05-02-2009, 10:48 AM | #51 | |
high-Tech Red Neck
Re: "The Beast" 85 Chevrolet Crew Cab Dually
The thing you have to realize is this, it all depends on gear ratio. The 700R4 has a 3.06:1 first gear, 1.63:1 2nd, 1:1 3rd, and a .7:1 4th The NV4500 has a 5.61:1 first, 3.04:1 second, 1.67:1 3rd, 1:1 4th, and finally a .73: 1 overdrive. So in other words 2nd gear on a NV4500 is like being in first gear on the 700R4. The hardest part about doing that swap is building the new cross member for your transmission. Here is something else to consider, the tire size you want to run is going to dictate what rear end ratio you run as well. The Dana 60 is a great axle, but many of them came with 4.10 gears or even 4.56'es in some cases to help you lug a load. If you run a 31.5" tall tire, (which is what most load range E's are) your engine will have to turn 2,235 RPM to go 70 MPH Where as if you run a 25" tall tire with 4.10's you are looking at 2,817 RPM to go the same 70 mph. Now if you went with a 3.55 rear end ratio, and a 27.5" tall tire, you could then run 70 MPH @ 2,258 RPM. What is the difference? It is fuel mileage, the lower you can get your engine RPM's the better mileage you will get at least to a point. And as per our conversation with your current tires being 31" tall, that means with your current 4.10 rear end you will pull 2,271 RPM @ 70 MPH And just for giggles, with your current 4.10 and the 1:1 final drive ratio of the TH350 and a 30" tall tire, you have to turn 3,112 RPM to go 70 MPH! So installing a NV4500 alone will get you a 841 RPM drop. In other words that is a 27% drop in engine rpm. You decide to do the swap let me know, I know everything you need having done it myself a few times.
"He used to be a pretty nice feller, now he's a welder!" |
05-02-2009, 09:24 PM | #52 |
high-Tech Red Neck
Today has been a pretty damn productive day, I figured out that it was my fuel tank selector switch that was keeping the tank from switching, which is way better than the valve its self because those are a pain in the butt to change.
I also got the AC blowing cold, and soon I am going to head back out and start on the heater core. I am hoping that by the end of tonight that I can have the dash completly reassembled. Tomorrow I will be getting the bracketry for the Passenger side seat built so I can get it mounted and get the carpet put back in. When all that is done, I am going to have a runner on my hands for sure. I am really looking forward to it. Also tomorrow the luggage rack on the roof is going bye bye and I will be getting all the holes welded shut, then touching it up with a little rust oleum. Oh, and somwhere in there too, I am going to try to get my stereo installed. I want tunes! and I miss my sirius radio.
05-02-2009, 10:10 PM | #53 |
Resident of Here
Love this build as much as your 72. I'll be doing an NV4500 or NV5600 swap into my K10 eventually. I'm hoping to have 33" tires and 4:10 lockers. My diesel should be getting even better mileage then! Maybe 26? Now with the R4 I get 22 hwy.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
05-02-2009, 10:27 PM | #54 |
high-Tech Red Neck
Actually you wont get any better mileage, the R4 actually has a slightly taller overdrive, it isn't that much of a difference, but it does, going to taller tires hurts mileage, so you will probably wind up back at 20.
05-02-2009, 11:03 PM | #55 |
Eat My Rust
But one thing to take into consideration is the lesser parasitic drag the manual has over the auto. Although, for an auto the 700R4 is fairly efficient (only known for a 14% power loss if I recall right), a manual is still more efficient. Meaning less work on the freeway for the motor.
05-03-2009, 12:16 AM | #56 | |
high-Tech Red Neck
05-03-2009, 11:40 PM | #57 |
high-Tech Red Neck
Im workin on the passenger side seat brackets, got one welded up, more pics to come.
05-04-2009, 07:14 AM | #58 |
great southern land
wow, this sure coming along nicly, u sure have put in some hours on this. well done mate
rod 86 chevy c10 silverado |
05-04-2009, 09:45 AM | #59 |
Resident of Here
What did the NV4500 come out of? Remember, it can only handle max of 14,500 GVW. So F450's might be out of the question.
05-04-2009, 10:03 AM | #60 | |
high-Tech Red Neck
The weak link is the output shaft, if you replace it with a different design shaft that has a full seat for the gear, you run the right oil in the tranny, and you don't abuse it under load you should be fine.
05-04-2009, 10:03 AM | #61 |
high-Tech Red Neck
5 AM last night!
05-23-2009, 12:35 AM | #62 |
high-Tech Red Neck
So the girl is here, and she is amazing!
The truck however has a blown transmission, it is not so amazing, I am seriously considering installing my Cummins an a NV5600 in it. I just don't have the 5600, going to have to do some searching around and see what I can come up with. Going to be a while until I have the cash anyhow, so its going to be parked. Back to work I go!
05-23-2009, 12:40 AM | #63 |
great southern land
any pics of her?
05-23-2009, 02:28 AM | #64 |
Garage wrench
see bottom of post #1.
Congrats on getting her home. The truck can be fixed, just takes time and money. Why did the NV4500 take a dump?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
05-23-2009, 09:15 AM | #65 |
high-Tech Red Neck
I bought a tow truck and drove up to the Waco area to get it, I towed the 85 back with the tow truck, well on the way back the transmission sprung a leak, dumped the fluid, and what little was left inside caught on fire.
It was not a shiny happy time.
05-23-2009, 11:01 AM | #66 |
Resident of Here
The NV4500 blew? Did you see how it ran before you bought it? Also, did you use the right oil? There are SPECIFIC oils that have to be used in the NV4500 any other oil and it will blow up.
05-23-2009, 11:49 PM | #67 | |
high-Tech Red Neck
The transmission had the Castroil Sintorq that is specific for the NV4500 in it. I might be able to rebuild it, I am not sure yet we will see. I need to pull it out of the truck and see what kind of damage was done.
05-24-2009, 12:34 AM | #68 | |
Resident of Here
05-24-2009, 06:56 AM | #69 |
great southern land
damn what a shame, hope u get it all sorted....
05-24-2009, 09:02 AM | #70 |
high-Tech Red Neck
Well I can find another 2WD NV4500 for about 400-500.00 so that isn't going to kill me. I think the worst of it is going to be getting the smell out of the cab.
The thing I can't decide right now is weather to put my Cummins in the 85, and set it all up, or to finish building the 72, and put the Cummins in that. Kind of a tough decision.
05-24-2009, 10:10 AM | #71 |
Resident of Here
Buy another Cummins and put one in each!
05-24-2009, 12:51 PM | #72 |
Looks good! That door you cut up looks better than the one on my truck now! lol
05-24-2009, 01:00 PM | #73 | |
05-24-2009, 08:55 PM | #74 |
Dually Pride
put the Cummins in one and buy a 6V53 Detroit for the other!
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
05-24-2009, 10:05 PM | #75 |
high-Tech Red Neck
I am tempted to put my 7 cab on a duce and a half frame, but.. I want it to be functional.
