11-03-2009, 04:20 PM | #51 |
Re: John's 87 S10 - Epilepsy build up
Any Updates?
11-03-2009, 08:22 PM | #52 |
I have been working on other projects to pay the bills for about a month, but I have been back on this thing for a few days now. Wiring is finished, and built the exhaust system today, so I will have some pictures tonight. Right now I need to get ready for league night.
If you can find it cheaper, I can fix it! |
11-03-2009, 08:41 PM | #53 |
Screw it I got a minute.
I built the exhaust system for Johns truck today. Stock was 2" to the cat and then 2.25" after that. I decided to step the whole thing up to 2.50" tube with all mandrel bends, a high flow Magnaflow cat, and a Dynomax Thrush welded muffler, which is similar to a Flowmaster design. It is all TIG welded aside from the hangers and where it meets the 2" - 2.50" reducer right at the manifold. At no point does any of it hang below the frame. The closest part is when it crosses over, where it has about 1/4" of room above and below the tube. Here is a picture of the back aired out. This is as low as it goes with the bed bolted on and the wheel wells uncut. There is still about 1/2" 1" between the axle and the bump stops, so I need to cut the fenderwells up about 2 inches. so they clear in any circumstance. The last picture is if a box I made to hold the air gauges and switches for the pressure switch and manually bypassing the lights. I figure since the gauges point right up at you, lights might be annoying at times. It needs a really good wash now. There was a lot of crap under the bed liner that got on everything.
11-04-2009, 08:26 AM | #54 |
Is looking really good
11-04-2009, 10:24 AM | #55 |
looks awesome!!!
12-06-2009, 02:31 PM | #56 |
Here are the nearly finished pictures of John's truck. I had to move it out to get the VW in to work on it. He brought by a battery so I can start it, and finish up the little stuff and the stereo now.
Obviously cutting the inner fenders more is one of those little things I need to take care of.
12-06-2009, 02:47 PM | #57 |
low n' slo
that looks good. is the rear rubs sitting on the wheels?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-06-2009, 03:05 PM | #58 |
Yes, as I said above that's still one of the little things I need to take care of when it comes back into the shop.
12-06-2009, 04:25 PM | #59 |
Keepin it old school
Looks good man
12-06-2009, 04:49 PM | #60 |
Wow, this is a great build! What have you done to the front? I have a 91 that I have fixed up with my son, but we have some clearance problems on the front, it actually broke out the air conditioning box and fan. I would like it too be low, but it needs to function, and on a realistic budget.
12-06-2009, 06:46 PM | #61 |
>130dB Moderator
Seth, Let m know when you want me to bring all the stuff down.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
12-07-2009, 12:42 AM | #62 | |
PM me your number. I should be ready soon, I just need to wrap up the project that is currently in the shop.
12-07-2009, 05:55 AM | #63 |
The front is really basic, just dehumped lower arms and pie cut upper arms. The firewall and the AC box hit the tires though. It holds it up about a half inch. I haven't figured out what I am doing about it yet.[/QUOTE]
Ok, I'm sorry too say, I don't know what dehumping the lower arms is, and I'm not familiar with a pie cut on the upper arms. Does this move the wheels inboard? Thanks S |
12-07-2009, 12:41 PM | #64 |
No it just allows the spindle to move up further without the upper ball joints binding, and without the lower arm hitting the frame.
12-08-2009, 12:42 AM | #65 |
THE TOY STORE
trucks look'n good but i had an old nova that had dump exhoust on the wheel like that and one day it burnt a little to much oil (not a good car) and it was like a slip and slid
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
04-25-2014, 10:50 PM | #66 |
Blazer Fanatic
what ever became of this build and is it all done? Very honorable of you and generous to help someone out
1970 Chevy blazer |
