09-06-2011, 02:08 PM | #51 |
"Where were you in '62?"
Re: 1960-66 Chevy/GMC Truck Frame Diagram
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
09-06-2011, 02:44 PM | #52 |
When I first saw the diagrams I thought I won't need those, but after thinking about it for a couple or seconds I thought of a couple of measurments I might need.
Thanks |
02-03-2013, 02:34 AM | #53 |
Does anyone have frame dimension charts for the 1960-1962 C-60 L-60 series 175" wheelbase with the X brace? And any type of photo? Thanks!
02-03-2013, 04:20 AM | #54 |
I guess I'm going to be the bad guy here, because we all know that both GMC & Chevy were NOT the same for these years of Trucks, just keep that in mind when posting and reading this forum, if it saids Chevrolet on it it done not mean its the same as GMC. Other then that nice scans.
Jolly ~ The 6066 GMC Guy Try the 6066 GMC Guy Facebook Page Jolly's Truck & Car Show Page! |
02-03-2013, 11:14 AM | #55 | |
02-03-2013, 11:15 AM | #56 |
07-19-2013, 12:00 PM | #57 |
07-19-2013, 12:39 PM | #58 | |
Does anyone have a cleaner larger version of this diagram? Also seeking a dimensions chart (and any photos please) for the 2 ton long wheelbase (and says school bus too) that also has a X brace like below: Thanks in advance for posting the charts here! Eric |
08-11-2013, 05:49 PM | #59 |
I bought this truck a couple of weeks ago and have put an engine in and got it running but the wiring is a mess. I was wondering if any body has a wiring diagram for this truck. Thanks it is a 62 G M C 1/2 ton short fleetside
08-20-2013, 08:35 AM | #60 |
I am new member just got a 1965 GMC V-6 trying to learn how to rebuild could I call you by phone to learn at 74 I am not very good on the computer I have been looking on this site and found your post you made 1-26-2009 about body digrahams and vin # my vin # is 1502pf5724b how can I decode this it is a 4 speed on the floor
Thanks for any help you can give to Bob |
08-20-2013, 08:51 AM | #61 |
Thanks for bringing this back TTT. I was just looking for this yesterday and wasn't having any luck-think I typed in the wrong search.
Awesome info! wouldn't by chance have the same info for a '64-66 Tilt cab, would ya??? |
11-30-2014, 02:20 PM | #62 | |
Do you know what the difference is in the rear between 60-62 and 63-72? I see all part numbers for suspension etc. go from 63-72 but it looks all the same??? |
11-30-2014, 04:28 PM | #63 |
The trailing arms are same, springs, bags. Not the same shocks, Panhard bar, extra stuff we don't need like crossmember. The x frame is wider and shaped different for notches and gas tanks.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
11-30-2014, 04:36 PM | #64 |
Here is a few shot before and after arm exchange and shock relocated.
11-30-2014, 04:47 PM | #65 |
Thanks!! I bought a rear bag kit from ridetech and am about to tackle the install, but had to get the 63-72 since that's all they offer. So the shocks may not work? Any clue what the difference in the shocks is? Sounds like everything else should bolt in.
11-30-2014, 06:08 PM | #66 |
My Ride Tech kit came with shocks and were way too short. You might use for front. I thought they stoped sending shocks. I been on Schrader valves for a while. Now getting ready for Porterbuilt front and Accuair control.
11-30-2014, 09:22 PM | #67 |
I've got shockwaves up front and the rear kit came with ridetech rq shocks. I have the full digital E3 ridetech set up.
02-14-2016, 09:37 AM | #68 | |
Is there any chance you have one of these for a '36? A very good friend of mine is building a frame for one, so I've been trying to track one down for a while, but have come up with nothing so far. If not, are you able to point me in the right direction? Thanks! |
02-14-2016, 02:59 PM | #69 | |
I'm sorry I don't but here is some info on these links below. https://www.gmheritagecenter.com/doc...olet-Truck.pdf http://www.oldchevytrucks.com/blog/i...icles/1934-46/ https://www.google.com/search?q=1936...es+%26+Chassis http://www.progressiveautomotive.com...short-bed.html
02-14-2016, 04:03 PM | #70 | |
Thanks again. |
02-14-2016, 04:10 PM | #71 |
what are you needing to know specifically?
ron |
02-14-2016, 04:25 PM | #72 |
02-14-2016, 04:36 PM | #73 |
good luck. you might find someone on stovebolt .com. there are some old chev restoration groups that are around and as mentioned the GMC historical site. I just thought of something that I will have to check out. think that it was in alberta
everything was pretty standard in concept from 32 -54 in the chassis dept. ron sorry can't find the info Last edited by padresag; 02-14-2016 at 05:03 PM. |
02-14-2016, 06:32 PM | #74 | |
Thanks for the info, i'll see where it takes me. Really appreciate the effort. Thanks again. |
01-21-2017, 02:17 PM | #75 |
But Found Her 25yrs Later!
I'm going to take this and load it into CAD.
Then can overlay the newer generation frames over it. That way members can have a visual of how the frames differ.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
