#51 |
Re: Need pics 60-66 (slammed not bagged)
Cut coils up front and leaf springs in the back
#52 |
montana54 what did you do to the leafs in the rear to get the drop and is it still semi functional? ive been searching for the best way to do it. did i see that truck at milltown last year?
#53 |
Yep, great show! and the truck had coil springs in the back, when i was 14 the trailing arms were too expensive, so I got $50 leaf springs welded up some mounts, put the axle on top of the leafs, then a large rubber bump stop on the frame to help with bottoming out, only about 2" of clearance, but it rides great back there. On a truck that had leaf springs if you put the axle on top, it lowers the back about 6", you can also reverse one of the center leaf springs in the pack to lower it about 2-3"
#54 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
#55 |
My recent purchase 66 c10
#56 |
I haven't posted my build yet, but here's my 63, with 2 1/2" spindles, 2 1/2" drop springs up front, and 5" springs with a 1" block out back. C-notched on
20's... gonna go another inch all the way around soon. |
#57 |
Very nice ride you've got OC Short Box. Show us more pics.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#58 |
![]() Join Date: Sep 2011
Saw this truck at the CPP event last March. Pictures just can't do it justice. Major drooling!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#59 |
![]() Join Date: Nov 2010
2 coils removed from front and jeep springs in rear
LIFE IS SHORT HAVE FUN |
#60 |
We did the same on this one
#61 |
Front Stepped lower control Arms, Cut 3/4 ton springs relocated shocks Camero sway bar
Rear, Small notch and cut 3/4 ton springs and Camero sway bar Corners Great Rides GREAT
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#62 | |
#63 | |
Am a owner of a 66 short stepper as well. Engine sound pretty strong in it as well. Personally I wouldn't do much to it at all ...looks like its ready to be driven! |
#64 |
Cut another1/2 a coil off the front and put bags on schrader valves out back. Diggin it!
![]() [/ATTACH] |
#65 |
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#66 |
![]() Join Date: Aug 2014
Let's bump this thread! I'm needing some insight in this direction with my 65.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#67 | |
my '62 rear bag Schrader valves and torsion bar before Porterbuilt!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#68 |
#69 |
I have a 4.5 in drop up front be careful if you go any lower. My lower control arms scrape if I go over a speed bump to fast. But I guess that is why they are called speed bumps.
#70 |
Does anyone have pics of a SWB on a 2" front and 4" rear?
My mother is a recent cancer survivor and this truck build is for her |
#71 |
@ Austinbelair- close to what you're looking for....
here my ol turd 4.5" up front ...4" out back ....soon to be 2 more in the rear....possibly ![]() ![]()
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
#72 |
My 66, 2 1/2 drop spindles and 2 inch drop springs in front, 4 inch drop springs in rear. I cut half the rubber stop in back to give about another inch of travel. Don't really care for bags in my humble opinion.
#73 |
Some awesome trucks! Let's keep this alive..
#74 |
![]() ![]() Join Date: Aug 2013
I'm In
#75 |
![]() ![]() Join Date: Jul 2002
My 64
2 1/2" spindles and 2" springs up front, 6" springs in the rear (4.5/6)
