#51 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Big Red, my 68 3/4 ton GMC
Nice work! It is getting closer for sure!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#52 |
Hey bro im almost ready to do my swap from leafs to coil.. did you install the fram stiffener?
#53 | |
Big Red - Now its a SWB!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#54 |
Also forgot to mention that if you need any parts to complete your swap the junk yard here in Oroville (oroville self serve) has plenty of these trucks around.
#55 |
[QUOTE=Jacfourteen;4702675]Also forgot to mention that if you need any parts to complete your swap the junk yard here in Oroville (oroville self serve) has plenty of these trucks around.[/QUOTAWESOME,, Thanks man.. i have a doner truck but theres alays something missin.. lol.. nice to have some peeps close by that share in th e fever..
#56 | |
Cool build. Nice work on the frame man!
-- 1969 Chevy Build: http://67-72chevytrucks.com/vboard/s...d.php?t=461209 Quote:
The front: 17x7 245/45/17 Kumho Ecsta XS The Rear: 17x11 315/35/17 Kumho Ecsta XS |
#57 |
Thanks! hopefully I will have some progress to report soon...
#58 |
DUDE!!! I went to that wrecking yar it was so awesome i got totaly soaked just looking around... got sick as hell from being outhgere in the rain.. but it was well worth it. you keepin your truck an 8 lugger?
#59 | |
#60 |
Oh yeah, I'm swapping over to 6 lug. The rear is done, now I need to do the front.
#61 |
oh yeah.. But im sure ill b back often..!!
#62 |
Wow it's been quite a while since I've updated this. I've been busy all summer and haven't got much done to the truck other than cutting the front of the bed down and tacking it back together so I could put it back on to do some hauling. I have pictures of everything so I'll get them posted up soon. So far I've hauled as much as 3000 pounds in the bed and thr frame is holding up great.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 11-20-2011 at 06:09 PM. Reason: Can't spell :lol: |
#63 |
good progress i love the details you givin (ME) my will be boing from long to short spring comes so i gotta get all my ducks in a row
thanx keep all the good work
Im stright up ESL student........ ![]() 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
#64 | |
#65 |
Very cool build, keep up the good work
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) |
#66 | |
#67 |
![]() Join Date: May 2009
I'm subscribed great work this far, I liked the tip on shortening the drive shaft. I also want to see witch way you shorten the box, cool build there. What brand of bags are those? Thanx...Vernski
#68 | |
#69 |
Well this thread has been long overdue for an update so here is some of the progress that has been made since then. I entered the truck in the under construction class at the Gold Rush Car Show, so I went to the cruise-in and the show had a good time and met some cool people including a few board members. Here are a few pics:
![]() ![]() ![]() ![]() If you want to see more pictures of this show and cruise I started some threads here: Show, Cruise-in Then after the show I cruised the truck as is bedless for a while, it was fun driving without it because it was so light that I could spin the tires anytime I wanted up to about 50 MPH. Then I needed to put my truck back to work so I needed to get the bed back on. The easiest way to get the bed back on the truck was just to shorten the front section so that the wheel tubs would line up with the tires and deal with the rear section later. After looking through all the threads on here I decided to shorten the front in a similar fashion to how LFD did it (you can read his thread Here). There are pros and cons to each method of going about this, but I chose this route because it allowed me to get rid of the gas door that is no longer necessary. So here goes the pics... First I had to get the bed where I could work on it, this is how I did it by myself without a hoist: Where it had been sitting ![]() Ready to go on the truck ![]() After I rolled it on the truck ![]() Back to where I wanted to work on it ![]() And back off ![]() ![]() Ready to get to work ![]() Up next, lay out and cut... ![]()
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 12-04-2011 at 02:01 AM. Reason: wrong img link |
#70 |
First I had to measure and mark the bed
![]() ![]() Then I started laying tape: Driver's side before tape ![]() Driver's side after tape ![]() Passenger before tape ![]() Passenger after tape ![]() Then it's time to cut: Driver's side ![]() Passenger's side ![]() And the inside ![]() ![]() After some more cutting this is the result ![]() ![]() Continued in next post...
#71 |
So the bed is cut in two, but now I need to get out the scrap sections. Here it is after a little more cutting:
Driver's side ![]() ![]() Passenger's side ![]() ![]() After I cut the bed floor 12" shorter with a skill saw I did a test fitting and this is how it looked: ![]() ![]() I was happy with how it lined up, so I decided to use the scrap pieces to practice my welding. Here is what the test welds looked like ![]() ![]() After grinding ![]() Next up, fitting and welding...
#72 |
nice! good idea on getting rid of the saddle holes. too bad you didnt get that little dent out of the bed above the cuts on the driverside while it was still unwelded to the rest of the bed.
#73 |
Thanks! Yeah, I should have gotten the dent out before welding because it would have been easier to fix then, but also because the dent threw off how the seam between the two pieces lined up. Oh well, live and learn...
#74 |
Great work on your box! You did a great job!
#75 |
Thanks!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 12-05-2011 at 07:27 PM. Reason: Typo |
