Old 04-08-2009, 09:33 PM   #51
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: 305 V-6 with dual Strombergs
"Different" is freakin cool!
Have you checked how everthing matches up? Are you going to need to do any porting and polishing so that it all matches up?
Old hot rodder that I am kin too use to double stack spacers under the carb and put a wire mesh in betwixt the 2 spacers to atomize the fuel.
Joey~AP is offline   Reply With Quote
Old 04-08-2009, 10:46 PM   #52
Corts60
Just here to tinker
Corts60's Avatar
Well, I'm pretty much learning as I go here......This will be my first dual carb set-up and, as far as i can read, it is the first time most anybody has seen dual carbs on a big block V-6.
I know that I definitely have room to port the vintage speed manifold to match the factory V-6 manifold, I don't think I will just yet because it's not like I'm trying to gain a 10th down the track ya know? So I figure just get 'er all bolted up and running before the car shows this summer and then when I pull the whole engine this winter, I'll match everything up nice and pretty.
Old 04-08-2009, 10:50 PM   #53
4dranch
Shloooooong bed member #2
4dranch's Avatar
Have you decided on breathers yet?
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 04-08-2009, 10:51 PM   #54
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Fred T View Post
A wye would be best, which is a vee with a leg. You get tremendous torque right off the bottom of the throttle. You do end up gasping for air at high rpm. But with these heavy trucks torque is what gets you there. A friend in high school had a 261 six in his 50 Chevy car, still had the one barrel carb with a tube under the carb. He could hook it up good enough to lift the front wheels a foot off the ground.
That's awesome! I'm hoping to gain a little torque.....I know this particular engine's peak torque is between 1200-1800 RPM's, and a factory 305 had about 250 LB FT. Maybe I'll even gain a little HP too since she only has 125.
When I pull the whole engine, I want to have a custom grind put on the cam so she gets a little thump, thump too!
Old 04-08-2009, 10:57 PM   #55
Corts60
Just here to tinker
Corts60's Avatar
What do you think about this one 4d? I already know the set-up is going to be too tall to keep under the hood, even without the spacer, so I have a picture in my head that has this breather sticking just a little out of the hood, almost like a shaker....
Old 04-08-2009, 10:58 PM   #56
texanidiot25
Eat My Rust
texanidiot25's Avatar
Chop the bottom of the T-manifold's flange off and weld on the adapter's intake flange?
texanidiot25 is offline   Reply With Quote
Old 04-08-2009, 11:50 PM   #57
protrash64
Resistance is Futile
protrash64's Avatar
Cort, I was looking at your set-up and its overall hite issue...my first thought was 90* it over. Will the carbs work that way? Kinda like VW set-up or something along those lines. Im sure you have plenty of room side-to-side under that hood.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-09-2009, 12:14 AM   #58
4dranch
4dranch's Avatar
[QUOTE=Corts60;3246487]What do you think about this one 4d? I already know the set-up is going to be too tall to keep under the hood, even without the spacer, so I have a picture in my head that has this breather sticking just a little out of the hood, almost like a shaker....
[QUOTE]
very cool..
Does the adapter only come in that hiegth? if not what about a machine shop. have them make you one shorter.
and with you doing all this work I think something like this will show them off alittle more just my 2 cents..
David,
Daughters 66 truck:
Old 04-09-2009, 01:07 AM   #59
texanidiot25
Eat My Rust
There is a member here who does CNC work, I think it's Mr. Beast, give him a PM if your looking at some custom work.
Old 04-23-2009, 02:22 PM   #60
4dranch
4dranch's Avatar
ttt
David,
Daughters 66 truck:
Old 04-23-2009, 10:42 PM   #61
Corts60
Just here to tinker
Corts60's Avatar
I know, I know. I had to switch projects and get my Nova on the road for a daily driver and she has been taking up all my time with the "little" stuff. Also I have been overhauling two Caterpillar 3608's at work and they also have been taking up my time. I am going to redo the brakes tomorrow and then I have a car show on saturday. Hopefully I can get started on the carb set-up sunday, still looking for a hood close to me though.....
Old 04-24-2009, 06:50 AM   #62
4dranch
4dranch's Avatar
just checking..good luck Saturday
David,
Daughters 66 truck:
Old 05-05-2009, 07:28 PM   #63
Corts60
Just here to tinker
Corts60's Avatar
OK, some new pics with the air filters. I hope to put the new set-up on tomorrow. This weekend I am going to look at a '62 GMC Suburban that still has the V-6 and GMC hood. If I buy it, I am going to use that hood to cut so I don't have to cut my original......
Old 05-05-2009, 07:30 PM   #64
Corts60
Just here to tinker
Corts60's Avatar
Now I need your guys opinions....Should I cut to seperate holes for each air filter or should I cut one oval in the hood for both? I'm thinking about only 1" of the air filter will stick through the hood, which I think might look pretty sick...
Old 05-05-2009, 07:53 PM   #65
justcuz
justcuz's Avatar
Find an old Ford super duty hood scoop. Pontiac used them on the early Lemans drag cars. They look good and won't show that you molested a stock hood! The scoops came on late 50's early 60's medium duty trucks. Like the picture included. I would think up in Oregon you would not want the air filters exposed to the weather.
justcuz is offline   Reply With Quote
Old 05-05-2009, 08:01 PM   #66
Corts60
Just here to tinker
Corts60's Avatar
Ooh, I like that. And period correct to boot! Maybe I might have to do a little hunting....
Old 05-05-2009, 10:27 PM   #67
texanidiot25
Eat My Rust
That would be slick. Just don't say it's ford.
Old 05-05-2009, 10:48 PM   #68
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
I'm liking the Furd scoop, too. It's too bad you have to cut your hood. I freakin love your truck.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-06-2009, 12:08 AM   #69
texanidiot25
Eat My Rust
It's all sheet metal, nothing that can't be fixed.
CUT IT UP!
Old 05-06-2009, 01:02 AM   #70
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Originally Posted by jonzcustomshop View Post
if not you might try that big ford truck scoop from 60-63 that they used on the superduty pontiacs, I think they might repro them...they would look period correct.
what I said!!
btw 62 gmc hood is different... your style is 60-61.
I would snoop around on some pontiac websites about that scoop... they used it on the superduty ponchos, and GM even gave it a GM part #.
Old 05-06-2009, 01:16 AM   #71
justcuz
justcuz's Avatar
Jon you are right, however you stuck it in the middle of your post with no pictures. Cort could not visualize it!
Old 05-06-2009, 02:15 PM   #72
Corts60
Just here to tinker
Corts60's Avatar
Yeah, I really want another 60-61 GMC hood to cut up but they just ain't easy to find....
Old 05-06-2009, 06:37 PM   #73
jonzcustomshop
1961 crewcab
why don't you do a road trip this summer?
take the hood off your truck, come up to our car show at the end of july, and then we can run over to kelleys in arlee, he has about 10 of them....and you can drive it home!
we are only 8-10 hours away....
PS: PM kdrodworks316.... he had one of those in good shape last year, he is an over the road trucker, he might be able to get it close to mid/eastern wa. for you.....
Old 05-06-2009, 08:37 PM   #74
Corts60
Just here to tinker
Corts60's Avatar
That sounds awesome, but I will be in Juneau at the end of July for work. Crap. Any other car shows up there this summer?
Old 05-07-2009, 07:07 AM   #75
jonzcustomshop
1961 crewcab
There is a big one in polson.. cruisin by the bay or something like that, might be in august. there is a relativly fun one put on by the missoula downtown assoc. at the end of june.. 23/4th? friday night they shut down the downtown for cruising only for 2 hours.
most of them should be listed in that northwest cruisin' magazine, if you can find one.
