Old 03-24-2009, 03:22 PM   #51
tekno62
Re: questions for converting to TPI
Well now for the stupid question - would a TPI get me better gas mileage?
tekno62 is offline   Reply With Quote
Old 03-24-2009, 03:50 PM   #52
71swb4x4
71swb4x4's Avatar
Maybe a mile or two per gallon more, but not much more than that. The only elements you are changing on the engine is how the air and fuel is being supplied to the engine. The real benefit would be seen if you swap in an overdrive tranny at the same time, or if you like a manual go to a five speed or a six speed if you really want to get fancy.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-24-2009, 03:54 PM   #53
smoky02
Location: Sunny, Florida, some might call it South Alabama
I know my uncle has a LT1 in his 78 Camaro, and he gets 20 in town. And that's driving it lightly, he doesn't get on it at all. So I find it hard to believe that I'm going to go from Carb. to FI, and my mileage isn't going to improve alot. Cause I have a 700R4 and get about 12 in town. And 14 on the high way.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 03-24-2009, 04:19 PM   #54
tranz am
tranz am's Avatar
basically just a miniature gas tank. hmmmm interesting thought. so your talking about mounting a stock tpi fuel pump inside of this little box gas tank? and this stock pump your talking about, it is a stock tpi pump right?
Originally Posted by Andy4639 View Post
A stock pump is only about $60.00 bucks at O-riley's. A 350 305 stock motor don't need no more than 40 to 45 PSI. The intank one will go in place of a tbi unt one. I know I have one now for 15 years and it works fine. I've said this before fab up a small gas box to fit under the cab inside the frame rails. Make it big enough for the pump to go inside of it. Put a gravity feed line off the orignal tank to it and have all the return lines and such come back to this small pump tank under the truck. Shouldn't cost that much to have one done.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-24-2009, 04:20 PM   #55
tranz am
tranz am's Avatar
are you talking about a gen I lt1 or newer gen II?
My build thread
1969 GMC SWB
Old 03-24-2009, 08:15 PM   #56
Andy4639
Old member
Andy4639's Avatar
I'm talking a 86 early 90's TPI motor, not a lt 1 or later which yes you could do the same thing just have to have a high out put pump for those.
Yes build a little tank that would hold the fuel pump with all the neccessary fuel lines running to it and if it is gravity feed then all you do is fill up the orignal tank and as long as the gas gauge is showing fuel your good to go and want need the baffels either.
This car was the first one I saw with fuel injection in SC. It had this little gem in it.
Carolina Rod shop One Lap America car or Panel which ever!
Glen Dodd was the owner back then.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-24-2009, 11:29 PM   #57
71swb4x4
71swb4x4's Avatar
If you get the Jags That Run TPI book it describes exactly what Andy is describing. They run a little tank to prevent fuel starvation. It's only a couple ounces.
Old 03-25-2009, 10:29 AM   #58
tranz am
tranz am's Avatar
I'll look into doing that thanks
My build thread
1969 GMC SWB
Old 03-25-2009, 09:25 PM   #59
Jim Osborne
Hey man heres my 2 cents I went to TPI Specialtys and got a late 90s corvette ECU and it was real easy three wire hook up, also got a adjustable fuel pressure regulator it will help going from 305 to a 350. I also put my o2 sensor just before my header collector, as for as a tank goes you need to look at Rock Valley they can fix you up with fuel pump, sending unit & tank a little pricey but you get what you pay for, after all you want to drive it not work on all the time
Jim Osborne is offline   Reply With Quote
