#51 |
Re: My Accuair e-Level Install....
Hey I checked out your ride and the new system today. Their new system looks to be very promising and I think I will be setting one up in my 72 Tahoe here very soon.
Reno it was nice meeting you today and I look forward to doing business with you in the near future. Kevin LFD Inc. |
#52 |
PorterBuilt Man Crush
![]() Join Date: Jul 2007
Welcome to the board!!
I will have to be the first to ask. Will members of the board be given a discount as with most of the vendors here. I am getting close to needing a system for my build, and I like what I see. One question, will the leveling system only work with your valves, or would I just need an adapter for the connection. Thanks, this looks like a very well designed system.
The 72 will live again |
#53 |
If I read correctly they will work with all 12V valves and they even have some adapters so it is a plug and play system. If you have a valve that they do not have a plug for then you will need to wire it up your self.
Kevin LFD Inc. |
#54 |
Rokcrln, I'm glad you got to see the system in person. We got my system finished Thursday, and drove it Friday. I was blown away by how the system adjusts. Did Reno happen to show you how the system adjusts for weight being added after it was already at a set height?
Long63, the wishbone mounts to a tube welded to the rearend. The front of it mounts to my frame. I have no side to side movement. I am going to do a movie in the next couple days. When I do I will post it. Here are some pics from the show.... |
#55 |
MY EX DRIVES A BROOM
subscribing
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#56 |
And I used to think burbs in this body style were ugly...
#57 |
Thanks!
I will post a video soon. I am going out of town this weekend and will try early next week to get a video online. |
#58 |
One day.....
Subscribing to keep myself informed.
DZL1. |
#59 |
Head Peon
![]() Join Date: Dec 1999
I'm down for a group buy if it can happen in the next couple weeks...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
#60 |
I see the Salinas Boys coupe on your site. I love that car.
I am very interested in this system. There are a few things I don't quite understand about the ride height setting. Do you manually set one ride height and turn the system on and it sets it to that height at all times? Or can you select more than one height? Does it tell you what height you are at, or do you select a few heights you like and use them like radio presets? My computer struggles a bit with navigating the site, but I don't think I can find a price for the system? I have a personal project I am working on right now that I am interested in using this on. It's a full frame project, spindles and all. It will be a very visual chassis, so I would like to install this during the build process so it doesn't look like an afterthought on my end.
If you can find it cheaper, I can fix it! |
#61 |
You set one button for low, ride and full up. As for telling were you are at height wise a simple look at the lit button will tell you. So yes it is like a radio pre-set. Then the system learns how your vehicle reacts to each height change and then the next time it will be faster and more accurate until after a few times it sets you at the proper height at the first try with out the annoying up and down some systems give until it is set right.
I personally will be running this on my 72 C4 Tahoe 4dr. Kevin LFD Inc. |
#62 |
Sorry for the delay on the video's. Here they are.....
#63 |
WTB this ad
Yea....I gotta get some o that!
Thanks for the vids!!! Last edited by see ten; 04-22-2009 at 05:56 PM. |
#64 |
i am saving up for one of these systems. hope to buy it in the next few months. if theres going to be a group buy i want in, someone send me a message if that happens.
i have a question about the tank size. can i use a smaller tank than the one you offer in the kit? i am not interested in speed and i will rarely be changing the hieght except when i am hauling loads. i am looking at a pancake style tank that will fit under the bed were the spare tire or fuel tank would go. just got my airlift 2600's from SD. thanks for the video thats what i was hoping to see. |
#65 |
Double 6's
just saw the videos and.........oh my god, oh my god, oh my god, oh my god......soooooo d&#n cool!!!! Im glad mines tore apart, I will be getting one of these for my truck!!!!
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
#66 |
I officially want this.
#67 |
wow............ any pictures of how you mounted the height indicators?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
#68 | |
Junior Member
![]() Quote:
![]() For the front on this one, we wanted to try mounting the sensor on the A-arm instead of on the frame. It works fine this way, but we usually do it the opposite... mount the sensor to the frame near the shock and run the linkage down to the A-arm. ![]() This isn't the best shot, but we just drilled the trailing arm where we found the travel was 2.75" (for the total suspension motion) and mounted the stand-off and ball stud through it. ![]() Here is what our height sensor kit comes with for each corner. The linkage is just a threaded rod inside, so it can be cut down to any length very easily. The tubing around the outside is just air line, so you can then cut it down accordingly. ![]() |
#69 |
Thanks for posting those pics.
So the 2.75" you mentioned. this is due to the stroke of the hieght sensor, correct? How did you find the exact location of that spot you attached the sensor? i understand you need to find that sweet spot between air'd out and air'd up is 2.75", but can you tell us how you located it. in the first pic it looks like there is a tab welded on the A-arm that the sensor bolt mounts too. am i seeing that right? |
#70 |
what is the stroke of the shocks you are using? compressed, extended?
#71 |
When the time comes to set up my air managment system, I will be running this for sure!!!!!!!!!!
Tony from Norcal |
#72 |
Plus seeing it in person on that layed out 60's burban at the goodguys show was very impressive. I love the controller it looks like an Iphone.
Tony from Norcal |
#73 |
Wide n'Low
![]() Join Date: Jan 2007
Nice, Gotta have this for Project 50th!
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#74 |
In case you guys have not seen this yet PorterBuilt is doing a group buy on this system!
http://67-72chevytrucks.com/vboard/s...d.php?t=341459 Kevin LFD Inc. |
#75 |
![]() Join Date: Apr 2005
OK, old thread but who has installed their system installed and working?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
