#51 |
Re: Cutting holes in a perfectly good hood
That's cool.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#52 |
That is awsome, I wish that I could do body work like that. You know what would make it look even better? if you installed 3 more dummy carbs on the other side just for show even if they are just part of the hood. Looks great thou.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
#53 |
Nothing to see here.....
![]() Join Date: Jun 2007
clean, functional, and right on. brrrrravo!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#54 |
Seņor Member
Note to self: Loctite the cones holding the air cleaners on.
I lost one on Hwy 92 up in the hills where there's no place to stop. It was just rolling around on the hood like one of those marble maze games until I finally lost it on a curve. So then I had to watch the air cleaner bounce around on the threads, just waiting for it to fly off. It didn't. I got home, pulled out a spare cone nut, and added a few drops of Loctite to each. ![]()
#55 |
Seņor Member
Got a bracket made to mount the Edelbrock fuel block. You can barely see the bracket... on one end it is shaped like the carb base, and so is mounted under the center carb. On the other end, it's got provisions for the fuel block itself. I've started running fuel lines, but need to resolve a fitting issue for the pressure gauge that goes in the front slot before I move the fuel feed from the rear carb to the block itself.
#56 |
Eat My Rust
Absolutly sick setup. Wish it was a true three-duece, but maybe another time with some more scratch.
Love the 3 spikes out the hood! And with it being off set it's a nice unique little look. |
#57 | |
Seņor Member
#58 |
VA72C10
![]() Join Date: Mar 2008
Very cool!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#59 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Let me guess h.h.r.?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#60 | |
Eat My Rust
#61 | |
Seņor Member
![]() One of these days...
#62 |
Love the six. I'd like to see them more often. Any idea what horsepower you have?
81 Blazer 69 C-10 |
#63 |
Very cool... Spotted the carbs in another thread you started but never seen this till now.. Awesome job on the hood... Love the attention to detail !
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#64 |
![]() Join Date: Aug 2005
You have consistantly chosen outstanding mods for this truck. Can't wait to see what's next!
#65 | |
Seņor Member
#66 | |
Seņor Member
![]() It's actually about time for a rebuild. I'm trying to track down a good shop to do a highly reliable stock-type build... maybe lump head inserts and a more effective cam, but no hot rod planned.
#67 |
you inline 6 guys are nuts!
#68 |
Personally, I think you need to make it function. The way it is now to me it is a little cheesy because it is going to be an attention getter but it doesn't actually work. There is no reason for it not to work since you went through the trouble. You can set it up so it works off of the center carb till you reach like 70% throttle and then the outers come in like a 4v carb. Then your fuel consumption will be the same and drivability will be the same. You just need to make a new billet adaptor with runners and make it from 3 pieces that would bolt together
#69 |
Seņor Member
#70 |
well stock they say 145 for trucks 150 for camaros idk if i belive that though had one in my panel for a year or so and it was weak
#71 |
Eat My Rust
140 in my old firebird was nothing to brag about (good old 12 seconds to 60), so I can't imagine it being any quicker in a much heavier steel brick
#72 |
that is so sick
![]() i really like it two thumbs up great job!
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#73 |
Fat Fendered Fleetside
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
#74 |
I'm normally all about making everything function but I have to say,,,,,,functional or not this is simply brilliant!!! You have pulled off, something that could have gone horribly wrong, extremely well.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
#75 |
I think this is aw-some!
