Old 07-02-2009, 03:11 PM   #51
daverod
SSN 706
daverod's Avatar
Re: Bagged, how low will it go with standard cnotch. Any pics???
Originally Posted by SkullCandy View Post
Will the 60-66 truck lay the frame on stock suspension? with a big c-notch.
You have to do a lot of stuff and stuff if you want to lay frame. But don't let that stop you . Everything you ever wanted to know is here. I'll you have to do is search and read and look at pictures and then spend $$. I guess it depends on what you consider stock means. Born in Vernon.BC
daverod is offline   Reply With Quote
Old 07-02-2009, 03:36 PM   #52
protrash64
Resistance is Futile
protrash64's Avatar
If you call your a-arm crossshafts frame, then yes. Depends on tire size , too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-02-2009, 05:23 PM   #53
chevytrucknut
chevytrucknut's Avatar
here's another pic or two.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline   Reply With Quote
Old 07-02-2009, 07:31 PM   #54
Frizzle Fry
Frizzle Fry's Avatar
Hey, where did you get the trim that connects the two sails and runs under the back window? GMC?
Frizzle Fry is offline   Reply With Quote
Old 07-02-2009, 08:16 PM   #55
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
skullcandy you can use your stock supsension parts. But and I mean a Big But. You will not be able to lay frame in the front because the crossmember and LCA lays under the frame. You can either section your crossmember or Z the frame to get what you need to lay out. For the back You will have to build a really wide notch at the bottom, because the trailing arms this the frame before it ever lays out. Ways around this Z the back of the frame as well to raise the bed section higher then under the cab. You can build a back half using 2x3 should give you the clearance so it doesn't hit. The problem that most people have when using the stock trailing arms is that your going to have to spend the money to box the arms or it will twist on you since you have to offset the bag. I was planing on doing the same thing, but after really looking at how much trouble it would be to just to get the stock parts to lay out you can build a 2,3,or 4 link for the same price. If you want to know what I'm talking about look at a bunch of the threads, and theres a thread that supports what I'm talking about I'll try to find it for ya!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-02-2009, 08:22 PM   #56
daverod
SSN 706
daverod's Avatar
Some good info. Thank Ruff
Old 07-02-2009, 08:46 PM   #57
chevytrucknut
The black '63 suburban and the black '65 are both bagged and have a small notch. The orange truck from a few pics back is the same frame set up but the body has been dropped 6 inches around the frame. The sheetmetal touches before the frame does. Its a lot of work and you loose some leg room but you get a really good ride out of it.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
Old 07-02-2009, 09:30 PM   #58
Ben IV
Not what your lookin for exactly but its one good lookin short step.
http://67-72chevytrucks.com/vboard/s...4&postcount=12
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 07-02-2009, 10:02 PM   #59
bird7263
Urban Chop Shop
bird7263's Avatar
Ben- Yeah, I love that truck.. stance is sweet.. Some day I will build another one... Because you can own more than one 60-66 right.. lol.
Jack- Talked to Jake today.. Going in next week.. We are gonna bag the rear and do new spindles and springs up front.. I dont really care about the front being low as much as I do the back..
I take it those are pics from Billit Proof? Looking good.. Wish I could have made it..The Baby is taking up all my time.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 07-03-2009, 12:01 AM   #60
protrash64
protrash64's Avatar
Come on Frizzle, you oughta be able to hammer out that piece with one arm tied behind your back......
Old 07-03-2009, 01:17 AM   #61
Frizzle Fry
Hah, don't mean to hijack. I've just never seen that on a Chevy. I like it.
Old 07-03-2009, 09:50 AM   #62
SkullCandy
Oh yeah.. Thanks for the info
1990 Dodge Ram D250 Cummins
SkullCandy is offline   Reply With Quote
