Old 09-25-2009, 11:27 PM   #51
joe231
joe231's Avatar
Re: '89 3/4T 'burb front-end swap to '66 C20
Originally Posted by iehotrod View Post
Cudos to you.... I never knew you can use an 89 front suspensions on these c-10's awsome deal nice job John...
Originally Posted by Eagar1 View Post
Suburbans and blazers retained the same suspension and body panels as the 81-87 c10-20's thru 91. They did get a new core support, and newer headlight arrangement. but 90% of it was still the same.
don't forget the crew cabs
joe231 youknow anyone?
I know of a few here in Ok....sorry I posted that after John's post but I guess you guys replied before I got it posted
iehotrod, check craigslist.
also your post is basically a WTB, which is against forum rules unless you are a supporting member, just a friendly FYI
CHEVY ONLY
Old 09-25-2009, 11:29 PM   #52
iehotrod
iehotrod's Avatar
ok its a bit far...
iehotrod is offline   Reply With Quote
Old 09-26-2009, 09:50 AM   #53
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by Chevy Fleetside View Post
For those of you that don't know. I am the John that helped him.
I'm glad you cleared that up....Your the one that helped...and I'm the good lookin one !!!
Thanks man !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-26-2009, 10:31 AM   #54
Chevy Fleetside
Chevy Fleetside's Avatar
If you asked the question. How many Johns on the site. I think that thread would be the biggest....
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-28-2010, 03:59 AM   #55
64c20crewcab
64c20crewcab's Avatar
Great build up for your 3/4! I'm at the beginning stages of the frame clean-up. Big fan of the POR-15 as well! Nice job!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 06-03-2010, 02:10 PM   #56
spr85gmc
spr85gmc's Avatar
subcribed Im in a litttle late but Im here
spr85gmc is offline   Reply With Quote
Old 07-19-2011, 02:21 AM   #57
iehotrod
iehotrod's Avatar
will the 73-87 k-memeber fir a 62?
Old 07-19-2011, 03:25 AM   #58
NorthstarGMC
a K crossmember? I would stick with 2WD crossmembers
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 07-19-2011, 03:27 AM   #59
padresag
what do you mean by "K" member(K stands for 4x4). if you are asking whether or not that a 73-87 frt axle fits in place of the 62 axle you would have to measure as unfamiliar with the spring spacing and the axle perches. the later (73-87) does fit in place on the 64-66 frt axle. spring perches have to be moved a little on the rear axle 64-66
ron
padresag is offline   Reply With Quote
Old 07-19-2011, 04:13 PM   #60
Captainfab
60-66 Nut
I believe the 'K member' that iehotrod is referring to is a common term used for the front suspension crossmember on a vehicle.
To answer your question iehotrod, yes the '73-'87 'K member' will work on a '60-'62 frame. It is a little more work than on the '63-66's as there are more holes that need to be drilled. I know there are a thread or two on here that give more insight.
Old 07-19-2011, 04:53 PM   #61
iehotrod
iehotrod's Avatar
Thanks captain
Old 07-19-2011, 05:06 PM   #62
kieth
kieth's Avatar
Originally Posted by Hilandr451 View Post
whew! you guys really know how to bury a post!
Hilander you are the reason I tore into my truck, I read your thread and said well I can do that, it only took you 3 days and I am now on 10 months, but we are close to completely frame off---ing my 66 1/2 ton gmc. Thanks for the inspiration. Kieth
It started out looking like this:
http://kieth.smugmug.com/Trucks/66-G...67555158_RNLWE
Got stripped down to this:
http://kieth.smugmug.com/Trucks/66-G...38809030_eUypo
Put back together starting here, using a 91 burb 2wd chasis:
http://kieth.smugmug.com/Trucks/66-G...05_PwoKs-X2-LB
And right now it looks like this:
http://kieth.smugmug.com/Trucks/66-G...847715_ctDzSfp
All due to your inspiration-------thanks, what am I saying should I thank you for all this pain, loss of play time, money, busted knuckles ?
Maybe I take that all back----------------ha ha thanks again, Kieth
It should be running in a couple of weeks.....
kieth is offline   Reply With Quote
Old 07-23-2011, 05:34 PM   #63
Hilandr451
Hilandr451's Avatar
well, you're welcome I guess...
Johnny and I were trying to give a good "how-to" documentation of the front end swap. Given the response this thread has received over the years, I think we were successful.
Keep in mind my brother that my 66 is no where near the state of completion yours is! Nice truck!!!
In fact it's pretty much in the same state it was at the end of the front end swap! Now I have to move to Bakersfield and the restoration is once again put on hold. BUT..... I will have the means to finish it when I get settled in at Bakersfield since I will be making a lot more money, and spending a LOT less on rent, utilities, groceries, commuting, etc.. also there are many more resources for parts and donor trucks where I'm going than where I live now.
I must say though, that I will miss my good friend and truck partner John terribly when I go. We have had a lot of good times together working on our trucks and trolling through junk yards.
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 11-04-2012, 12:14 AM   #64
1955 mancave
1955 mancave's Avatar
you guys did a great job with the pictures and documentation, i am just about to do the same but on my 64 1 ton.
you know when you said how its funny how life deals you the cards, like you comming back from that med. issue, and now you just dont want to stop moving, i hear you , after i lost around 225lbs i just hate sitting around.
i know this is an older post but hope all is good with you.
Henry.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 01-21-2013, 06:33 PM   #65
earl84
This is just the information I was looking for!!! Geez, I love this forum. I have been looking for the answer if I can just swap a C20 crossmember and all just like a C10 crossmember and here it is complete with pictures.
I know this is an old thread as well, but I hope all is well with you still, healthwise and on a personal level.
Side note, I used to be stationed out at Fort Irwin and have been through Bakersfield a time or two. Desert life wasn't for me, but it does have its own beauty and it sure is nice for having wide open spaces and awesome sunsets/temps at night.
earl84 is offline   Reply With Quote
Old 01-21-2013, 07:15 PM   #66
MikeS.
MikeS.'s Avatar
Still a great write up 3 plus years later.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 01-21-2013, 07:18 PM   #67
1955 mancave
i just got done with mine last week, and this thread was also what i used to make the decision to do it, yes pictures are good, i'm not sure if the guys who posted the original thread are still around here , i have sent pm's but have not gotten a reply as of yet.
Old 01-22-2013, 11:13 AM   #68
Chevy Fleetside
You didn't send me a private message. Greg is the one who rebuilt his front end and I was there to help him put it in his truck Or should I say he was there to help me put it in He is fine and well in Bakersfield Ca. I remember this like it was yesterday. Ok maybe the day before.. I will tell him to chime in here and look at his post.
Old 01-22-2013, 01:32 PM   #69
1955 mancave
well you guys did a great job, and i'm glad he is doing well as i hope you are also.
thanks John.
Old 01-23-2013, 02:32 AM   #70
Chevy Fleetside
I like working on these old trucks.
Old 01-23-2013, 08:09 AM   #71
1955 mancave
i think most of us do, it's funny i was talking to my brother and he has just abandoned this hobby, said he does not like to play with cars anymore, i find that to be sad ! he is even selling his car
i dont understand him but hey his life his choice.
Old 02-16-2013, 12:48 AM   #72
Hilandr451
Hilandr451's Avatar
Hidey-Ho Chevy brothers! just checkin' in on this old thread!
Me & Johnny had a blast putting my '66 together that week. I remember the harrowing test drive after - sheesh what a ride! The clamp on the rag joint was stripped and the steering wheel was, uh shall we say, "less than responsive"!
We had just as much fun a few months later scrapping out his '81 C10!
My health is holding and I'm just getting ready to start back in on my truck. The truck is running great today. I still drive it to work now & again. We hauled our 26 ft Airstream camping trailer down 300 miles from Vacaville to Bakersfield when we moved. We had a few problems with the trailer, but the truck ran like a charm!
Old 02-16-2013, 01:22 AM   #73
Chevy Fleetside
Im getting closer to tearing into the 3/4 ton and getting that rear diff to you.
Old 02-16-2013, 02:24 AM   #74
padresag
shouldn't that be Johnny and I or is the haggis throwing you off your game. what happened to your door
ron
Old 02-16-2013, 12:10 PM   #75
Chevy Fleetside
ron
Too much work and not enough play. Haggis has nothing to do with it.
