Old 04-19-2009, 09:56 AM   #51
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Well boys, I may be leaving the fold tomorrow
It should be delivered tomorrow. I'm about 100 percent sure I'll like this truck better than my 67-72s I've had lately. Life is short, why build the same truck over and over again ?
In my opinion, the older the better. The only reason I settled my search on a 63-66 was because the suspension and drivetrain is easy to update for small money.
I did an OLD Chevy once and it sucked. Babbit pounder engine, torque tube driveline and awful brakes. I had to completely build that car from scratch front to back, new rearend, open driveshaft, V8, auto, all new mounts, Mustang II front end to get good driveability.
I'd have bought an AD truck if it weren't for those issues. I drive them too much to live with that antiquated stuff every day and I'm too poor to build a catalog street rod ever again.
Old 04-19-2009, 10:21 AM   #52
Boog
laying low
Boog's Avatar
How similar are the frames Kevin? Would it be easier to just move the 63 body over to the other frame and not have to R&R all the suspension, engine, tranny, rear etc onto the old frame?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-19-2009, 10:46 AM   #53
Tx Firefighter
I haven't gotten a good straight answer on that yet. Obviously the big picture is the same, as crossmembers, axles, brakes, springs, etc all swap straight across. Mainly, the rear left framerail of my 72, behind the axle, is bent about an inch to inch and a half. I have always had to compensate for it by building spacers for that corner of the bed mount and adjusting the ECE super track bar to make the truck track straight from behind.
I think what I will do is to continue to drive the 72 at first. I will take the clip and bed off the 63 and give the frame a nice detail job (within reason). I will probably just clean and POR15 the frame. I will rebuild the rear training arms with new bushings and powdercoat. Then, in the front, I will clean, rebuild and powdercoat the 63 suspension crossmember and arms.
Once all of that is done, I will take the 72 off the road and remove the good stuff, detail, and install onto the 63. This way, I will continue to have something to drive around as long as possible to keep motivation high.
Old 04-19-2009, 11:53 AM   #54
I`m not sure about the frames,either.But they sure look the same without really looking into it and I`ve never seen them side by side.If they fit fairly well,that would open things up to the 60-62s pretty good....for modders that is.
Old 04-19-2009, 12:03 PM   #55
jamie72
jamie72's Avatar
not sure on the frame myself either, but i do know of 2 4x4s here local that have 67-72 bodies bolted on 63-66 frames.. look pretty close to me, i know yours is a 2wd, but still would be close, unless i`m really missing something.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-19-2009, 12:07 PM   #56
SCOTI
SCOTI's Avatar
The frames are very similar but as stated, not the same. The front frame horns are very different & would have to be cut/spliced if swapping. The cab mounts & mount locations are different as well.
Tx, is they new owner of your 'work rig' going to finish you dually conversion or is that one upgrade that's going to remain just an idea?
Originally Posted by c10addict View Post
theres some good guys on the 60 66 side of the site too!! Lol... Just do like I did and get one of each... All I need now is a square body.. Hummm..
I do believe I know the lone member in that club (not sure if there's more than just one guy).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-19-2009, 01:56 PM   #57
Camper Power
Camper Power's Avatar
all this talk makes me wanna go out to the shop, clean it up a bit and start pullin the engine, tranny and cab from my dads 66 gmc
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 04-19-2009, 02:32 PM   #58
factorystock
factorystock's Avatar
I vin # on upper left door pillar will tell the year model. If it is 2C144 it is a 62 , if 3C144 it is a 63. From photo, appears to be a 62. Regardless of year, the character lines of the 62-66 hood and back of cab(small window) are fantastic.
factorystock is offline   Reply With Quote
Old 04-19-2009, 07:52 PM   #59
Tx Firefighter
Nope. The guy is a rich oil field prick who could not help but brag to me as to how he has had over 100 classic cars in his life. I just gritted my teeth as he counted the money out in my hand.
Old 04-19-2009, 08:57 PM   #60
jbristo67
resident oilfield trash
jbristo67's Avatar
They like both.I`ve seen it go from`72 to`67.I think now that guys are doing so much to them the upgrades of a`72 means little and it`s all going into the`67s.I always like a`71 over the`72 and always really like the small window`67 Stepside.Some still don`t like a Stepside on anything.Alot of car-coverts into trucks these days.
Back on track...
6'5" and wrap around windshield...They named them knee knockers just for you.
At 5'10" it`s never been an issue for me.
Thats cool I think I like like my fleet side more than step but I really like the step sides too.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-19-2009, 09:30 PM   #61
It`s hard sellin`your truck to some people.You feel sorry for the truck.I had a rich guy tryin`to buy my K/20 Highlander but he was gettin on my nerves and he didn`t appreciate it`s rarity.Just liked the big tires and lift.He made it easy for me though.He kept wanting me to fix the axle stub u-joint because he wanted to know the 4wd worked.I just didn`t fix it.I told him it ain`t magic,it just needs the u-joint installed that`s layin`on the dash.After stalling him almost a year my friend handed me the money and totally surprised me.It`s in good hands.
