03-26-2009, 11:20 AM | #51 |
Happy to be here
Re: Bent Custom and Performance Back-half
I am not a big fan of Watt's links as I like things uncluttered. That is the cleanest application I have seen.
03-26-2009, 11:55 AM | #52 | |
To re-phrase the question . .... How much more drop does this allow vs. a stock frame w/a 3" c-notch?
03-26-2009, 01:42 PM | #53 |
This is quality work... it should impress everybody.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-26-2009, 01:57 PM | #54 | |
www.bentcustomandperformance.com |
03-26-2009, 02:57 PM | #55 | |
03-26-2009, 03:32 PM | #56 |
Actualy I think it's more. The 2 1/8 is where it is now. The stock trailing arms sit up higher the way my set up is. In a stock set up the rearend is actualy below the frame rails. So I think it is a lot lower than 2 1/8.
03-26-2009, 03:52 PM | #57 |
Velocity Speed Shop
Question? What tool did you use to punch the holes in the trailing arms?
--------------------------------------------------- My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143 My Garage ..... http://www.hubgarage.com/mygarage/OCD69 |
03-26-2009, 04:41 PM | #58 |
Is the rear section 3x4"?
03-26-2009, 08:32 PM | #59 |
Punch flares from Mitler Bros.
03-26-2009, 08:32 PM | #60 |
03-26-2009, 11:57 PM | #61 |
03-28-2009, 09:38 PM | #62 |
what grit finish are you doing on the steel in these pics and what tools and steps are u taking to achieve this? i always loved how rad rides did this and was wondering how to do this economically so customers get that wow factor when they see their stuff in my shop
03-29-2009, 03:36 AM | #63 | |
03-29-2009, 02:01 PM | #64 | |
03-30-2009, 11:29 AM | #65 | |
I'm just glad to be here!
I know in an earlier post you said the frame is cut from flat sheet then welded together. What type of steel sheet did you use? Hot Rolled Pickled & Oiled or Cold Rolled sheet? Can't wait to see more progress..!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-30-2009, 08:33 PM | #66 |
Unfortunately the water jetter used hot rolled. Wasn't to happy. It should be cold sheet 1010 or 1020. Welds and grinds really nice. Just better quality all around.
03-30-2009, 08:35 PM | #67 |
Buy the way we will be starting on the front half very soon. She's getting a heart transplant also. 5.3 and 4l60 conversion. This truck my friends will be SICK!!! Stay tuned.
03-31-2009, 01:27 AM | #68 |
Using a 5.3 seams dismal compared to the work going on out back. As always, beautiful work. How many hours are we looking at?
Mike Redpath |
03-31-2009, 10:23 AM | #69 |
Thanks Mike. As for the motor it's all about form and function. There's probably about 150 to 175 hrs. write know.
03-31-2009, 11:12 PM | #70 |
>130dB Moderator
The 5.3 can be a stout motor. A few extra goodies, maybe even a maggie, and you've got yourself a very respectable motor.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
03-31-2009, 11:33 PM | #71 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-01-2009, 01:19 AM | #72 |
Not questioning the motor itself, but the choice in a high end project. Money doe not seem to be an issue
Mike Redpath |
04-01-2009, 01:41 AM | #73 |
>130dB Moderator
"Impression" that won the Riddler Award back in 2005 had a very tame 340hp LS1. Many "high end" builds use very common and lower hp motors for a variety of reasons. Big cams and blower whine aren't everyone's thing. Some guys want a reliable car/truck that they can drive to shows and have a little fun with, but not have to hassle with a lengthy and expensive motor build that at the same time is completely unnecessary.
Now, they haven't touched on anything being done to this motor, but I'm more than willing to bet that it isn't just some crate motor. It will have some bolt on goodies at the very least. Personally, I love factory/crate motors. Some of the best and most reliable out there, that's why I chose one for my truck. 400+ factory rated engineered horsepower and matching torque in a smog legal, completely reliable, package. You really can't ask for much better for the money.
04-01-2009, 08:25 AM | #74 |
ummm........what is a maggie???
CHEVY ONLY |
04-01-2009, 08:29 AM | #75 |
