Old 09-12-2009, 04:51 PM   #51
frmula505
frmula505's Avatar
Re: My 60 Chevy Shop truck build
Your taking about the roll on herculiner. Dont use it, it chips and peels with time. There is a liner called al's liners that I've heard nothing but good about. One of the site vendors sells it. As for under the fenders and hidden places (Places that arent abused) I just use the canned rubberized undercoating.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 09-14-2009, 10:54 AM   #52
frmula505
frmula505's Avatar
Originally Posted by Chevy Fleetside View Post
Maybe you might want to try this. It is still coming along nice though.
After looking at the thread where this mod is done. I don't think it will match with the smoothie tailgate cover I installed. I decided I didn't like the way mine had come out either. So I changed my design a bit. What do you guys think?
Since I have most of the body work done, it was time to start on the interior. I still had it striped from the floor board welding. I had to do a little welding. on the dash. they had installed a huge tach (#2), there was some type of cup holder (#3), and the last 4 holes who knows what was there (#1)
On the area behind the drivers side door there was the bottom of a coffee can screwed on. Probably had a speaker at one time.
After taking it off I found a PP, actually part of a Colorado license plate with the letters "PP". Covering what looks to be a hole for a CB antennae.
Got started welding, and of course ran out of wire, another project stopper.
2006 Cadillac XLR-V
Old 09-14-2009, 11:12 AM   #53
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by frmula505 View Post
...As for under the fenders and hidden places (Places that arent abused) I just use the canned rubberized undercoating.
Brand? Where to buy? Is this brushed or rolled on, or do you need some special gun to spray it on? Thanks for the advice.
Question about the license plate "repair" you fund. Looked like quite a bit of rust around that hidden area. Did you do any prep to it before covering it?
Dan in Pasadena is offline   Reply With Quote
Old 09-14-2009, 11:27 AM   #54
frmula505
frmula505's Avatar
It's 3M rubberized undercoating (comes in a spray can,), you can get it at most autoparts store. As for the rust, It was only light surface rust. Actually rust on the plate was was the worst. I wiped it down with metal conditioner and spayed a coat of undercoating. I would have posted a pic, but figured three pics for one hole is enough.
2006 Cadillac XLR-V
Old 09-18-2009, 09:26 AM   #55
frmula505
frmula505's Avatar
I got my lowering kit. A few problems first of all they sent me the wrong panhard rod. I specifically told them it was a 1960 and needed a 33"-34" rod. They sent me a 27".
Next not sure if this is a problem. Seems so to me. But are these shocks to small. They are fully extended, and the truck frame weight is on the springs. will the weight of the bed bring it down this much?
The springs fit fine.
2006 Cadillac XLR-V
Old 09-18-2009, 10:21 AM   #56
joe231
joe231's Avatar
as far as the shock length, have you tried standing on the frame to see how much it droops?
CHEVY ONLY
Old 09-18-2009, 10:27 AM   #57
frmula505
frmula505's Avatar
It drops about an inch. Shock is still a little short. I'm sure a complete bed, bumper, wood weigh more than me (200lb). I'll have a couple of friends sit in the frame this afternoon.
2006 Cadillac XLR-V
Old 09-18-2009, 04:56 PM   #58
rookierodbuilder
rookierodbuilder's Avatar
just my $0.02, looks to me as if they sen you a kit for about a 63 model year pickup. The track bar looks to be the same lenght as the 63' frame that i'm working with and the shocks look to be in completely different locations (about 1-1.5" above the 63-72 shock locations).
rookierodbuilder is offline   Reply With Quote
Old 09-19-2009, 09:11 PM   #59
cliffy
Hi frmula505, LMC has 2 styles of floor pans, OEM and the Universal ones. Are the universal ones you used good enough thickness wise?
my o/l says the truck has a vibration at 65 mph..I said its ok, it goes away at 90.
cliffy is offline   Reply With Quote
Old 09-20-2009, 01:28 AM   #60
frmula505
frmula505's Avatar
they're just as thick as all the other patch panels I used. not sure the gauge.
2006 Cadillac XLR-V
Old 09-20-2009, 12:00 PM   #61
cliffy
Thanks,
Old 09-20-2009, 12:14 PM   #62
1964C10
1964C10's Avatar
I dont know where those shocks are for/from but IMHO I think they are completely wrong, having done a number of shocks on different vehicles I have never had any that need to be extended competely till the end or have weight on the bed to install them. I just did them on my 64 with nothing but framerails in the back and I still had to push them on to get them into the holders. If they so much as get to the end in any kind of driving they will be destroyed. I would most definitely get longer ones. Just my 2c
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 09-20-2009, 01:09 PM   #63
frmula505
frmula505's Avatar
It's a hassle to send back and wait again. Since the suspension is already modified I'm just gonna modify the shock mount plates to match the shocks. Will post pics when I return from work related travel.
2006 Cadillac XLR-V
Old 09-24-2009, 07:22 PM   #64
frmula505
frmula505's Avatar
Got the shocks mounted. Just had to improvise.
2006 Cadillac XLR-V
Old 09-24-2009, 08:10 PM   #65
62 Bowtie
62 Bowtie's Avatar
cool I just got the same shocks (Doetchtech) and they were also too short I ordered the 5" drop style cuz I have the 5" drop coils I sent them back for the 3" also are those mounted correctly they look upside down I mounted my fronts opposite of how your installing them
62 Bowtie is offline   Reply With Quote
Old 09-24-2009, 09:31 PM   #66
frmula505
frmula505's Avatar
you mounted yours with the solid part to the bottom? I might be wrong enlighten me. It's not that hard to turn them around.
2006 Cadillac XLR-V
Old 09-24-2009, 09:56 PM   #67
protrash64
Resistance is Futile
protrash64's Avatar
Ive seen this before, and dont quite understand all the reasoning, but 'unsprung weight' is one reason Ive heard; also keeps junk off the shaft for longevity. Dont want to get your thread off into debate territory
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-24-2009, 10:06 PM   #68
joe231
joe231's Avatar
look at stock shocks, the fluid reservoir is at the bottom. the only difference is the shaft has a bell/cover so you can't see the shaft
here is a pic I stole from Hart Rod
Personally I think it would look better straight across, instead of angled up....
CHEVY ONLY
Old 09-24-2009, 10:54 PM   #69
62 Bowtie
62 Bowtie's Avatar
That was my reasoning when I installed mine
Old 09-26-2009, 06:22 PM   #70
frmula505
frmula505's Avatar
Thanks I'll flip them over.
2006 Cadillac XLR-V
Old 09-26-2009, 09:08 PM   #71
Eagar1
If I recall the gasadjust didn't matter which way they were mounted, but the old school shocks would overheat if mounted upside down, and also the valving rates were different as you want your shocks to drop faster than they retract, and having them upside down messed that up somehow. I am sure someone else knows the true story.
Eagar1 is offline   Reply With Quote
Old 09-26-2009, 10:04 PM   #72
markeb01
Senior Enthusiast
markeb01's Avatar
Back in the days before gas shocks, I was taught it was standard practice to "bleed" the shocks before installing. The way this was done was to turn the shock upside down with the reservoir on top, fully compress the shock, turn it right side up, fully compress, then repeat this 2-3 more times.
Per the old timers this made sure all the air was out of the fluid. I believe it was true, because on the first pass the shock would collapse easily. After a few cycles the shock was much stiffer, and if left alone right side up they remained stiffer.
If installed with the reservoir at the top, there wouldn't be any compression resistance as the fluid valve would be open, and the shock absorbing would become ineffective.
Old 09-27-2009, 06:33 PM   #73
Eagar1
Oh man my rusty rolodex of a brain just remembered doing this with my Dad, I was like 12, I think it was like a 65 buick wagon, man now that brings back memories, thanks for the Reminder Markeb01
Old 10-22-2009, 08:53 PM   #74
frmula505
frmula505's Avatar
I was out of town working. Finally got some time for the truck. The cab is done. It has a thick coat of sanding sealer. One more guide coat and the final sealer.
2006 Cadillac XLR-V
Old 10-22-2009, 09:48 PM   #75
markeb01
Senior Enthusiast
markeb01's Avatar
Blocking out one of these bodies sure makes a person appreciate how many nooks and curves there are in the sheetmetal. The bodywork is looking nice.
