#51 | |
SSN 706
Re: ol Curt Progress
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-08-2009 at 09:25 AM. |
#52 |
Member of the longbed union.
Ol Curt, I would stay away from the chrome pan. I will just trap heat. Get a nice aluminum one with fins to help cool it down. You can scuff the chrome on the crossmember and paint it. That's what a lot of people do to rims.
I would take the cab off and check it. It's a lot easier to install the trans and get the crossmember in the right spot when drillin holes. If you have a hoist, just ask Alan how he made his lift. I'm not sure if your running a diffrent steering colum or not, but you can always cut the old shaft out, and replace it with 3/4"DD pipe and get 2 joints. it will clean it up a lot. I hate the rage joints.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#53 |
Junior Member
I crawled under the old truck today and felt the parts of the floor pan that had not been replaced were so good that I can't justify tipping or removing the cab. Some light wire brush work and a little POR 15 should make it real good for a driver!
Thanks for the tip on the finned cover...I'll have to look for one of those. I'm always on the lookout for something I can do early morning on ol Curt cause my garage is attached, and you DON'T want to wake the wife early! I thought I could put some seam sealer on. Little did I know that the Autozone wouldn't carry it. The young guy was trying to sell me some clear silicone that couldn't be painted. Couldn't find the real stuff....guess I have to wait til Monday and go to an autobody store!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 08-09-2009 at 12:00 AM. |
#54 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-09-2009 at 09:30 AM. |
#55 |
Junior Member
Couldn't find it at Autozone...called Advance, Pep Boys and O'Reillys. All said they didn't carry. I went to one O'Reillys that is sort of slow business wise and the guy looked in the back and found one tube. I asked out of curiosity if the other stores in town showed any. He said both did! LOL
I got a lot of work done in cleaning up the rest of the floor and prepping for whatever coating I decide on this week. Damn, it was hot!! ![]() I looked at my seat a bit and am undecided on what to do with the foam. The back of the seat was original and had 1" of foam. The bottom had been recovered and my grandpa was pretty short, so I can't help but wonder if they put extra padding in it. It has a piece about 5" think. How thick were most of yours? First Pic is of the back padding.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#56 |
Junior Member
I should mention that this was the first time my wife has weighed in on ANYTHING with this truck and she says I have a nice cover and it should be NEW foam!
#57 |
Junior Member
I'm not sure what you mean by this process. Can you give me more info? Thanks!
#58 |
This is what I'm saying you can get to clean it up. I found it on summits website. but it gives you an Idea.
#59 |
Junior Member
OK, I just need to get it set in my mind how the pieces relate to the existing shaft.
#60 |
Junior Member
So, does one end of that go on to the existing round shaft and have a set screw or a pin that goes through the original?
#61 |
Junior Member
What hav eyou guys done about your drip rails. I fell it was a problem with these trucks having he rail all the way around the top. It makes sens on the sides. I have minor areas where I can see a little rust dripped down the side and back of the interior in the past. I don't want to paint the interior till I know I have all that sealed.
Has anyone cut all but the sides rails off and welded them shut?
#62 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-10-2009 at 09:07 PM. |
#63 |
yeah look back through Alans thread and see what he did to his.
On the steering, You will attach one of the joints to the end of the steering column and then hook up the DD pipe to the other joint that hooks to your gear box. All it does is clean up the old shaft, unless something has moved then it allows it to work. This is what I have to use on mine because I have power rack.
#64 |
Junior Member
"On the steering, You will attach one of the joints to the end of the steering column and then hook up the DD pipe to the other joint that hooks to your gear box. All it does is clean up the old shaft, unless something has moved then it allows it to work. This is what I have to use on mine because I have power rack."
Do you by chance have a pic or two of yours? thanks
#65 |
Here are 2 diffrent ones that I've found on here. Mine will be a little diffrent because I have power rack and pinion. If using the stock stuff then this is what u'll use if your bagged. The Heim joint keeps the top rod up high enough so when your letting air out it doesn't get in the way of the upper control arm.
#66 |
SSN 706
Do you have to do that if you lay frame?
#67 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 08-22-2009 at 08:48 AM. |
#68 |
Junior Member
Well, I ought to be really good at carving turkey this Thanksgiving. I have been trying to mold some new foam to the shape of the old for my seat. I believe my mother in laws Hamilton Beach electric carver is a bit dull. Sorry no pics...camera at work. Will have some tomorrow.
I was not short of help tonight. My neighbor Frank, who has trouble putting gas in his mower and my wife both decided to critique. ![]() ![]() I don't know why my wife has taken an interest in the seat. She could care less about anything else that has been done. But damn, she sure is interested in this! ![]()
#69 |
Dave sorry I didn't get back to you, Yes you will have to do that to lay frame. Your upper control arm will get in the way if you dont.
Ol Curt your getting by on Joe with not having any pics.
#70 |
Junior Member
Yep, I know!! I suspect the sherriff has been busy keeping unruly town hall people like myself under control!
#71 | |
SSN 706
#72 |
Junior Member
Finished my seat last night. My friend says my wife looks happier about it than me. I told him that's cause i did all the work and was tired.
#73 |
SSN 706
#74 |
Junior Member
She and my neighbor have poked a lot of fun at me while I have been working on it. I told them they couldn't even ride in it, much less drive it!
![]() Got much of the interior painted in primer and one coat of paint today. Hope to finish that and take pics tomorrow. I think I'm going to sell the th350, crossmember and column I just bought, as I want to get this thing on the road and I'm still waiting on the column as Tony has hurt his back and is out of commission for awhile. I am anxious to get the seat and tank back in and once they're back in whatever trans ins in that thing is stayin!! ![]()
#75 |
Junior Member
Can anybody tell me how far the interior paint extends into the jamb area. Also, what part of the doors were painted in the fawn color from the factory...just the inner cover, or the whole door?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 08-22-2009 at 07:46 PM. |
