Questionable
Hey, FirstGen....
Can you provide any more detail about what exactly parts were necessary for your truck and what you got them off of? I've heard stories of people raiding 1994-1996 Impala/Caprice/Roadsters to get the 5-lug setup. I am wondering if there is a need to get new a-arms (upper or lower), ball joints, tie rods or intermediate shaft with the method you chose? I literally have the same truck as you (closer to stock though ) - I would probably do mine a bit different, just looking for some direction.TIA
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-05-2005 at 10:50 PM. |
Just Don't Stop!
![]() Join Date: Feb 2004
Basically these are the parts I used:
1968 C20 lower control arms 1990 3/4 ton Light Duty 2X4 must have (1.25" rotors) spindles 1990 1.25" thick 6 lug rotors 1990 calipers off same truck 1990 upper and lower ball joints 1990 outer tie rods inner tie rods MOOG part #ES2020RL 1990 style tie rod coupler The only catch is to cut 3/4" off each end of both tie rods on each side of the truck so you can have enough room to align the truck. Well at least I had to since mine is lowered 4" in the front. The front end I bought off the 1990 truck was 5 lug. All I did was went and bought the 6 lug rotors and bolted them on. If you wanted to stay with the 5 lug, you'd save yourself about $120 bucks. After everything is done, you will now have 14mm studs on the front. I fixed this by drilling my rear axles and pressing in 14mm studs in the rear also but you wouldn't have to do this... I plan on going to a rear disc setup using a floating rotor design and so this helps that plan also... Good luck.
1968 C10 build in process TT LSA/6L90e/9" |
MY EX DRIVES A BROOM
what ball joints did you use?
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#4 | |
Just Don't Stop!
Questionable
Thanks for the info, FirstGen. Did you need to modify your brake line or brake line assembly at all? I've noticed some people (normally in the back) welding on new L-brackets to hold the tap between the hard line and the flex line. Did you re-use all existing fittings and lines or buy new ones?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Just Don't Stop!
I used the rubber lines off the 1990 truck and used the factory mount from the 1990 to secure the line to the frame. Never ran new steel lines until later when I just wanted to, it wasn't nessary to do the swap.
Re: easy disc brake swap
DO you know if the 68 3/4 ton Lower A-Arm is the same as the 69? Thanks in advance for the help.
Bruce |
#8 | |
Just Don't Stop!
I'm sure it is. Call Ed at Mothertruckers and ask him, he will know for sure...
#9 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
![]() Join Date: Dec 2000
I wonder if you can utilize the '88-'98 3" lift spindle while doing this swap....I'd like a little lift on my '70 C-10 Sub!!
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
!Women...!!!!
Did anybody else that did this swap with factory ride height have serious alignment issues like I have??? Not toe, caster / camber...
'69 GMC 1/2T LWB 2WD '02 Silverado 2500HD 4X4 '79 ElCamino SS |
#12 | |
thanks.
78 C10 LWB Super Cheyenne |
#13 |
Yup, for the larger ball joint in the 3/4-ton a-arm to match the larger later model lower ball joint.
#14 |
can you put a 3/4 ton ball joint in a 1/2 ton lower control arm.
I am really enjoying these modifications. It seems that the sky is the limit with these old trucks
#15 |
to keep this alive and kickin'...Anyone know if it'll work on a 67 GMC??? Thx so much in advance!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
#16 |
Just Don't Stop!
yes, it looks like this... been running it for a while now so it doesn't look as nice but you get the idea. I used a 1990 chevy front end/parts that had 5 lug 1.25" thick rotors and went to AutoZone and bought new factory 6 lug 1.25" thick rotors and bolted them on.
Good luck.
1968 C10 build in process TT LSA/6L90e/9" Last edited by FirstGen; 04-02-2005 at 02:24 PM. |
| Bookmarks |
