12-11-2008, 02:47 PM | #51 |
Re: disc brake conversion question
i dont know why, but i always reffer to the control arms as a-arms, thats why i was confused. but i am not swaping out the crossmembers. I am going to ask this one more time since nobody has given me a for sure yes, but do i need the 71 ball joints in my 69 a-arms?
12-11-2008, 03:06 PM | #52 |
Under Construction
if you took the upper/lower control arms from the suburban and the ball joints are good , you can use those. If you didnt get them you will need to install upper and lower '71 balljoints in you '69 a-arms. the balljoints used for drum spindles are different from disk spindles.
*** another option ** if you have or can get the upper/lower 71 a-arms use those as is or replace the balljoints if needed, and you could try selling the drum assemblies with a-arms,spindles etc. to recoupe some $$.... Good luck!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-11-2008 at 05:29 PM. |
12-11-2008, 05:20 PM | #53 |
ok, thanks a bunch
