#51 |
Wide Eyed User
Re: 1962 Fuel Cell dimensions
Yea.. I have thought of that... probably will end up doing that, unless I find something better.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
#52 |
[QUOTE=DaddyMack;3109987]Here are some pics of my progression and the finished install. I still need to get a new cross member for the rear.. it will have to be custom to go across the rails at rear, unless someone knows of one ready made?
cutting away cross member ![]() I purchased a 4" x 36" channel, custom cut and fit across the back to box in the rear, good protection for the tank. I will post some pics tomorrow. looks like your rear cross member under the tailgate is off a 63-66? the bolting points are inboard of the frame rails? A cross member like what I am talking about would solve your mounting issue for that.
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
#53 | |
Wide Eyed User
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 01-28-2009 at 02:02 PM. |
#54 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If it was a '60-'62 rear sill these mounts would be on top of the frams rails. Not trying to be an a$$ just saying what I see. If you were to put a crossmember there as you are talking about, you could just bolt the rear sill to it like 62chevystep said also.
#55 | |
Yep they should bolt here (yellow Circles) ![]()
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 Last edited by 62ChevyStep; 01-29-2009 at 01:55 AM. |
#56 | ||
Wide Eyed User
Didn't think you were... ![]() Thank you in advance for the pictures..
#57 |
Here ya go DMack
#58 |
And the some more
#59 |
#60 |
Wide Eyed User
perfect!! thanks... I like it. notched, welded and all the holes are intact for attaching the bed rail (new one in my case..lol).
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 01-30-2009 at 12:57 PM. |
#61 |
Sunburst C10!!!
what do you mean by foam in your tank
![]() heres the setup i have
Gage 1967 C10 Shortbed Stepside |
#62 |
"Where were you in '62?"
![]() Join Date: Jul 2004
The cells have foam in the base to prevent fuel aeration and sloshing.
http://store.summitracing.com/partde...5&autoview=sku Here are some pics of the Fuel Cell, and how it's mounted on to the frame. http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#63 |
Sunburst C10!!!
can you actually see the foam inside the tank
#64 |
![]() Yep! The fuel cell is a rectangular box filled with foam to prevent the fuel from sloshing around too much. When you put gas in it you just put the gas pump nozzel right on the foam. ![]() ![]()
#65 |
Sunburst C10!!!
mine doesnt have that
did you put the foam in yours
#66 |
Yep it sure did. I got it from Jegs.com.
You can buy the foam to put in it. Fuel Cell Safety Foam http://www.jegs.com/webapp/wcs/store...2Bmatchpartial
#67 |
Sunburst C10!!!
how many do you have to put in there
do you have to alter your fuel lines
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-06-2009 at 09:48 AM. |
#68 |
60-66 Nut
Just a little FYI.....I've read that some guys have had issues with the foam breaking down after a while and causing problems with plugged filters and carb problems. I don't remember if it had to do with running race fuel, or just having the foam in the cell for a couple years or so.
#69 |
Sunburst C10!!!
thanks
i probably wouldnt need it anyway
#70 |
when you have the rear bumper on can you see the tank at all if you look at it from behind or does it sit flush in there so you dont see any tank hanging?
#71 |
Wide Eyed User
Not really on mine. I had my tank custom made for me with my own plans I drew up. My tank is deeper in the front and shallower in the rear. Still holds 20 gallons.
#72 | |
![]() Quote:
![]() http://www.enertechlabs.com/ethanol_in_gasoline.htm I need to find out when it is need to replace the foam after years in use on these since mine came with it. I may just take it out all together to be on the safe side and save me future troubles.
#73 | |
![]() Quote:
Page #5 http://67-72chevytrucks.com/vboard/s...=321173&page=5 ![]()
#74 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
This one would probably hang down to low.
And at only 27 inches wide, I'd feel like I'm wasting 9" of space if it could be 36 inches wide for my 65 on a 62 frame. portland.craigslist.org/clc/pts/3487760429.html Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
