Old 08-26-2009, 05:20 PM   #51
68 TT
Still plays with trucks
68 TT's Avatar
Re: What did you get done 8/23/2009 edition
Originally Posted by whiskeydented View Post
Here is the link, just join and send a pm.
http://www.pirate4x4.com/forum/showt...876&highlight=
Thanks. I was all ready a member, just had to dust off my login and password.
68 TT is offline   Reply With Quote
Old 08-26-2009, 06:36 PM   #52
SCOTI
SCOTI's Avatar
Originally Posted by menace121978 View Post
Thanks. I purchased the gold (brass?) style from Inline Tubing when I bought the stainless brakeline kit. I was looking for something a little nicer & this looks to fit my needs (& budget).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-26-2009, 07:09 PM   #53
68 TT
68 TT's Avatar
It bothers me that the ad says it is for drum/drum, disc/drum and disc/disc.
There should be different items allowing more or less fluid to front/rear to balance out breaking force because the three systems they say it will work for all have very different amounts of braking force at each end.
Old 08-26-2009, 08:03 PM   #54
BIG V
Just got the notch done on my crew cab next comes helper bags and gooseneck hitch. took 2 days monday and tuesday the bilsteins ride perfectly
BIG V is offline   Reply With Quote
Old 08-27-2009, 12:02 AM   #55
menace121978
menace121978's Avatar
anytime man. i liked the looks too! couldnt see spending $100-$200 for a original gm one...
iduno? i have rear disc w/ the same brake hoses and calipers in the rear as the front. worst comes to worse i'll have to get an adjustable valve that just goes right under the bed from summit for like $38 to adjust the rears.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-27-2009, 10:27 AM   #56
68 TT
68 TT's Avatar
I would go with the adjustable unit from Summit. I have used it twice before on cars I put rear disc on and it helped tremendously in getting the threshold braking dialed in.
You want the rear to lock up just slightly before the front.
Rear disc conversions usually cause brake lockup issues without the right proportioning valve. Rare 4-wheel disc exceptions exist like the C3 Corvette that didn't use a prop valve at all. It was balanced well enough that a straight distribution block did the job.
Get the adjustable unit from Summit and you will be good to go and for much less money than that universal part that probably won't do the job properly for a truck with so little back end weight.
