04-15-2009, 10:39 PM | #51 | |
Re: Engine builder says to use valvoline 20w50
Agree 100%. I don't believe Shell Rotella has Zinc anymore....The only oils with zinc to my knowledge are racing oils like the Joe Gibbs line etc. From everything I have read, normal everyday engine oil, shell,pennzoil,amaco, etc has had zinc & phosphorus removed to protect catalytic converters and emissions. If your motor has a flat tappet cam, don't fool yourself, its just a matter of time before you wipe the cam lobes. New oil is not the same, just because its the same brand/weight/package etc. GM EOS (engine oil supplement) is the stuff to use, Lucus also has a comparable product, for additives if you want to continue using your "old faithful brand" you need this!
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van Last edited by chas350; 04-15-2009 at 10:41 PM. |
04-15-2009, 10:46 PM | #52 |
04-15-2009, 10:50 PM | #53 |
Sierra Grande Club
I put the VR1 10w30 and now I've noticed slight valve train noise that I'm pretty sure wasn't there before.
So now I'm going to drain this oil and put the 20w50 in, and see if it makes it quiet. (oil pressure is 30psi) I'll keep you posted on my findings. *Question* is driving this with some valve train noise a problem? It's 25 miles to Town. Please advise. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
04-15-2009, 10:54 PM | #54 |
There ya go! my next motor will!
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
04-15-2009, 11:14 PM | #55 | ||||
Sierra Grande Club
I remember the tech at Lunati saying you'll know if you'll have a cam failure real soon. Apparently once it starts in progresses very quickly. That seems to back up the statement from the Valvoline guy? Sure is cheap insurance to keep on using it though. Seems to be several people here using regular oil on high mileage motors with no ill affects. Quote:
04-15-2009, 11:14 PM | #56 |
All the light duty 3/4-1ton "big 3" diesel trucks have cats now. So the zinc/phosphorus in diesel oils will be most likely dissapearing soon or not.
You guys that don't want to run Valvoline 20w50 VR1, it also comes in 10w30. You may have to order it though as I never see it around here, just the 20w50 and straight 50wt at Autozone. Looks like as of 2006 the Delo 400 had the same zinc/phosphorus levels as the VR-1. Not sure if it has changed any now. Chevron Delo 400 Multigrade SAE 15W-40 meets: • API Service Categories CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF, CE1, CD1, SL, SJ, SH1, SG1 Chevron Delo 400 LE SAE 10W-30 meets: • API Service Categories CJ-4, CI-4 PLUS, CI-4, CH-4, SM, SL http://www.valvoline.com/products/VR...otor%20Oil.pdf http://www.royalpetroleum.com/Upload...00%2015w40.pdf Looks like a bunch of multi viscosity options with delo too. (May 2008) Their SAE 10w30 oil has the zinc. http://www.chevrondelo.com/deloperfo...aspx#delomotor |
04-15-2009, 11:18 PM | #57 |
I always use Mobil 1 10-30 and after I heard about zinc/phosphorous levels being reduced in oils I continue using Mobile 1 hoping that the cam would wipe and I could then get a built 383 in there.
"Unfortunately" it runs just fine and I am beginning to believe that for a stock,low lift cam you don't need any fancy,expensive oil or additive.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
04-15-2009, 11:19 PM | #58 | |
Sierra Grande Club
04-15-2009, 11:22 PM | #59 |
I have read that GM's EOS may be discontinued or the part number has changed. Seems like a rumor. Not sure though. There is still EOS out there to buy though.
04-15-2009, 11:23 PM | #60 | |
Our NAPA closed a few years back, but I will check with the local autoparts next time to see what they have. |
04-15-2009, 11:31 PM | #61 | |
Question of the day..... Old stock motor high miles= low spring seat pressures due to stock low lift & well worn cam lobes= less chance to wipe a cam lobe? New cam or performance cam=high lift=strong spring seat rate= more force to overcome todays oils and wipe out your cam lobes?
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van Last edited by chas350; 04-15-2009 at 11:32 PM. |
04-15-2009, 11:32 PM | #62 | ||
Sierra Grande Club
If he says he can order it I'll pass this on to you. I'm thinking he can't. s/t
04-15-2009, 11:34 PM | #63 |
Wow, I'm amazed at some of the things I've read in this thread. It's awesome that everyone is talking about this issue because it's extremely important but I can't believe some of things I'm hearing that the "mechanics" have said.
I'm a performance engine builder so I'm going to drop some info here just in case anyone is interested in using it. Definitely not trying to step on anyone's toes so this is just a "take it or leave it" kinda post. Most of this info will deal with "flat tappet" hydraulic or solid lifter cams. Roller cams aren't subject to the "zinc" issue. And it all has to do with break-in. Your camshaft will either be set or ruined in the first 25 minutes. 1. Most important!!!! Your break-in procedure for the camshaft is the #1 issue regardless of oil. The cam lobes and lifter bottoms needs to be coated with the assembly grease that came with them. During installation you need to pour an entire bottle of GM EOS all over the cam and lifters. It will drain down and mix with your oil in the pan. Once you're ready to fire it up you have to start your engine and immediately bring it up to the 2500 to 3000 rpm range. You need to vary the rpm between 2500 and 3000 for at least 25 minutes. This means you need to have your timing set and enough coolant in the engine so that it will run this rpm and not overheat/backfire. If you're having trouble starting the engine, don't keep cranking, figure out the problem and try again. The reason for this procedure is that the lifters need to mate to the cam. They do this by spinning. The bottom of the lifters aren't flat. They're slightly indented, it's just hard to tell it. Same with the cam lobes. They have a slight arch in them. The reason for varying the rpm is that it will cause the crankshaft to throw oil on different ares of the cam. Your cam gets its oil from what is slung up by the crankshaft. If one area of the cam doesn't get enough oil during the break-in then the lifter bottom will overheat and "microweld" to the cam lobe when you shut it off. The next time you fire it up, it will break loose from the cam taking a small piece of the lobe with it. This is called "pitting" That pit will destroy the bottom of the lifter and then the lifter will destroy the cam lobe. Now, the second most important thing to do is use the proper oil. It has more to do with what "not" to use. DO NOT USE SYNTHETIC OIL for break-in or the first 10,000 miles. If you've built a performance motor then don't use it at all. A synthetic oil is too slippery and this will keep your lifters from spinning on the cam lobe during break-in and they will never mate. It wil also interfere with this spinning at high rpm in a performance engine. As a tip, if you can have someone in the vehicle to control the rpm of the motor then you can run it without the valve covers in place. You can get a spash shield to catch the oil slung out by the pushrods. Watch the pushrods as they will spin with the lifters. If you see one that isn't spinning you can give it a spin with your fingers to help it start. (This is assuming that you've properly adjusted your lifters/rocker arms) Don't use a multi-grade oil either. Do your break-in with a straight 30w oil. The thicker the oil, the cooler it will keep the camshaft during break-in. Heat is a major factor. The GM EOS additive that you pour over the cam and lifters is the only additive you need. After you've finished the break-in procedure immediately change the oil. You can add more GM EOS to the new oil. Run that oil for about 500 miles (this is to seat the piston rings) and change it again. Now for oil theories. Shell Rotella oil was the only conventional oil you could get at your parts store that still had the zinc in it but that ended early last year. If you look at a bottle now it has that triple protection stamp on it including "emissions". That tells you that the zinc has been removed. So, Diesel oil no longer has any advantage over any other oil. As for multi-grades (ie 10w30, 10w40, 20w50) They are not 30w, 40w, or 50w oil. That second number means that they are "equivalent" to those wieghts after they've gotten "hot". They do this by adding "fillers" to the oil that keeps it from breaking down as much when it heats up. The down side is that you lose some lubrication as it's replaced by the "fillers". I use only straight 30w oil. This is actually thicker than 20w50. However, it thins normally as it gets hot whereas the 20w50 will be "as thick" as straight 50w when it's hot. Keeping your oil at the highest possible weight is not necessary. 90% percent of your engine wear (in a tight motor)_will occur at startup. Unless you drive at excessive rpms or overheat the engine. No oil will ever break the drive rod for your oil pump. And 20w-50 is not even as thick as straight 30w when it's cold so don't worry about that. If you run a straight 50w oil (perhaps your engine is old and loose) then you need to take it out before the outside temperature drops below 60. Oil that thick will not flow properly at startup and your engine will run dry until it heats up. Racing oil is not meant for street use. It will gum up. If you use it, make sure you change it every 1000 miles. That's gonna get expensive. Like I said, this is my personal info, and not meant to argue with anyone else's experience. Here's my recommendation for your engine's break-in. -Straight 30w, any "conventional" brand you want to use. (not synthetic) -GM EOS additive. -After break-in change it immediately. -Add GM EOS again -At 500 miles, change it again. -If you want to use a zinc additive, go ahead but it's not necessary once the cam has been broken in. -Do not use Synthetics or additives like slick 50 for the first 10,000 miles. If it's a performance (high rpm) engine, don't use it at all. Now, if you have a roller cam................ I've just wasted a bunch of typing because you can use whatever oil or procedure you want to! Last edited by highperf4x4; 04-15-2009 at 11:37 PM. |
04-15-2009, 11:36 PM | #64 | |
Sierra Grande Club
s/t
04-15-2009, 11:41 PM | #65 |
Just remember guys, (and gals) when you're talking about oil........ it's all about the camshaft. And when you're talking about the camshaft, it's all about the break-in. That first 25 minutes will make ya or break ya.
04-15-2009, 11:49 PM | #66 | |
Driven a 72
So quick question for ya. I have a motor with more than likely 200000 + miles and have some lifter noise. What oil should I run to help keep it going alittle longer. 20w50 straight 30w or straight 40w. I do live in a cold climate.
1996 GMC JIMMY 1972 CHEVY C10 LWB My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729 |
04-15-2009, 11:59 PM | #67 | |
If your hydraulic lifters aren't pumping up like they should then no oil is going to help you much. Just keep the rpms down as much as you can. Lucas Oil Stabilizer will help the oil "cling" longer without making it any thicker and this might help to keep them pumped up. Last edited by highperf4x4; 04-16-2009 at 12:00 AM. |
04-15-2009, 11:59 PM | #68 |
Someone mentioned delco filters..... be aware of what you are buying now day. I have heard that delco moved all manufacturing out of the U.S. Im not sure if this is true or not but I have been working at a family owned auto parts store since i was 16 and in the last few years not only have delco filters (most popular applications) shrunk in size, but also the inner mesh is now plastic instead of metal like the wix and other better brand filters....just keep an eye on it
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
04-16-2009, 12:02 AM | #69 | |
Driven a 72
Thanks for the quick reply. Guess im doing a oil change in the morning!
04-16-2009, 12:05 AM | #70 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 04-16-2009 at 12:07 AM. |
04-16-2009, 12:13 AM | #71 |
The reason this thread is important to me is my 402BB will be totaly rebuilt so when the Circuit Rider gets out of the body shop I want to be sure I break the engine in correctly. As said...this is a very good thread. Thanks all for their input!
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-16-2009 at 12:13 AM. |
04-16-2009, 12:24 AM | #72 | |
As for racing oil, I was referring to brands like Redline and Royal Purple. Valvolines VR-1 is closer to a conventional passenger car oil. I think it's pretty good stuff but not enough for break-in if that's what you're asking. |
04-16-2009, 12:29 AM | #73 | |
I've got the 402BB in my truck as well. Did you do a performance build or just a stock rebuild. |
04-16-2009, 12:49 AM | #74 |
Thanks for the info on Shell Rotella T changing its formula. I didn't realize that they had changed it. This has been a very informative thread. I love this board.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
04-16-2009, 01:02 AM | #75 | |
You'll know you lost a lobe if it progressively keeps getting louder. It's been my experience that a 15 minute drive is all it takes to wipe one clean, but if the damage has already started, there's no saving it. Last edited by Jim_PA; 04-16-2009 at 01:03 AM. |
