Old 07-28-2009, 08:54 PM   #51
onlyifihadachevy
Re: Got a new truck
i got the clutch working then i started putting wires on then need the radiator hoses and they didn't get ordered, so thurs im getting the brakelight switch, hoses, and hopefully gtting it started friday.
I went offroading in my other truck and liked the power low end, but didn't like the carb when on a steeper hill/trail it would die then i would try it again a few times then if it stalled i would just hammer down and make it look easy.
I put a factory cluster in it, so it looks good, i will get a pic on thurs.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 07-31-2009, 01:54 AM   #52
onlyifihadachevy
Re: Got a new truck
I worked on it a little and i only have a week till summers over so next week i'm building the cage and 4 link hopefully, but i worked on it a little didn't get much done was waiting on radiator hoses, but bolted up the starter.
just need to wire it and the batt wires, put the spark plug wires on, alt, and the oil pressure line to the back of the block. STart it nd cut the back of the frame off and cage it.
My 72 thread
Old 07-31-2009, 12:05 PM   #53
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Got a new truck
Hey man, sounds like your really getting serious with this thing, I wanted to ask you about your link set up.. What type of links are you going with.. Have you done your research about links? Will you watch this video? http://www.spike.com/full-episode/su...101-rock/30579
Now you should understand this question. Whats your COG? Are you going to go 3 link with panhard up front? Did you get your front/rear and total weight yet? I have spent a lot of time under my truck measuring, remeasuring and then measuring again.. Im hoping you are putting enough thought into it, and putting it down on paper (or here) really helps.. There should be a considerable amount of math involved with linking your rig. Ide be happy to help if you need any.
Eturnit3 is offline   Reply With Quote
Old 07-31-2009, 01:54 PM   #54
onlyifihadachevy
Re: Got a new truck
i have thought about it i'm going to run the leafs up front and a 4link in the rear for now. I'm back halfing it and building the cage into a mini bed for a cooler for some soda water, tools and recovery gear, maybe a fuel cell in the future. BUt its going to be the 45 degree set up so no track bar, and coilovers buecause my uncle doesn't think a 1000pds weight max load will be enough if im pulling and jumping. THe 4link should work great same idea as airbaged trucks just with coil overs.
WIll i watch the video yup, tonight, my cog will be lower than my white truck, if not the same, the weight i will not know because of the back being cut off and rebuild the front i will 4link in the future my uncle wants to do it.
What truck were you thinking about linking.
My 72 thread
Old 08-01-2009, 09:07 PM   #55
onlyifihadachevy
Re: Got a new truck
forgot to take a pic
My 72 thread
Old 08-02-2009, 11:03 PM   #56
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Got a new truck
Ive got a couple prospects actually, the 1st one is a 76 1 ton flatbed with d70 rear the second is just a 78 shortbox 2wd that Im not really into.. i will get some pics for ya tomorrow. but it looks cool.. I did CaLROCs this weekend.. when I find the cable I will post vids
Old 08-02-2009, 11:30 PM   #57
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
i would do the 76. it sounds like a good platform to start with seeing as the axles are already beefy.
70 beast is offline   Reply With Quote
Old 08-03-2009, 04:01 AM   #58
onlyifihadachevy
Re: Got a new truck
yup i would do the 76
My 72 thread
Old 08-03-2009, 08:29 PM   #59
onlyifihadachevy
Re: Got a new truck
i push the truck into the shop and worked on it for a little while didn't look like much but i'm almost ready to start it, the wire to the coil and start and thats it. I pulled t out with my other truck and had to push it a little with it but its back in its place, Tomarrow i will start the cutting and caging.
My 72 thread
Old 08-04-2009, 02:33 AM   #60
84 400
Sb 400 club
84 400's Avatar
Re: Got a new truck
cool man your getting there
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 08-05-2009, 01:36 AM   #61
onlyifihadachevy
Re: Got a new truck
THE most recent pics of it, haven't done much but plug in some wires and priced my shocks, and We're going to buy a tubing bender and my uncles going to let me use, i willl most likey keep it, because he has 2 or 3 more of them, and build the cage and 4link at my house because schools starting.
My 72 thread
Old 08-06-2009, 11:27 AM   #62
onlyifihadachevy
Re: Got a new truck
THE bed off and learned to use a torch, i knew before but i was taught more about it, so i can cut anything, had to cut some bolts out. I went and got a new starter didn't fit, so put the old one back in. Hooked up the wires and tried to start it, it was cranking and fired and backfired.
CHaNged the timing and some stuff don't know exactly, then It wasn't getting any fuel so i poured 5 gallons in the tank cranked it fired and ran fine for about a minute then i turned it off, because open headers was loud.
I wil get pics today.
My 72 thread
Old 08-08-2009, 11:53 AM   #63
onlyifihadachevy
Re: Got a new truck
I got my truck home and we cleaned the garage and we will put it in there to day, Tuesday we're ordering and tubing bender, 1.75 dye and a notcher. Then i will get 100ft of 1.75 3/16 wall dom for my truck and start building.
My 72 thread
Old 08-08-2009, 11:56 PM   #64
dbmx66
Re: Got a new truck
nice truck
dbmx66 is offline   Reply With Quote
Old 08-09-2009, 12:56 AM   #65
onlyifihadachevy
Re: Got a new truck
thanks, and I was wondering what color i should paint it, flat black, flat white its getting a little old for me but still cool, try to paint gloss balck with spray paint or get an air compressor and paint it nice with clear to I buff it and then go destroy the paint in the rocks and mud? Some ideas would help it would needs to be cheap and look fairly good.
My 72 thread
Old 08-09-2009, 09:43 PM   #66
onlyifihadachevy
Re: Got a new truck
I went to the junkyard looking for a d60 and i got the right trottle cable from a really old like 30's 40's truck and got the vaccaum line for the power brakes from a van. But i found a few 67-72 chevy/gmcs some had pretty good metal, like the one in the pictures.
My 72 thread
Old 08-09-2009, 09:53 PM   #67
onlyifihadachevy
Re: Got a new truck
And i think my dad and I are going to try and sell the ford my dads boss gave him for enough for some cheap rockwells, its a 85 ford with a 302 or 292 small block v8 halfton 4x4, its reg as a diesel so no smog. hopefully, it wil fletch enough but I'm waiting till tuesday to order a bender and then it should be i don't know how long before it comes then the building begins.
My 72 thread
Old 08-10-2009, 10:31 AM   #68
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
well rattle can is cheap and if done right, can look good also.
a buddy of mine is building a trazer, and he did a two tone look using a dark blue and flat black which turned out nice. total cost was somewhere round 20-30 bucks i think.
its hard to do flat black from a can. lines show up easy. so gloss black might me easier.
Old 08-10-2009, 05:09 PM   #69
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Got a new truck
Damn nice job its looking good so far. Keep up the good work on it
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-10-2009, 05:39 PM   #70
onlyifihadachevy
Re: Got a new truck
the flat black only shows lines with the base is a light color but the flat black i would to 2-3 layers, and i was thinking about buying a cheap spray gun and learning to paint on my 2 trucks.
My 72 thread
Old 08-10-2009, 05:56 PM   #71
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
what about a gray primer?
Old 08-10-2009, 06:30 PM   #72
onlyifihadachevy
Re: Got a new truck
I think that would look good like yours.
My 72 thread
Old 08-10-2009, 06:49 PM   #73
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Got a new truck
I am going a dark, flat OD green!! Choose what you like, I really liked how tough the color makes any rig look. But if you like blue and pink camo... Go for it man. Make it yours!! The most forgiving color to hide scratches/nicks/blemishes seemed to be white oddly enough. So if you decide you want glossy paint (although I admire your taste in flat colors) go White!! it hides **** really well. My .02, cant wait to see the progress pics.
Also, I have noticed a lot of guys going with d70's lately due to the ultra heavy duty'ness of it.. You can find em a lot easier too it seems. But its harder to find info on em and isnt so easy as a 60 to build or have built. Just some food for thought..
Old 08-10-2009, 10:31 PM   #74
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
i wanted to do an army theme green paint job on my jimmy, but my gal and i chose the flat black, and burgundy.
eventually i wanna do a dark blue primer.
Old 08-13-2009, 11:36 PM   #75
onlyifihadachevy
Re: Got a new truck
i HAVE BEEN THINKING, my bad caps was on, but on paint i'm still debating and i started drawing a picture of my truck, I will post it later and i think i will do the set up just like the pic but I/m going to copy it of designing the backhalf.
My 72 thread
