02-17-2010, 05:14 PM | #51 |
The Few, The Proud
Re: First Timers Build/Super Stock 70 Step
Hey Joel. Are you up and running yet?
Shannon |
02-18-2010, 12:41 AM | #52 |
Not yet Shannon, I'm going to be pulling the motor this weekend as long as the guy still has it. I called him today and he didt return my call. SO if all goes well this weekend i should be up and running for the Chewing fat get together.
If its not i will still be there!!
Learning as I go! ------------------------------------- |
02-24-2010, 09:07 PM | #53 |
Ok the motor finally showed up! i was suppose to get the motor saturday but things came up. So the motor was delivered to me today at work. Not quite what i was expecting. PO said that they were double hump heads, well the dbl humps are suppose to look like a dog bone from what i have seen and been told. These look like pyramids. The carb and distr. are worth what i paid for the motor. Here are some pics of it, i plan on putting it in Saturday. I still have to get headers, oil and water temp gauge stuff and a different fuel pump . not sure about the bosch plugs. lemme know whatca think
i will put on some after photos and maybe a video if i can get it to work
02-24-2010, 11:36 PM | #54 |
i dont have the casting numbers on the heads i didnt want to take the valve covers off, but this is what i found when i did a search.......
. 624 (double triangle)-Originally used on '71-'72 LT-1, '71-'74 Z/28, and '73-'79 L-82 engines (with 9:1 compression ratio), this head has 76cc combustion chambers and is in essence a high-performance smog head. It was also available as a service replacement for high-performance, low-compression engines. part number 464045 was supplied with 31/48-inch screw-in studs and is machined for 2.02/1.60-inch valves. This casting isn't a lightweight type, but weight reduction was incorporated in its design. ---- now i really need to get this thing running.
02-25-2010, 10:34 AM | #55 |
1 thing at a time is progress.
Do you know anything about the carb?
Alan
Philippians 2:14-16 |
02-25-2010, 08:02 PM | #56 |
Hey Alan, not 100% sure but i believe its a 750cfm Holley. i went to summit today ordered the headers they didnt have them in stock *bummer*. i picked up pig tail for HEi, oil, filter, alt brackets, plug wires, a different fuel pump with no return, I'm hoping that the z bracket for the cluth will not give me to much problems.
02-25-2010, 10:18 PM | #57 | |
Alan
02-25-2010, 10:25 PM | #58 |
I tried to call to see if you wanted to go LOL.... You are more than welcome to come down and help! it will be out in the cold haha
02-28-2010, 12:39 AM | #59 |
weather was nice, made some progress. i removed the L6 from the truck, inspected the clutch.. i need to get a new one, a starter and a pulley setup. should be going to pull a part tomorrow to get what i need. will post picks tomorrow
02-28-2010, 12:48 AM | #60 |
forgot to mention that i picked up a five lug disk brake spindles! thanks DANO. and thanks for all the help
02-28-2010, 06:39 PM | #61 |
Two days, two motors. The 250 came out of the truck with no problems. Started around 1pm and it was out by 5pm. Inspected the clutch, guess what..... needs a new one the old one was almost down to the rivets. So this morning i ran over to the parts store and grab a new clutch kit. The motor mounts would have worked but one was broken. 7 bucks a piece in stock at O'reilys. While the V8 was laying out we went ahead and bolted on the starter, transmission. i need a different fuel pump with out the return vent line. The new motor and tranny went in with no major problems. Didnt even break a plug. Started pluged up, fuel line connected. All ready to crank!!!! No exhuast..... they should be here tomorrow. But the drivers side is going to be cramped for space. I need to locate a z bar mount for the V8. The old one will not work. I should be able to find one at the pull a part or on the sale board. Here is a crappy cell phone photo. Oh i also need to get some pulleys and brackets!
Learning as I go! ------------------------------------- Last edited by jsmithbm; 02-28-2010 at 06:40 PM. |
02-28-2010, 10:26 PM | #62 |
Still Learning
Great progress! New engine is looking good!
02-28-2010, 10:36 PM | #63 |
thanks!! i cant wait to fire it up!!
02-28-2010, 11:00 PM | #64 |
Grandpa in the rustmobile...
nice build! that v8 looks good in there!!! can still still crawl in to work and close the hood with ya under it lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-28-2010, 11:14 PM | #65 |
The Few, The Proud
Looking good Joel.
Keep up the good work.
Shannon |
02-28-2010, 11:17 PM | #66 | |
i did stand in front of the motor with my feet on the ground to hook up the starter and the fuel lines. there is enough from for a few, well lets just say there is a ton of room in the front now.
03-02-2010, 07:56 PM | #67 |
I laid down some paint today on the cowl, i sanded it a while back and it has been primed and ready for paint. I was originally going to go with the stock green. But after i decieded to put the new motor in, the custom bug kicked in! This will be the only 67-72 chevy i plan on doing so why not go all out right!
Well here it is, its called Blue Ribbon. Its a blue metallic with xr17 (i think) metallic flake. Its a toyota color and it looks sharp in the sun!
03-02-2010, 09:00 PM | #68 |
Nice really like tre color
70 SWB STEPSIDE 70 BLAZER 09 challenger |
03-02-2010, 11:32 PM | #69 |
You painted that? No really? J/K it looks great. I thought you didn't have any paint experience. If the custom bug has bit you, you know there is not a cure for it yet, but the checkbook can delay the effects.
That's a pretty good one liner if I say so myself.
Alan
03-03-2010, 07:21 AM | #70 | |
Thanks, It really looks good when the sun hits it!
I guess i will need to get another job to pay for my habit!
Learning as I go! ------------------------------------- Last edited by jsmithbm; 03-03-2010 at 07:23 AM. |
03-03-2010, 09:53 PM | #71 |
here some more photos of the cowl
Man its gonna pop! cant wait to get the whole thing painted. i need some donations for the custom bug!!!
03-03-2010, 10:14 PM | #72 |
The Few, The Proud
That's definately going to pop.
Good job Joel.
Shannon |
03-03-2010, 11:10 PM | #73 |
03-05-2010, 12:20 AM | #74 |
Alan
03-05-2010, 01:53 AM | #75 |
Countdown Survivor
That paint looks really good!
Your first paint job? I think not, I remember what my first try looked like.
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
