Old 09-13-2009, 09:31 AM   #51
jjjmm56
jjjmm56's Avatar
Re: 56 project
Some of the suspension
jjjmm56 is offline   Reply With Quote
Old 09-13-2009, 10:08 AM   #52
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 56 project
Nice work! I may give it a try.
ChuckDriver is offline   Reply With Quote
Old 09-13-2009, 11:30 AM   #53
Kim57
Kim57's Avatar
Re: 56 project
Thanks for the pics.
Kim
Kim57 is offline   Reply With Quote
Old 09-13-2009, 03:06 PM   #54
jjjmm56
jjjmm56's Avatar
Re: 56 project
I hope they help, and for anyone thinking of bagging a TF I can help with pics of that also. All the brackets step notch and bag cups ,trailing arms were made out of scrap steel from a fab shop. Cost 1, 12 pack of beer. allmost everything I made was cut with a 4 1/2" grinder, sawzall or torch. I wanted to see if the home builder could make it without speical tools and little money.
Old 09-14-2009, 03:44 AM   #55
Primer70
Superbad
Primer70's Avatar
Re: 56 project
I'd be a little concerned with that single U-bolt on the two link arm. The ones GM used on the trailing arm suspensions was much beefier.
Primer70 is offline   Reply With Quote
Old 09-14-2009, 03:55 PM   #56
jjjmm56
jjjmm56's Avatar
Re: 56 project
I was looking at that the other day .I"ll go to the 4 wheel drive shop and see what they have that's stronger. That whole setup will be changed when I find a disk brake rearend. Then I"ll make it into a 4 link. Thanks for the insight.
Old 11-20-2009, 01:24 PM   #57
jjjmm56
jjjmm56's Avatar
Re: 56 project
back to one color. It's nice to have it all 1 color again, now ready for guide coat and block. Also some pics of the last min. rot I needed to fix, and my air suspension
Old 11-20-2009, 01:43 PM   #58
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
Looking good, keep up the good work.
Kabwe is offline   Reply With Quote
Old 11-20-2009, 02:30 PM   #59
Kateaux
Kateaux's Avatar
Re: 56 project
I had the same roof rot. Had to replace the roof.
Kateaux
1958 3100 w/55 frontend and 55 Cameo Bed (in progress)
Kateaux is offline   Reply With Quote
Old 11-20-2009, 04:07 PM   #60
jjjmm56
jjjmm56's Avatar
Re: 56 project
Thanks Kabwe! The roof rot was like that on both sides and top and bottom of the gutter. If I had to do it again I'd shave the gutters, spent the same amount of time.
Old 11-20-2009, 04:12 PM   #61
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
Well you know I shaved mine.lol Mine were not bad I just felt like cutting something.lol I did end up replacing my entire roof anyway.
Old 11-23-2009, 11:11 PM   #62
jjjmm56
jjjmm56's Avatar
Re: 56 project
Kabwe, Man you've done a hell of a lot cutting and welding! I do have a ? On your cowl vent did you cover up the stock grill or make a new one? I lost mine and need to look for one this weekend at Daytona rod run.
Old 11-24-2009, 12:16 AM   #63
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
I just smooth mine. They sale them smooth but in glass I'm a metal kind of guy. I see them for sale on ebay all the time for a little of nothing.
Old 11-24-2009, 05:00 PM   #64
jjjmm56
jjjmm56's Avatar
Re: 56 project
Thanks thats my project for sunday.
Old 11-24-2009, 06:04 PM   #65
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
No problem.
Old 01-27-2010, 02:12 PM   #66
jjjmm56
jjjmm56's Avatar
Re: 56 project
Well I've been getting more done. Got my bed,fenders and doors ready for last blocking before for paint. Built a new front panel using stock top rail and making a new lower. Also making new tailgate need to make hidden pin locks and skin the outside.
Old 01-27-2010, 03:30 PM   #67
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
Looking good buddy.
Old 01-27-2010, 04:17 PM   #68
Kim57
Kim57's Avatar
Re: 56 project
Looks nice.
What are your seats out of?
Kim
Old 01-27-2010, 04:49 PM   #69
jjjmm56
jjjmm56's Avatar
Re: 56 project
Thanks! Seats are from a pontiac sun bird 30.00 at the salvage yard. Hope to remount the doors this weekend and recheck the gaps, then block and prime fenders and cab 1last time. I hope to have the motor installed in two weeks.
Old 01-29-2010, 10:08 AM   #70
ChuckDriver
Re: 56 project
Wow! it's coming together real nice!
Old 02-03-2010, 01:46 PM   #71
jjjmm56
jjjmm56's Avatar
Re: 56 project
Hung a door and checked gaps, and figured out my paint.
Old 02-03-2010, 03:32 PM   #72
Kim57
Kim57's Avatar
Re: 56 project
Looking good.
Kim
Old 02-03-2010, 06:59 PM   #73
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 56 project
Kim is right its looking great. good work you should be proud.
Old 02-03-2010, 08:27 PM   #74
jjjmm56
jjjmm56's Avatar
Re: 56 project
Thanks, but now my mind is racing so much I have a hard time staying on task. I need to pick colors for the seats so I can figure out what to paint the dash. Need to pull it all apart to paint the door jams. Can't wait to put the motor in do I run the th350 I have or buy a 700r4. If I go with the r4 then I need to get differant brackets to mount my lokar. ON and ON and ON ARGHHHHHHHHH!!!
Old 02-03-2010, 08:42 PM   #75
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: 56 project
Very nice build, That sure is sitting low. Can you show some pics of your front and rear suspension? Do you have air bags on the front? Are you running any shocks on the rear and how stable is the back now? I don't see a panhard bar that's why I'm asking.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
