12-01-2008, 07:19 PM | #51 | ||||
PITbut
Re: Starting the beast. Any tips i should know?
So, i started it again today. I turned it over a few times, built some fuel and oil pressure, then the 2nd crank it fired right off. No fire, barely any smoke.. I only got to run it for about 5-7 minutes or so, then i shut it down. I dont have a fan on it yet, just the box fan. Also, the damn plug wires that i made, and have go under the headers still a tad bit close to the headers and they will not last like that. Im going to suck it up and buy the kind that come out straight then go over the valve covers. I didnt want to do that, but i want reliability... Thats it for now. Once i pick up the electric fan and get that mounted im not going to run it again. Now that i got the bugs and fires worked out i can mount the cab and get to the rest.. |
12-01-2008, 07:32 PM | #52 |
PITbut
Here is todays vid....
Nothing to exciting. Anyone want to buy a set of msd wires that route under the manifolds. ahaha... |
12-01-2008, 08:04 PM | #53 |
i see you have the air lines from the Viairs running through the frame right toward the muffler..
just make sure you have at least six inches i would say.. i have melted quite a few airlines myself from being too close to exhaust.. im sure you have already taken that into consideration though.
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
12-01-2008, 08:20 PM | #54 |
I am a Referee of life.
We have ignition,we have fuel, we have start.We have fire... uhh ohhh.... fire!!!!!!!!
Glad there wasn't much damage,it's always scary starting a new one.Little glitches like you had aren't uncommon.Glad you're dealing with it well.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-01-2008, 08:30 PM | #55 | ||
PITbut
Since im breaking it in, i cant really adjust the timing because i cant let it idle. What is a good way to get the timing close???? Can you adjust the timing when its at 1800 rpms??? |
12-01-2008, 10:10 PM | #56 |
ok i see what your saying..
running it through the crossmember is definitely alot better. although i cant say they wont melt, time will tell though, but i would think they would be okay
12-01-2008, 10:11 PM | #57 |
PITbut
its good up to 180 i believe. THe crossmember exterior was 100 degrees... So i dont think it will be an issue.
12-01-2008, 10:34 PM | #58 | |
PITbut
Flexalites See how that goes...Once i get these in, i can do the final 20 mins of break in or so.... |
12-01-2008, 10:36 PM | #59 |
you can adjust your total timing. That will get you close and you can still have higher revs.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
12-01-2008, 10:39 PM | #60 | |
PITbut
so take the timing light, and use the degree advance button. Im pretty sure i know what that is. Aim it at the crank and with it set at say 30 degrees it should read right on the crank correct? |
12-01-2008, 10:44 PM | #61 |
PROJECT 7DEUCE
If your saying cg is getting those wheels I can tell you right now he only likes hub caps Truck sounds good glad to see that your outlook on a little set back has changed.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-01-2008, 11:01 PM | #62 | |
PITbut
Im reading your build thread now. What carb is that your running.. My motor is slightly built, but im running the stock 750cc quadrajet carb. I dont know how i will like it, but i was more looking for reliability and longevity... So far so good. Fires right up. LITERALLY. ahaah |
12-01-2008, 11:25 PM | #63 |
PROJECT 7DEUCE
Im running a double pumper holley not real sure on the size? Btw back in high school they called me fyrhazrd for a reason...
12-03-2008, 12:15 AM | #64 |
laying low
This is lyrikz wife.
[/QUOTE] Oh man! Look out guys, it's THE LOOK. Women give THE LOOK every now and then when they are suspicious and unsure if the guy knows what he is doing or not. All the while thinking he spent all that money just to watch it go up in flames and I coulda had a new living room suite?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 12-03-2008 at 12:17 AM. |
12-03-2008, 10:02 AM | #65 |
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
12-03-2008, 10:37 AM | #66 |
BlahBlahBlah
LMAO...I do love my hubcaps thats for sure. I also love the wheels from when I was a kid getting into cars and trucks too. These chrome daisys might look cool on a future ride.
12-03-2008, 12:58 PM | #67 |
PITbut
Oh man! Look out guys, it's THE LOOK. Women give THE LOOK every now and then when they are suspicious and unsure if the guy knows what he is doing or not. All the while thinking he spent all that money just to watch it go up in flames and I coulda had a new living room suite? [/QUOTE]
HAHAHA. No, what that look is me showing her the cool wire tuck and wrap i did. She was impressed.... ahah |
