dimple dies it realy adds to it.
redsled04 is offline   Reply With Quote
Old 12-11-2008, 09:33 PM   #57
Twisted Minis
Re: Gary's S10
It would have been easier to use a KP six link. I'm not all that fond of the design of the bolt on kits though, and the customer wanted a custom set up with better geometry. It ended up being close to the same price to build and install that as it would have been for me to install a bolt on 6-link. And no one else will have the same setup.
Old 12-11-2008, 09:34 PM   #58
Twisted Minis
Re: Gary's S10
Should I keep this on this thread? Or should I start a new one somewhere?
I quit early today because I'm not feeling that well, so I didn't get much done. The tank was at 118 PSI when I came in today. So it dropped about 2 PSI in about 15 hours. I think the schraeder valve is leaking because that was the only thing I got to bubble this morning. But I got the backhalf squared up and welded in place. Building the whole backhalf on the table rather than piecing it together on the truck was so much easier. It only took about 10 minutes to square the rails up once I slid them into the stock frame. So it's welded in place, but it still needs some shear load gussets where it ties together, and I want to wrap the bottom of the frame with some 3/16" plate to keep the transition from being drug.
Also made this bracket for my neighbor, to mount a computer monitor to the wall.
Old 01-04-2009, 11:20 PM   #59
heavy71chevy
heavy71chevy's Avatar
Re: Gary's S10
Man,
i remenber seeing your fab work on the MTZ board years ago..but these are so much more in depth.I may wrench on my classic now but once a mini truker..always a minitruker
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-05-2009, 01:05 AM   #60
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Gary's S10
I think it is great that you post here!!!!! You do excellent work!!!!!
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
