02-16-2009, 07:00 PM | #51 |
Luv the Crewcabs
Re: Another Crewcab build
Any Pics or Detail on how you are Doing the Rear Door? Are you leaving extra Material on the Cut to Fold over to make the Seam along front edge?
You Sure are Coming along Fast on this........... Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
02-16-2009, 08:49 PM | #52 |
chevy only
thats just cool very cool
CHEVY ONLY... Nothin Else ! |
02-17-2009, 01:02 AM | #53 |
There wasn't really anything to take pictures of yet. Right now I'm figuing out where to cut the inside of the door. Once thats worked out I'll post pics. As for the door skin, I left it an inch to fold over just like stock. Wouldn't you know that corner of the lower doorskin was fine, but the lower rear corner is rusted and needs patched next.
02-23-2009, 02:24 AM | #54 |
You work like I do; plan as much as you can in theory but figure it out as you go in reality. Otherwise you will never start! Looks like it's doable to me. I need to check this thing out. When does the burb roof arrive?
02-23-2009, 08:23 AM | #55 |
You all are some sick individuals in this group
Man you guys know your stuff... gotta love it. Cant wait to see more pics
1st project 66 SWB Dave |
02-23-2009, 05:32 PM | #56 | |
That's it though, lay it out in CAD, measure things a bit, then snap a chalk line, and start cuttin. I think better on my feet. The last couple of days I have realized that even the second go at my front doors isn't right. The rear post on the door curves in to the top when looking from the rear, and I think it curved a bit when you look down from the roof too. The front post though is flat and straight like a... well never mind. But I do have a spair pair from the donor doors that I cut for extra top material, so in the end I think the front doors will have two 'A' posts. I'm sitting in a motel in South Carolina right now, the inlaws are coming to visit for the weekend, two buddies need parts for their cars (one is a shifter for an old Brabham F3 car, and the other needs parts for his dirt latemodel). So it might be a few days until I get back on track. Oh, yea the burb roof is supposed to show up this weekend... After looking at one in the wrecking yard a couple weeks ago, I'm not sure how usefull it will be. The drip rails seem to be formed differently, and I hadn't noticed before but there is now inner roof panel. I think I can form up a long piece of new drip rail, but I'll probably have to use some of the new roof for the inner roof too. (and I'm starting to get distracted by the corvair in the driveway... picked up some urethane bushings for the front suspension, and some rod ends for the rear.... then there is the racing season just around the corner) |
02-23-2009, 06:54 PM | #57 |
Resistance is Futile
The burb roof is 2 piece, I believe. The assembly manual for 60-66 shows it fairly well. Im not sure where the division is, exactly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-23-2009, 07:10 PM | #58 |
The one I looked at in the wrecking yard had runners inside for attaching a soft headliner, but no metal one. It might have been a GMC that I was looking at if that makes any difference... now I gotta go look at pictures.
02-23-2009, 07:18 PM | #59 |
Here's what I saw. Bare roof panel, with runners across, and a kind of trim piece along the edge.
02-24-2009, 01:28 AM | #60 | |
02-24-2009, 01:46 AM | #61 |
60-66 Nut
All Burb/ Panel, Chevy/GMC roofs are the same as that. If it were me, I'd just do an upholstered roof in the crewcab utilizing the Burb style roof. Just my .02
02-24-2009, 02:09 PM | #62 |
1961 crewcab
and the crew cabs used the burb style roof/headliner-
02-26-2009, 08:25 PM | #63 |
1961 crewcab
my idea for using a sub roof on a crew build, is to cut the windshield posts of the pickup cab, and splicing in the whole sub roof, connecting it across the top rear of the cab in the driprail.
my reasoning for thid, is that the sub would have a consistent drip rail running front to back on the sides. the problem with putting 2 truck cabs together front to back, is that the windshield area is quite a bit narrower than the rear of the cab, and the driprail runs out at a steeper angle than the sub.... |
02-27-2009, 01:36 AM | #64 |
60-66 Nut
My thoughts on using a Burb were along the same lines, but using mostly Burb....roof, firewall, and front floorpan. Then adding a pickup rear cab panel and floor, and going from there. Sorry for the hijack 66Z71
02-27-2009, 10:24 AM | #65 |
No problem. I can use all the suggestions you guys have. Thats why I started this thread when I started the project. This is all new territory for me.
03-01-2009, 07:06 PM | #66 |
Sweet project, nice work. Good luck!!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
03-02-2009, 12:19 AM | #67 |
Any progress this weekend? The phoochop is the best looking one ive seen.
remeber lots of pics
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
03-02-2009, 03:02 PM | #68 | |
On another note, I got the Suburban roof Saturday. It looks every bit as good as I had hoped. Don't know if I'm lucky or not though. I posted an ad on Craigslist back when I started this looking for a roof, and the very next morning I get a reply from a guy 300 miles away that he has one. Turned out he needed to pick up a door from a guy just a few miles from me, so he brought me the roof, no charge. Well, talking to him Saturday I mention that the only thing left to find is a big back window cab panel. Well, you can see where this is going, he has one sitting in his back yard, and coulda thrown it on the trailer too if he had known I needed it. DOH !!! Here are a few other pics of parts that will eventually find their way onto the truck if it should ever get done. I should be able to find enough good parts in there to build a tranny & transfer case. Street Wheels, wife picked them up for $100. gotta keep the wife involved In looking for the ideal street/offroad tire it seems the only real solution is a pair of each. The good offroad tires are noise, and wear out quickly on the street, and smooth riding street tires don't go far offroad. So I'll pick up a pair of cheap steel wheels for the offroad tires, and use these for some nice all terains. On Board Air, so I can air down the tires when were off road, and refill the air tank in the trailer while were on our way to the track.. gotta love that. Hydraboost, I have it on my '94 Suburban, and it has saved my bacon a time or two when getting cut off while towing a big trailer. Rear disk brake brackets, and front spring hangers from DIY4X. Not the cheapest, but a reasonable compromise between $$ and quality. Anyways work is slow, so I'm gonna take a couple days off this week and stay home and play in the shop. Hopefully by next weekend there will be plenty to show. |
03-04-2009, 10:17 PM | #69 |
Daring to be Different
Man all I have to say is YOU HAVE BALLS to tackle this project. Nice work. Keep us posted.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
03-05-2009, 12:56 PM | #70 |
or total lack of brains...oh wait that's me your talking about.. well, then yea total lack of brains would be it. If I'd have known how much work this was gonna be, I would have just bought one.
naw, this is funner wait till tonight, I took yesterday, today, and tomorrow off work just so I could play with this |
03-05-2009, 09:28 PM | #71 |
Here it is....
a little bondo, and some paint. hey Alan what do you charge? |
03-05-2009, 10:43 PM | #72 |
Its looking good.Just an opinion, you should radius the corners of you doors like Frizzle Fry did to his.I stole the pic from his build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 Last edited by suicide 63; 02-27-2010 at 06:09 PM. |
03-05-2009, 10:56 PM | #73 |
1961 crewcab
wow! now those are some teaser pics!
more,more! on that driver door did you straighten that window frame out? it looks so from that angle... how did you do the rear door hinge/pillar, and do the dors interfere with each other when opening? |
03-05-2009, 10:58 PM | #74 |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
03-05-2009, 11:31 PM | #75 |
That's a funny place to put the Master Cylinder & Power Brake unit.
