#51 |
![]() Join Date: Aug 2005
Re: anyone ever autocross/road race their truck?
Does anyone know the actual stock steering ratio?
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) |
#52 | |
Still plays with trucks
Not a big deal in Auto-X but road courses where you might see some triple digit speeds it will help.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#53 |
I did a little cross reference work and found that the steering gear box changed in 1980 so the IROC box guts should fit into the 80-up square body gear box case.
Not as cool to have as the new 600 series box that came in some of the 99-up trucks but it at least it will give you the quicker steering ratio for a budget friendly price. The IROC box I have cost me all of $22 at the pull it yourself wrecking yard so with a 80-up truck donor box and a seal kit I will have about $80 into the quick ratio steering box for the 67 C-10. Much more budget friendly than the $400+ a converted old box would cost.
#54 |
I know the pieces fit
I just heard back:
John, We can custom build a 2.75 turn box for $225 plus $75 core deposit. It would take a few days to build. Feel free to contact us with further questions or to order. Thanks, Scott 1-800-399-7845 sales@CarSteering.com www.CarSteering.com Now that ain't to bad at all... |
#55 |
Has anyone else thought about using a Porterbuilt drop member? Lower ride height, narrow track width, bolt on rack and pinion steering. I'm sure a set of 295-50-15's would fit alot better with the narrow track. Scrap all the air ride crap for some coil-overs. I think it would be pretty trick...
#56 | |
I haven't done any measuring but I would bet it narrows the track width by a little just by where I know the frame stands for the motor mounts are located on the B-body frame vs. the trucks frame rails. Next time I am around a B-body I will take a front track width measurement to see. It may be possible to graft in the B-body front frame section like the older trucks used to graft in the F-body subframes but turning it into a bolt-in drop member would be better.
#57 | |
#58 | ||
One issue with the oe setup is the tire sits back in the wheel well. If you dial in a bunch of caster it's really far back. A lot of caster is nice because you get the appropriate camber gain when turning. This is good because you can run less static negative camber, which results in better braking a more evenly loaded wheel/hub so on and so forth. If this is the case and the Porterbilt drop member addressed this that would certianly be a plus. |
#59 |
That is the case with the Dropmember-it is very well engineered. And it has been performance engineered. Not only that, but he also makes a Dropmember that accepts C-4 (corvette) front suspension components-including the spindle and 13" rotor. And its re-engineered to complement the truck. Oh, and it moves the tire forward slightly to center the wheel.
#60 |
I went thru a dropmember post and found some answers for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=201898 Look at posts #5 and #47 especially. And posts #101, 114, and 121 for the C-4 details. |
#61 | |
I would go with a different spindle that could still use individual Timken wheel bearings that are inexpensive and a typical bearing hub. Something like CORE3 makes would be nice but a redrilled factory bearing hub from a drum brake truck or car could work too for a whole lot less money.
#62 | |
#63 | |
I like the idea of simple and inexpensive so the late truck 12" disc may be the way to go with just a slightly relocated upper A-arm mount point to give it 5 degrees of caster with a level shim stack and relocated crossmember mount bolt holes to center the wheel in the well.
#64 | |
#65 | |
My ideas I can implement for minimal investment using stock GM parts and will result in the best bang for the minimal bucks I have to work with. It will have its shortcomings but that is the price I will pay for working with next to nothing for a budget.
#66 |
The DM addresses the camber gain and centering the wheels in the wheel well. CPP and McGaughy's makes a 13" brake kit for the truck spindle. And CPP will be offering a 14" kit soon. I can't see any advantages of trying to put the B body suspension on a truck. McGaughy's even sells their set up with the 4.75x5 pattern if you really want them. I like the idea of sticking with the 5x5 pattern and upgrading to 5/8ths studs.
#67 | |
I am mostly converting to 5 on 4-3/4 to use up a bunch of spare parts I have sitting around taking up space. Camaro style rally wheels, larger pinion car 12-bolt posi with 4.11 gears, full set of four C3 Vette rotors and four matching 1.25" reach LS1 Camaro PBR calipers and a pair of C3 Vette front bearing hubs. I always upgrade to higher strength aftermarket 1/2" wheel studs so they should be plenty strong, the taller sidewall 15" tires will be my limiting factor.
#68 |
If you got a bunch of parts laying around that makes sense... I never liked the U-bolt on the lower control arms either. The DM does make a pretty good improvement there as well. I wish I could call Nate and order one up right now, but I'm in the same boat as everyone else.
#69 |
On the quicker ratio steering box quote, the price he gave me was only $30 more than a reman replacement. So the price is OK, but 2.75 turns LTL doesn't seem like a big improvement, at least to a novice like me. I've been reading an in-depth discussion here that let's me know we have some members who have been there and done that. I did reply and ask if 2.75 was the only option but haven't heard back yet.
Is that a quick enough ratio for a driver? 2.5 or 2.25 sounds much better, but without hands-on experience I don't really know what to ask for, or more accurately - I don't know what I really want and don't want to fall into the 'more is better' trap. Thanks. |
#70 |
TTT for good info!!
#71 | |
The difference between 2.75 and the IROC 2.25 is huge. I started with almost the same thing at 3 turns on my Malibu and installed the 2.25 IROC box. Wow what an improvement. The car really reacts when you turn the wheel even just 1/8 of a turn.
#72 |
I did hear back, 2.75 ltl is the best they can do with the stock unit. The calculator says that's a 21% improvement. That may be all I need. I'll have to check it against some other cars in the driveway and see what the rest of them are.
#73 |
For the price of that rebuild, That seem like a worth while improvement.
06' GMC 1500 Crew cab..... |
#74 |
Did you ever have them rebuild the box to the quicker ratio? If so, what is your report? Worth the money?
